How to enable Platform SCP when using SE050
1,006件の閲覧回数
yang_lee
Hello everyone,
I'm using SE050E and having trouble using Platform SCP. I followed the instructions in AN12542 (https://www.nxp.jp/docs/en/application-note/AN12542.pdf#4#4) and defined SSS_HAVE_SE05X_AUTH_PLATFSCP03 1, but when I open a session by calling the ex_sss_boot_open function, the result is kStatus_SSS_Fail. Did I do something wrong? Everything worked fine when I use plain communication. Please let me know if I need to configure anything else.
タグ(2)
2 返答(返信)
971件の閲覧回数
Kan_Li
Hi @yang_lee ,
The example provided in the chapter 6 is just for SE050E, but at first please make sure which build system you are using.
1. For MCUXpresso SDK based, please follow the steps within 6.2 and 6.3
2. For Cmake based, please follow the steps within 6.4 and 6.5
Hope that helps,
Kan
957件の閲覧回数
yang_lee
Hi @Kan_Li ,
I followed the instructions in sections 6.2 and 6.3 and tried running the se05x_MandatePlatformSCP example in SE-PLUG-TRUST-MW_04.07.01, but the sss_key_object_init(eraseAuthCtx.auth.ctx.idobj.pObj, &pCtx->host_ks) function returned kStatus_SSS_InvalidArgument. Do I need to call the ex_sss_boot_open, ex_sss_key_store_and_object_init, and ex_sss_boot_open_host_session functions as in the ex_sss_main_inc.h file before calling the sss_key_object_init function? The code is below:
/* clang-format off */
#define MandateSCP_UserID_VALUE                 \
        'N', 'E', 'E', 'D', 'S', 'C', 'P'            \
/* clang-format ON */
sss_status_t se050_platformSCP03(void)
sss_status_t status = kStatus_SSS_Fail;
    sss_object_t keyObject;
    ex_sss_boot_ctx_t gex_sss_mandate_scp_boot_ctx;
SE_Connect_Ctx_t eraseAuthCtx = { 0 };
sss_se05x_session_t *pSession = (sss_se05x_session_t *)&gex_sss_mandate_scp_boot_ctx.session;
    smStatus_t sw_status;
    Se05xSession_t *pSe05xSession;
    SE_Connect_Ctx_t* pOpenCtx;
    sss_object_t ex_id = { 0 };
    const uint8_t host_userid_value[] = MandateSCP_UserID_VALUE;
    const uint8_t userid_value_factoryreset[] = MandateSCP_UserID_VALUE;
    eraseAuthCtx.auth.ctx.idobj.pObj = &ex_id;
const char *portName = NULL;
    memset(&gex_sss_mandate_scp_boot_ctx, 0, sizeof(gex_sss_mandate_scp_boot_ctx));
//    /* initialize session to connect to the SE050 */
//    status = ex_sss_boot_open(&gex_sss_mandate_scp_boot_ctx, portName);
//    if (kStatus_SSS_Success != status)
//        ex_sss_session_close(&gex_sss_mandate_scp_boot_ctx);
//        return status; /* return error if can't initialize session with SE050 */
//    /* setup KeyStore */
//    status = ex_sss_key_store_and_object_init(&gex_sss_mandate_scp_boot_ctx);
//        return status; /* close sesion and return error if can't initialize fail */
//    ex_sss_boot_open_host_session(&gex_sss_mandate_scp_boot_ctx);
    /* Prepare host */
    status = sss_key_object_init(eraseAuthCtx.auth.ctx.idobj.pObj, &gex_sss_mandate_scp_boot_ctx.host_ks);
    if (kStatus_SSS_Success != status) {
        LOG_E("Failed sss_key_object_init");
        goto cleanup;
    status = sss_key_object_allocate_handle(eraseAuthCtx.auth.ctx.idobj.pObj,
                                            MAKE_TEST_ID(__LINE__),
                                            kSSS_KeyPart_Default,
                                            kSSS_CipherType_UserID,
                                            sizeof(host_userid_value),
                                            kKeyObject_Mode_Transient);
        LOG_E("Failed sss_key_object_allocate_handle");
        goto cleanup;
    status = sss_key_store_set_key(&gex_sss_mandate_scp_boot_ctx.host_ks,
                                   host_userid_value,
                                   sizeof(host_userid_value) * 8,
                                   NULL,
                                   0);
        LOG_E("Failed sss_key_store_set_key");
        goto cleanup;
    pSe05xSession = &pSession->s_ctx;
    sw_status = Se05x_API_WriteUserID(pSe05xSession,
        NULL,
        SE05x_MaxAttemps_NA,
        kSE05x_AppletResID_PLATFORM_SCP,
        userid_value_factoryreset,
        sizeof(userid_value_factoryreset),
        kSE05x_AttestationType_AUTH);
    pOpenCtx = &gex_sss_mandate_scp_boot_ctx.se05x_open_ctx;
    eraseAuthCtx.tunnelCtx = pOpenCtx->tunnelCtx;
    eraseAuthCtx.connType = pOpenCtx->connType;
    eraseAuthCtx.portName = pOpenCtx->portName;
    eraseAuthCtx.auth.authType = kSSS_AuthType_ID;
    sss_session_close(&gex_sss_mandate_scp_boot_ctx.session);
    status = sss_session_open(&gex_sss_mandate_scp_boot_ctx.session, kType_SSS_SE_SE05x,
                               kSSS_ConnectionType_Password, &eraseAuthCtx);
        LOG_E("Failed sss_session_open");
        goto cleanup;
    /* Call SE05X API to Mandate Platform SCP. */
    sw_status = Se05x_API_SetPlatformSCPRequest(&pSession->s_ctx, kSE05x_PlatformSCPRequest_REQUIRED);
    if(SM_OK != sw_status) {
        LOG_E("Se05x_API_SetPlatformSCPRequest Failed");
        goto cleanup;
    else {
        LOG_I("Se05x_API_SetPlatformSCPRequest Successful");
        LOG_W("Further communication must be encrypted");
cleanup:
    if (kStatus_SSS_Success == status) {
        LOG_I("se05x_MandatePlatformSCP Example Success !!!...");
    else {
        LOG_E("se05x_MandatePlatformSCP Example Failed !!!...");
    return status;
Duong
タグ(2)
%3CLINGO-SUB%20id%3D%22lingo-sub-2372103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESE050%E4%BD%BF%E7%94%A8%E6%99%82%E3%81%AB%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0SCP%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2372103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%81%BF%E3%82%93%E3%81%AA%E3%80%81%3C%2FP%3E%3CP%3ESE050E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20SCP%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82AN12542%20(%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.jp%2Fdocs%2Fen%2Fapplication-note%2FAN12542.pdf%234%234%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.jp%2Fdocs%2Fen%2Fapplication-note%2FAN12542.pdf%234%234%3C%2FA%3E%20)%20%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%20SSS_HAVE_SE05X_AUTH_PLATFSCP03%201%20%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81ex_sss_boot_open%20%E9%96%A2%E6%95%B0%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%A6%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%8B%E3%81%8F%E3%81%A8%E3%80%81%E7%B5%90%E6%9E%9C%E3%81%AF%20kStatus_SSS_Fail%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E4%BD%95%E3%81%8B%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E9%80%9A%E5%B8%B8%E3%81%AE%E9%80%9A%E4%BF%A1%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BB%96%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E9%A0%85%E7%9B%AE%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2372103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ESE050%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2372709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20enable%20Platform%20SCP%20when%20using%20SE050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2372709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%206.2%20%E3%81%A8%206.3%20%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%3CSTRONG%3E%20SE-PLUG-TRUST-MW_04.07.01%3C%2FSTRONG%3E%20%E3%81%AE%3CEM%3E%20se05x_MandatePlatformSCP%3C%2FEM%3E%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%3CEM%3E%20sss_key_object_init%3C%2FEM%3E%20(eraseAuthCtx.auth.ctx.idobj.pObj%E3%80%81%26amp%3BpCtx-%26gt%3Bhost_ks)%20%E9%96%A2%E6%95%B0%E3%81%8C%20kStatus_SSS_InvalidArgument%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CEM%3Eex_sss_main_inc.h%3C%2FEM%3E%E3%81%AB%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81ex_sss_boot_open%E3%80%81%20%3CEM%3Eex_sss_key_store_and_object_init%3C%2FEM%3E%20%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%3CEM%3Eex_sss_boot_open_host_session%3C%2FEM%3E%E9%96%A2%E6%95%B0%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CEM%3Esss_key_object_init%3C%2FEM%3E%E9%96%A2%E6%95%B0%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E5%89%8D%E3%81%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%3E%2F*%20clang-format%20%E3%82%AA%E3%83%95%20*%2F%3C%2FDIV%3E%3CDIV%3E%23define%20MandateSCP_UserID_VALUE%20%5C%3C%2FDIV%3E%3CDIV%3E%7B%20%5C%3C%2FDIV%3E%3CDIV%3E'N'%E3%80%81'E'%E3%80%81'E'%E3%80%81'D'%E3%80%81'S'%E3%80%81'C'%E3%80%81'P'%20%5C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%2F*%20clang-format%20ON%20*%2F%3C%2FDIV%3E%3CDIV%3Esss_status_t%20se050_platformSCP03(void)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Esss_status_t%20status%20%3D%20kStatus_SSS_Fail%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Esss_object_t%20keyObject%3B%3C%2FDIV%3E%3CDIV%3Eex_sss_boot_ctx_t%20gex_sss_mandate_scp_boot_ctx%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ESE_Connect_Ctx_t%20eraseAuthCtx%20%3D%20%7B%200%20%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Esss_se05x_session_t%20*pSession%20%3D%20(sss_se05x_session_t%20*)%26amp%3Bgex_sss_mandate_scp_boot_ctx.session%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3EsmStatus_t%20sw_status%3B%3C%2FDIV%3E%3CDIV%3ESe05xSession_t%20*pSe05xSession%3B%3C%2FDIV%3E%3CDIV%3ESE_Connect_Ctx_t*%20pOpenCtx%3B%3C%2FDIV%3E%3CDIV%3Esss_object_t%20ex_id%20%3D%20%7B%200%20%7D%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Econst%20uint8_t%20host_userid_value%5B%5D%20%3D%20MandateSCP_UserID_VALUE%3B%3C%2FDIV%3E%3CDIV%3Econst%20uint8_t%20userid_value_factoryreset%5B%5D%20%3D%20MandateSCP_UserID_VALUE%3B%3C%2FDIV%3E%3CDIV%3EeraseAuthCtx.auth.ctx.idobj.pObj%20%3D%20%26amp%3Bex_id%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Econst%20char%20*portName%20%3D%20NULL%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Ememset(%26amp%3Bgex_sss_mandate_scp_boot_ctx%2C%200%2C%20sizeof(gex_sss_mandate_scp_boot_ctx))%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%20%2F*%20SE050%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FDIV%3E%3CDIV%3E%2F%2F%20status%20%3D%20ex_sss_boot_open(%26amp%3Bgex_sss_mandate_scp_boot_ctx%2C%20portName)%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%20if%20(kStatus_SSS_Success%20!%3D%20status)%3C%2FDIV%3E%3CDIV%3E%2F%2F%3C%2FDIV%3E%3CDIV%3E%2F%2F%20ex_sss_session_close(%26amp%3Bgex_sss_mandate_scp_boot_ctx)%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%2F*%20SE050%20%E3%81%A7%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FDIV%3E%3CDIV%3E%2F%2F%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%20%2F*%20%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%88%E3%82%A2%E3%81%AE%E8%A8%AD%E5%AE%9A%20*%2F%3C%2FDIV%3E%3CDIV%3E%2F%2F%20status%20%3D%20ex_sss_key_store_and_object_init(%26amp%3Bgex_sss_mandate_scp_boot_ctx)%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%20if%20(kStatus_SSS_Success%20!%3D%20status)%3C%2FDIV%3E%3CDIV%3E%2F%2F%3C%2FDIV%3E%3CDIV%3E%2F%2F%20ex_sss_session_close(%26amp%3Bgex_sss_mandate_scp_boot_ctx)%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%92%E8%BF%94%E3%81%99%E3%80%82%2F*%20%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%89%E3%81%98%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E8%BF%94%E3%81%99%20*%2F%3C%2FDIV%3E%3CDIV%3E%2F%2F%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%20ex_sss_boot_open_host_session(%26amp%3Bgex_sss_mandate_scp_boot_ctx)%3B%3C%2FDIV%3E%3CDIV%3E%2F*%20%E3%83%9B%E3%82%B9%E3%83%88%E3%82%92%E6%BA%96%E5%82%99%E3%81%99%E3%82%8B%20*%2F%3C%2FDIV%3E%3CDIV%3Estatus%20%3D%20sss_key_object_init(eraseAuthCtx.auth.ctx.idobj.pObj%2C%26amp%3Bgex_sss_mandate_scp_boot_ctx.host_ks)%3B%3C%2FDIV%3E%3CDIV%3Eif%20(kStatus_SSS_Success%20!%3D%20status)%20%7B%3C%2FDIV%3E%3CDIV%3ELOG_E(%22sss_key_object_init%20%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%22)%3B%3C%2FDIV%3E%3CDIV%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%B8%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3Estatus%20%3D%20sss_key_object_allocate_handle(eraseAuthCtx.auth.ctx.idobj.pObj%2C%3C%2FDIV%3E%3CDIV%3EMAKE_TEST_ID(%20__LINE__%20)%2C%3C%2FDIV%3E%3CDIV%3EkSSS_KeyPart_Default%E3%80%81%3C%2FDIV%3E%3CDIV%3EkSSS_%E6%9A%97%E5%8F%B7%E3%82%BF%E3%82%A4%E3%83%97_%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BCID%E3%80%81%3C%2FDIV%3E%3CDIV%3Esizeof(host_userid_value)%E3%80%81%3C%2FDIV%3E%3CDIV%3EkKeyObject_Mode_Transient)%3B%3C%2FDIV%3E%3CDIV%3Eif%20(kStatus_SSS_Success%20!%3D%20status)%20%7B%3C%2FDIV%3E%3CDIV%3ELOG_E(%22sss_key_object_allocate_handle%20%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%22)%3B%3C%2FDIV%3E%3CDIV%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%B8%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3Estatus%20%3D%20sss_key_store_set_key(%26amp%3Bgex_sss_mandate_scp_boot_ctx.host_ks%2C%3C%2FDIV%3E%3CDIV%3EeraseAuthCtx.auth.ctx.idobj.pObj%E3%80%81%3C%2FDIV%3E%3CDIV%3Ehost_userid_value%E3%80%81%3C%2FDIV%3E%3CDIV%3Esizeof(host_userid_value)%E3%80%81%3C%2FDIV%3E%3CDIV%3Esizeof(host_userid_value)%20*%208%E3%80%81%3C%2FDIV%3E%3CDIV%3ENULL%E3%80%81%3C%2FDIV%3E%3CDIV%3E0)%3B%3C%2FDIV%3E%3CDIV%3Eif%20(kStatus_SSS_Success%20!%3D%20status)%20%7B%3C%2FDIV%3E%3CDIV%3ELOG_E(%22sss_key_store_set_key%20%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%22)%3B%3C%2FDIV%3E%3CDIV%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%B8%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EpSe05xSession%20%3D%20%26amp%3BpSession-%26gt%3Bs_ctx%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Esw_status%20%3D%20Se05x_API_WriteUserID(pSe05xSession%2C%3C%2FDIV%3E%3CDIV%3ENULL%E3%80%81%3C%2FDIV%3E%3CDIV%3ESE05x_MaxAttemps_NA%E3%80%81%3C%2FDIV%3E%3CDIV%3EkSE05x_AppletResID_PLATFORM_SCP%E3%80%81%3C%2FDIV%3E%3CDIV%3Euserid_value_factoryreset%E3%80%81%3C%2FDIV%3E%3CDIV%3Esizeof(userid_value_factoryreset)%3C%2FDIV%3E%3CDIV%3EkSE05x_AttestationType_AUTH)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EpOpenCtx%20%3D%20%26amp%3Bgex_sss_mandate_scp_boot_ctx.se05x_open_ctx%3B%3C%2FDIV%3E%3CDIV%3EeraseAuthCtx.tunnelCtx%20%3D%20pOpenCtx-%26gt%3BtunnelCtx%3B%3C%2FDIV%3E%3CDIV%3EeraseAuthCtx.connType%20%3D%20pOpenCtx-%26gt%3BconnType%3B%3C%2FDIV%3E%3CDIV%3EeraseAuthCtx.portName%20%3D%20pOpenCtx-%26gt%3BportName%3B%3C%2FDIV%3E%3CDIV%3EeraseAuthCtx.auth.authType%20%3D%20kSSS_AuthType_ID%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Esss_session_close(%26amp%3Bgex_sss_mandate_scp_boot_ctx.session)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EpSe05xSession%20%3D%20%26amp%3BpSession-%26gt%3Bs_ctx%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Estatus%20%3D%20sss_session_open(%26amp%3Bgex_sss_mandate_scp_boot_ctx.session%2CkType_SSS_SE_SE05x%E3%80%81%3C%2FDIV%3E%3CDIV%3EkSE05x_AppletResID_PLATFORM_SCP%E3%80%81%3C%2FDIV%3E%3CDIV%3EkSSS_ConnectionType_Password%E3%80%81%26amp%3BeraseAuthCtx)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eif%20(kStatus_SSS_Success%20!%3D%20status)%20%7B%3C%2FDIV%3E%3CDIV%3ELOG_E(%22sss_session_open%20%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%22)%3B%3C%2FDIV%3E%3CDIV%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%B8%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F*%20SE05X%20API%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%A6%E3%80%81%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20SCP%20%E3%82%92%E5%BC%B7%E5%88%B6%E3%81%97%E3%81%BE%E3%81%99%E3%80%82*%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Esw_status%20%3D%20Se05x_API_SetPlatformSCPRequest(%26amp%3BpSession-%26gt%3Bs_ctx%2C%20kSE05x_PlatformSCPRequest_REQUIRED)%3B%3C%2FDIV%3E%3CDIV%3Eif(SM_OK%20!%3D%20sw_status)%20%7B%3C%2FDIV%3E%3CDIV%3ELOG_E(%22Se05x_API_SetPlatformSCPRequest%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%22)%3B%3C%2FDIV%3E%3CDIV%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%B8%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%20%7B%3C%2FDIV%3E%3CDIV%3ELOG_I(%22Se05x_API_SetPlatformSCPRequest%20%E6%88%90%E5%8A%9F%22)%3B%3C%2FDIV%3E%3CDIV%3ELOG_W(%22%E4%BB%A5%E9%99%8D%E3%81%AE%E9%80%9A%E4%BF%A1%E3%81%AF%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%22)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E6%8E%83%E9%99%A4%EF%BC%9A%3C%2FDIV%3E%3CDIV%3Eif%20(kStatus_SSS_Success%20%3D%3D%20status)%20%7B%3C%2FDIV%3E%3CDIV%3ELOG_I(%22se05x_MandatePlatformSCP%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E6%88%90%E5%8A%9F!!!...%22)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%20%7B%3C%2FDIV%3E%3CDIV%3ELOG_E(%22se05x_MandatePlatformSCP%20%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F!!!...%22)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%BA%E3%82%AA%E3%83%B3%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2372675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20enable%20Platform%20SCP%20when%20using%20SE050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2372675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252826%22%20target%3D%22_blank%22%3E%40yang_lee%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%AC%AC6%E7%AB%A0%E3%81%A7%E7%B4%B9%E4%BB%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E4%BE%8B%E3%81%AFSE050E%E5%B0%82%E7%94%A8%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%BE%E3%81%9A%E3%81%AF%E3%81%94%E8%87%AA%E8%BA%AB%E3%81%8C%E3%81%A9%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E1.MCUXpresso%20SDK%20%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%816.2%20%E3%81%8A%E3%82%88%E3%81%B3%206.3%20%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E2.%20CMake%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%816.4%E3%81%8A%E3%82%88%E3%81%B36.5%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-%20%E6%9C%80%E5%BE%8C%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93%E3%81%AFThread%E3%82%92%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BE%8C%E6%97%A5%E3%80%81%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E9%96%89%E3%81%98%E3%82%89%E3%82%8C%E3%81%9F%20Thread%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
