TJA1462 ASIL rated
TJA1462 ASIL rated
B_Walid
TJA1462 is not ASIL certified.
What can you suggest to make it ASIL-B ?
antoinedubois
what would be your safety requirement allocated to it ?
CAN transceiver failure are usually covered by E2E protection at application level.
Antoine
B_Walid
Safety requirement allocate to it is to not loose CAN communication.
Do you have functional safety document about FIT rate ?
antoinedubois
Antoine
