How to enable Platform SCP when using SE050
yang_lee
Hello everyone,
I'm using SE050E and having trouble using Platform SCP. I followed the instructions in AN12542 (https://www.nxp.jp/docs/en/application-note/AN12542.pdf#4#4) and defined SSS_HAVE_SE05X_AUTH_PLATFSCP03 1, but when I open a session by calling the ex_sss_boot_open function, the result is kStatus_SSS_Fail. Did I do something wrong? Everything worked fine when I use plain communication. Please let me know if I need to configure anything else.
Tags (2)
Kan_Li
Hi @yang_lee ,
The example provided in the chapter 6 is just for SE050E, but at first please make sure which build system you are using.
1. For MCUXpresso SDK based, please follow the steps within 6.2 and 6.3
2. For Cmake based, please follow the steps within 6.4 and 6.5
Hope that helps,
Kan
yang_lee
Hi @Kan_Li ,
I followed the instructions in sections 6.2 and 6.3 and tried running the se05x_MandatePlatformSCP example in SE-PLUG-TRUST-MW_04.07.01, but the sss_key_object_init(eraseAuthCtx.auth.ctx.idobj.pObj, &pCtx->host_ks) function returned kStatus_SSS_InvalidArgument. Do I need to call the ex_sss_boot_open, ex_sss_key_store_and_object_init, and ex_sss_boot_open_host_session functions as in the ex_sss_main_inc.h file before calling the sss_key_object_init function? The code is below:
/* clang-format off */
#define MandateSCP_UserID_VALUE                 \
        'N', 'E', 'E', 'D', 'S', 'C', 'P'            \
/* clang-format ON */
sss_status_t se050_platformSCP03(void)
sss_status_t status = kStatus_SSS_Fail;
    sss_object_t keyObject;
    ex_sss_boot_ctx_t gex_sss_mandate_scp_boot_ctx;
SE_Connect_Ctx_t eraseAuthCtx = { 0 };
sss_se05x_session_t *pSession = (sss_se05x_session_t *)&gex_sss_mandate_scp_boot_ctx.session;
    smStatus_t sw_status;
    Se05xSession_t *pSe05xSession;
    SE_Connect_Ctx_t* pOpenCtx;
    sss_object_t ex_id = { 0 };
    const uint8_t host_userid_value[] = MandateSCP_UserID_VALUE;
    const uint8_t userid_value_factoryreset[] = MandateSCP_UserID_VALUE;
    eraseAuthCtx.auth.ctx.idobj.pObj = &ex_id;
const char *portName = NULL;
    memset(&gex_sss_mandate_scp_boot_ctx, 0, sizeof(gex_sss_mandate_scp_boot_ctx));
//    /* initialize session to connect to the SE050 */
//    status = ex_sss_boot_open(&gex_sss_mandate_scp_boot_ctx, portName);
//    if (kStatus_SSS_Success != status)
//        ex_sss_session_close(&gex_sss_mandate_scp_boot_ctx);
//        return status; /* return error if can't initialize session with SE050 */
//    /* setup KeyStore */
//    status = ex_sss_key_store_and_object_init(&gex_sss_mandate_scp_boot_ctx);
//        return status; /* close sesion and return error if can't initialize fail */
//    ex_sss_boot_open_host_session(&gex_sss_mandate_scp_boot_ctx);
    /* Prepare host */
    status = sss_key_object_init(eraseAuthCtx.auth.ctx.idobj.pObj, &gex_sss_mandate_scp_boot_ctx.host_ks);
    if (kStatus_SSS_Success != status) {
        LOG_E("Failed sss_key_object_init");
        goto cleanup;
    status = sss_key_object_allocate_handle(eraseAuthCtx.auth.ctx.idobj.pObj,
                                            MAKE_TEST_ID(__LINE__),
                                            kSSS_KeyPart_Default,
                                            kSSS_CipherType_UserID,
                                            sizeof(host_userid_value),
                                            kKeyObject_Mode_Transient);
        LOG_E("Failed sss_key_object_allocate_handle");
        goto cleanup;
    status = sss_key_store_set_key(&gex_sss_mandate_scp_boot_ctx.host_ks,
                                   host_userid_value,
                                   sizeof(host_userid_value) * 8,
                                   NULL,
                                   0);
        LOG_E("Failed sss_key_store_set_key");
        goto cleanup;
    pSe05xSession = &pSession->s_ctx;
    sw_status = Se05x_API_WriteUserID(pSe05xSession,
        NULL,
        SE05x_MaxAttemps_NA,
        kSE05x_AppletResID_PLATFORM_SCP,
        userid_value_factoryreset,
        sizeof(userid_value_factoryreset),
        kSE05x_AttestationType_AUTH);
    pOpenCtx = &gex_sss_mandate_scp_boot_ctx.se05x_open_ctx;
    eraseAuthCtx.tunnelCtx = pOpenCtx->tunnelCtx;
    eraseAuthCtx.connType = pOpenCtx->connType;
    eraseAuthCtx.portName = pOpenCtx->portName;
    eraseAuthCtx.auth.authType = kSSS_AuthType_ID;
    sss_session_close(&gex_sss_mandate_scp_boot_ctx.session);
    status = sss_session_open(&gex_sss_mandate_scp_boot_ctx.session, kType_SSS_SE_SE05x,
                               kSSS_ConnectionType_Password, &eraseAuthCtx);
        LOG_E("Failed sss_session_open");
        goto cleanup;
    /* Call SE05X API to Mandate Platform SCP. */
    sw_status = Se05x_API_SetPlatformSCPRequest(&pSession->s_ctx, kSE05x_PlatformSCPRequest_REQUIRED);
    if(SM_OK != sw_status) {
        LOG_E("Se05x_API_SetPlatformSCPRequest Failed");
        goto cleanup;
    else {
        LOG_I("Se05x_API_SetPlatformSCPRequest Successful");
        LOG_W("Further communication must be encrypted");
cleanup:
    if (kStatus_SSS_Success == status) {
        LOG_I("se05x_MandatePlatformSCP Example Success !!!...");
    else {
        LOG_E("se05x_MandatePlatformSCP Example Failed !!!...");
    return status;
Duong
Tags (2)
%3CLINGO-SUB%20id%3D%22lingo-sub-2372103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHow%20to%20enable%20Platform%20SCP%20when%20using%20SE050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2372103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20everyone%2C%3C%2FP%3E%3CP%3EI'm%20using%20SE050E%20and%20having%20trouble%20using%20Platform%20SCP.%20I%20followed%20the%20instructions%20in%20AN12542%20(%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.jp%2Fdocs%2Fen%2Fapplication-note%2FAN12542.pdf%234%234%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.jp%2Fdocs%2Fen%2Fapplication-note%2FAN12542.pdf%234%234%3C%2FA%3E)%20and%20defined%20SSS_HAVE_SE05X_AUTH_PLATFSCP03%201%2C%20but%20when%20I%20open%20a%20session%20by%20calling%20the%20ex_sss_boot_open%20function%2C%20the%20result%20is%20kStatus_SSS_Fail.%20Did%20I%20do%20something%20wrong%3F%20Everything%20worked%20fine%20when%20I%20use%20plain%20communication.%20Please%20let%20me%20know%20if%20I%20need%20to%20configure%20anything%20else.%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2372103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ESE050%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2372709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20enable%20Platform%20SCP%20when%20using%20SE050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2372709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EI%20followed%20the%20instructions%20in%20sections%206.2%20and%206.3%20and%20tried%20running%20the%20%3CEM%3Ese05x_MandatePlatformSCP%3C%2FEM%3E%20example%20in%20%3CSTRONG%3ESE-PLUG-TRUST-MW_04.07.01%3C%2FSTRONG%3E%2C%20but%20the%20%3CEM%3Esss_key_object_init%3C%2FEM%3E(eraseAuthCtx.auth.ctx.idobj.pObj%2C%20%26amp%3BpCtx-%26gt%3Bhost_ks)%20function%20returned%20kStatus_SSS_InvalidArgument.%20Do%20I%20need%20to%20call%20the%20ex_sss_boot_open%2C%20%3CEM%3Eex_sss_key_store_and_object_init%3C%2FEM%3E%2C%20and%20%3CEM%3Eex_sss_boot_open_host_session%3C%2FEM%3E%20functions%20as%20in%20the%20%3CEM%3Eex_sss_main_inc.h%3C%2FEM%3E%20file%20before%20calling%20the%20%3CEM%3Esss_key_object_init%3C%2FEM%3E%20function%3F%20The%20code%20is%20below%3A%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%3E%2F*%20clang-format%20off%20*%2F%3C%2FDIV%3E%3CDIV%3E%23define%20MandateSCP_UserID_VALUE%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%5C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%5C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20'N'%2C%20'E'%2C%20'E'%2C%20'D'%2C%20'S'%2C%20'C'%2C%20'P'%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%5C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%2F*%20clang-format%20ON%20*%2F%3C%2FDIV%3E%3CDIV%3Esss_status_t%20se050_platformSCP03(void)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Esss_status_t%20status%20%3D%20kStatus_SSS_Fail%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20sss_object_t%20keyObject%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20ex_sss_boot_ctx_t%20gex_sss_mandate_scp_boot_ctx%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ESE_Connect_Ctx_t%20eraseAuthCtx%20%3D%20%7B%200%20%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Esss_se05x_session_t%20*pSession%20%3D%20(sss_se05x_session_t%20*)%26amp%3Bgex_sss_mandate_scp_boot_ctx.session%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20smStatus_t%20sw_status%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20Se05xSession_t%20*pSe05xSession%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20SE_Connect_Ctx_t*%20pOpenCtx%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20sss_object_t%20ex_id%20%3D%20%7B%200%20%7D%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20const%20uint8_t%20host_userid_value%5B%5D%20%3D%20MandateSCP_UserID_VALUE%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20const%20uint8_t%20userid_value_factoryreset%5B%5D%20%3D%20MandateSCP_UserID_VALUE%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20eraseAuthCtx.auth.ctx.idobj.pObj%20%3D%20%26amp%3Bex_id%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Econst%20char%20*portName%20%3D%20NULL%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20memset(%26amp%3Bgex_sss_mandate_scp_boot_ctx%2C%200%2C%20sizeof(gex_sss_mandate_scp_boot_ctx))%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%26nbsp%3B%20%26nbsp%3B%20%2F*%20initialize%20session%20to%20connect%20to%20the%20SE050%20*%2F%3C%2FDIV%3E%3CDIV%3E%2F%2F%26nbsp%3B%20%26nbsp%3B%20status%20%3D%20ex_sss_boot_open(%26amp%3Bgex_sss_mandate_scp_boot_ctx%2C%20portName)%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%26nbsp%3B%20%26nbsp%3B%20if%20(kStatus_SSS_Success%20!%3D%20status)%3C%2FDIV%3E%3CDIV%3E%2F%2F%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FDIV%3E%3CDIV%3E%2F%2F%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20ex_sss_session_close(%26amp%3Bgex_sss_mandate_scp_boot_ctx)%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20return%20status%3B%20%2F*%20return%20error%20if%20can't%20initialize%20session%20with%20SE050%20*%2F%3C%2FDIV%3E%3CDIV%3E%2F%2F%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%26nbsp%3B%20%26nbsp%3B%20%2F*%20setup%20KeyStore%20*%2F%3C%2FDIV%3E%3CDIV%3E%2F%2F%26nbsp%3B%20%26nbsp%3B%20status%20%3D%20ex_sss_key_store_and_object_init(%26amp%3Bgex_sss_mandate_scp_boot_ctx)%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%26nbsp%3B%20%26nbsp%3B%20if%20(kStatus_SSS_Success%20!%3D%20status)%3C%2FDIV%3E%3CDIV%3E%2F%2F%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FDIV%3E%3CDIV%3E%2F%2F%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20ex_sss_session_close(%26amp%3Bgex_sss_mandate_scp_boot_ctx)%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20return%20status%3B%20%2F*%20close%20sesion%20and%20return%20error%20if%20can't%20initialize%20fail%20*%2F%3C%2FDIV%3E%3CDIV%3E%2F%2F%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%26nbsp%3B%20%26nbsp%3B%20ex_sss_boot_open_host_session(%26amp%3Bgex_sss_mandate_scp_boot_ctx)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%2F*%20Prepare%20host%20*%2F%26nbsp%3B%20%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20status%20%3D%20sss_key_object_init(eraseAuthCtx.auth.ctx.idobj.pObj%2C%20%26amp%3Bgex_sss_mandate_scp_boot_ctx.host_ks)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20if%20(kStatus_SSS_Success%20!%3D%20status)%20%7B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20LOG_E(%22Failed%20sss_key_object_init%22)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20goto%20cleanup%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20status%20%3D%20sss_key_object_allocate_handle(eraseAuthCtx.auth.ctx.idobj.pObj%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20MAKE_TEST_ID(__LINE__)%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20kSSS_KeyPart_Default%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20kSSS_CipherType_UserID%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20sizeof(host_userid_value)%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20kKeyObject_Mode_Transient)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20if%20(kStatus_SSS_Success%20!%3D%20status)%20%7B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20LOG_E(%22Failed%20sss_key_object_allocate_handle%22)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20goto%20cleanup%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20status%20%3D%20sss_key_store_set_key(%26amp%3Bgex_sss_mandate_scp_boot_ctx.host_ks%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BeraseAuthCtx.auth.ctx.idobj.pObj%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bhost_userid_value%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bsizeof(host_userid_value)%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bsizeof(host_userid_value)%20*%208%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BNULL%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B0)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20if%20(kStatus_SSS_Success%20!%3D%20status)%20%7B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20LOG_E(%22Failed%20sss_key_store_set_key%22)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20goto%20cleanup%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20pSe05xSession%20%3D%20%26amp%3BpSession-%26gt%3Bs_ctx%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20sw_status%20%3D%20Se05x_API_WriteUserID(pSe05xSession%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20NULL%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20SE05x_MaxAttemps_NA%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20kSE05x_AppletResID_PLATFORM_SCP%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20userid_value_factoryreset%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20sizeof(userid_value_factoryreset)%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20kSE05x_AttestationType_AUTH)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20pOpenCtx%20%3D%20%26amp%3Bgex_sss_mandate_scp_boot_ctx.se05x_open_ctx%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20eraseAuthCtx.tunnelCtx%20%3D%20pOpenCtx-%26gt%3BtunnelCtx%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20eraseAuthCtx.connType%20%3D%20pOpenCtx-%26gt%3BconnType%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20eraseAuthCtx.portName%20%3D%20pOpenCtx-%26gt%3BportName%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20eraseAuthCtx.auth.authType%20%3D%20kSSS_AuthType_ID%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20sss_session_close(%26amp%3Bgex_sss_mandate_scp_boot_ctx.session)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20pSe05xSession%20%3D%20%26amp%3BpSession-%26gt%3Bs_ctx%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20status%20%3D%20sss_session_open(%26amp%3Bgex_sss_mandate_scp_boot_ctx.session%2C%20kType_SSS_SE_SE05x%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BkSE05x_AppletResID_PLATFORM_SCP%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BkSSS_ConnectionType_Password%2C%20%26amp%3BeraseAuthCtx)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20if%20(kStatus_SSS_Success%20!%3D%20status)%20%7B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20LOG_E(%22Failed%20sss_session_open%22)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20goto%20cleanup%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%2F*%20Call%20SE05X%20API%20to%20Mandate%20Platform%20SCP.%20*%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20sw_status%20%3D%20Se05x_API_SetPlatformSCPRequest(%26amp%3BpSession-%26gt%3Bs_ctx%2C%20kSE05x_PlatformSCPRequest_REQUIRED)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20if(SM_OK%20!%3D%20sw_status)%20%7B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20LOG_E(%22Se05x_API_SetPlatformSCPRequest%20Failed%22)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20goto%20cleanup%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20else%20%7B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20LOG_I(%22Se05x_API_SetPlatformSCPRequest%20Successful%22)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20LOG_W(%22Further%20communication%20must%20be%20encrypted%22)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Ecleanup%3A%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20if%20(kStatus_SSS_Success%20%3D%3D%20status)%20%7B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20LOG_I(%22se05x_MandatePlatformSCP%20Example%20Success%20!!!...%22)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20else%20%7B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20LOG_E(%22se05x_MandatePlatformSCP%20Example%20Failed%20!!!...%22)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20return%20status%3B%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EDuong%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2372675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20enable%20Platform%20SCP%20when%20using%20SE050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2372675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252826%22%20target%3D%22_blank%22%3E%40yang_lee%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThe%20example%20provided%20in%20the%20chapter%206%20is%20just%20for%20SE050E%2C%20but%20at%20first%20please%20make%20sure%20which%20build%20system%20you%20are%20using.%3C%2FP%3E%0A%3CP%3E1.%20For%26nbsp%3BMCUXpresso%20SDK%20based%2C%20please%20follow%20the%20steps%20within%206.2%20and%206.3%3C%2FP%3E%0A%3CP%3E2.%20For%20Cmake%20based%2C%20please%26nbsp%3Bfollow%20the%20steps%20within%206.4%20and%206.5%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHope%20that%20helps%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHave%20a%20great%20day%2C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22Mark%20Correct%22%20button.%20Thank%20you!%3CBR%20%2F%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
