I'm trying to connect the Azure IoT Hub to my Android system which includes NXP Se050E over I2C.
I already succeeded to run the demo with ex_sss_ecc.c file and sign using the NXP HSM.
Now I want to do the IoT HUB part.
According to your great tutorial, I need to create the certificate by the following commands:
a. Send > ssscli connect se050 t1oi2c 0.
b. Send > ssscli get cert 0xF0000101 ./device_cert.cer.
c. Send > ssscli refpem ecc pair 0xF0000100 ./reference_key.pem.
d. Send > ssscli disconnect.
Since I saw all the examples of the ssscli using python scripts, I didn't find a good way to run it on Android environment.
Is there an alternative ssscli tool, dedicated to c++ code?
If not, is there an example of how can I generate the certificate and the key by the c++ sss api?
Thanks!
已解决! 转到解答。
Hi @nehadad ,
Yes, we provide another demo to fetch the cert in "simw-top\demos\se05x\se05x_GetCertificate", as well as a tool to create ref key file in "simw-top\demos\se05x\seTool", you may refer to "simw-top/doc/demos/se05x/seTool/Readme.html" for more details.
Hope that helps,
Kan
Hi @nehadad ,
Hope that helps,
Kan
