S32Z RTU0 core0 performance issue
2,386件の閲覧回数
DirkEtzler
I am running some test code on S32Z270 RTU0 core 0 (R52) with RTU0_CORE_CLK set to 1GHz where the execution time seems to too long.  In comparison I am running the same code on SS32K388 core 0 (CM7) with core clock set 320MHz.  Given the clock frequency increase I would have expected some faster execution but instead the execution time is longer.
Build/compilation flags are held identical for both binaries (see attached txt file buildinfo.h)
(1) Since the clock configuration in the S32 Configuration Tool is kind of sophisticated for the S32Z how can I make sure the RTU0 core 0 clock frequency is 1GHz as intended?
I have routed out the RTU0_CORE_DIV2_CLK via MC_CGM_3_MUX4_CSC (e.g., SEL_CTL = 0x3D) to CLKOUT_4 (PAD_040 of BGA594) including a divider of 10 in MC_CGM_3_MUX4_DC_0 (e.g., DIV = 0x9).  See also attached register readings.  If I measure 50MHz at CLKOUT_4, can I presume that (a) RTU0_CORE_DIV2_CLK is 500MHz and (b) RTU0_CORE_CLK is 1GHz?
CLOCKOUT4_Measurements_RTU0_CORE_DIV2_CLK_50MHz.pngCLOCKOUT4_Measurements_RTU0_CORE_DIV2_CLK_50MHz.png
(2) I have measured the execution time of pin writes to GPIO using S32Z RTD2.0.1 and measuring high/low times of scope channel CH5 - TESTFLAG which is roughly 3.4us. Is there the possibility that you could confirm whether they seem to be alright or too slow?
(3) I am not sure what I am missing.
タグ(3)
9 返答(返信)
2,252件の閲覧回数
Joey_z
Hi,DirkEtzler
Sorry for the reply late.
(1) I have routed out the RTU0_CORE_DIV2_CLK via MC_CGM_3_MUX4_CSC (e.g., SEL_CTL = 0x3D) to CLKOUT_4 (PAD_040 of BGA594) including a divider of 10 in MC_CGM_3_MUX4_DC_0 (e.g., DIV = 0x9). See also attached register readings. If I measure 50MHz at CLKOUT_4, can I presume that (a) RTU0_CORE_DIV2_CLK is 500MHz and (b) RTU0_CORE_CLK is 1GHz?
>>>About this question, the number 7 is assigned to RTU0_CORE_DIV2_CLK, you also should program GPR3.CLKOUT4SE to set this value. Could you try to confirm if you have set this register?
Joey
1,924件の閲覧回数
DirkEtzler
Hello @Joey_z,
I am not sure my previous message went through and was recognized as a reply.  I have checked GPR3.CLKOUT4SEL[MUXSEL] is set to 0x7 and thus, routing RTU0_CORE_DIV2_CLK through the multiplexer.  Using the described configuration and seeing 50MHz at the output pin, I presume the RTU0 core is clocked with 1GHz.
If the core frequency is set to 1GHz and I still do not see the expected performance (e.g., using CoreMark testbench) what else could be incorrect configured?  How can I check if the cache is configured correctly?  I have been looking through the assembler startup script and also the used linker script and cannot find anything that looks suspicious.
タグ(3)
1,869件の閲覧回数
Joey_z
Hi,DirkEtzler
Thank you for your reply and detail information.
You can try to refer to the chapter 3,4 of AN14245 to check the cache configuration. Cache mechanisms help enhance the memory performance. You can download it as the following picture.
In addition, the GPIO turn over to the time of measurement, mainly reflects the "delay" access path of the peripheral, but there will be a deviation of CPU core computing performance. Also, have the contents of CoreMark in this application, you can as references for your testing.
Joey
1,636件の閲覧回数
DirkEtzler
Hello @Joey_z,
Thank you-I will review chapters 3 and 4 of the mentioned application note (AN14245 S32ZE Safe and Secure High-Performance Real-Time Processors) with respect to the correct setup of the caches.
As a side note, the obtained CoreMark scores are too low-that is the reason for the support case in the first place.
タグ(3)
2,103件の閲覧回数
DirkEtzler
Hello @Joey_z
With respect to this question:
I have checked register settings for GPR3.CLKOUT4SEL[MUXSEL] which is set to 7 to select RTU0_CORE_DIV2_CLK in the corresponding multiplexer.
タグ(3)
2,340件の閲覧回数
Joey_z
Hi,DirkEtzler
Thank you for contacting us.
1.Do you use the development board or customer board?
2. Are you using the IDE of S32DS? What is the version of IDE for you testing?
3. Could you share your testing code with me?
Joey
2,333件の閲覧回数
DirkEtzler
Hello @Joey_z,
thanks for the quick reply.  Please see below my answers to the questions:
1) I am using a combination of the S32Z2XX motherboard + S32Z2XX daughterboard.
    a) S32ZXX motherboard X-S32X-MB version A
    b) S32ZXX daughterboard SCH-50588 REV B2 / 700-50588 REV A2
2) Code is compiled and linked using S32DS Version 3.6.7 Build 260420.  There is no change when using previous releases of the S32DS such as Version 3.6.6 or 3.6.5.  I am using RTD2.0.1 for S32Z2XX.
3) I will send a copy of the project using DM.
タグ(3)
2,281件の閲覧回数
Joey_z
Hi,DirkEtzler
I will help you to check it and reply to you late.
Joey
2,332件の閲覧回数
DirkEtzler
Attached is also a photo of the package markings.
Scan from 2026-04-27 09_28_21 AM.jpgScan from 2026-04-27 09_28_21 AM.jpg0
タグ(3)
%3CLINGO-SUB%20id%3D%22lingo-sub-2356091%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32Z%20RTU0%20core0%20%E3%81%AE%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2356091%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ES32Z270%20RTU0%20%E3%82%B3%E3%82%A2%200%20(R52)%20%E4%B8%8A%E3%81%A7%E3%80%81RTU0_CORE_CLK%20%E3%82%92%201GHz%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%83%86%E3%82%B9%E3%83%88%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%AE%9F%E8%A1%8C%E6%99%82%E9%96%93%E3%81%8C%E9%95%B7%E3%81%99%E3%81%8E%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E6%AF%94%E8%BC%83%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E5%90%8C%E3%81%98%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92SS32K388%E3%82%B3%E3%82%A20%EF%BC%88CM7%EF%BC%89%E4%B8%8A%E3%81%A7%E3%80%81%E3%82%B3%E3%82%A2%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92320MHz%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AE%E4%B8%8A%E6%98%87%E3%82%92%E8%80%83%E3%81%88%E3%82%8B%E3%81%A8%E3%80%81%E5%AE%9F%E8%A1%8C%E9%80%9F%E5%BA%A6%E3%81%8C%E9%80%9F%E3%81%8F%E3%81%AA%E3%82%8B%E3%81%A8%E4%BA%88%E6%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%8C%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E5%AE%9F%E8%A1%8C%E6%99%82%E9%96%93%E3%81%8C%E9%95%B7%E3%81%8F%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%2F%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%83%95%E3%83%A9%E3%82%B0%E3%81%AF%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%A7%E5%90%8C%E4%B8%80%E3%81%A7%E3%81%99%EF%BC%88%E6%B7%BB%E4%BB%98%E3%81%AEtxt%E3%83%95%E3%82%A1%E3%82%A4%E3%83%ABbuildinfo.h%E3%82%92%E5%8F%82%E7%85%A7%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%EF%BC%88%EF%BC%91%EF%BC%89S32%E6%A7%8B%E6%88%90%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E8%A8%AD%E5%AE%9A%E3%81%AFS32Z%E3%81%A7%E3%81%AF%E3%81%8B%E3%81%AA%E3%82%8A%E8%A4%87%E9%9B%91%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81RTU0%E3%82%B3%E3%82%A20%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%8C%E6%84%8F%E5%9B%B3%E3%81%A9%E3%81%8A%E3%82%8A1GHz%E3%81%AB%E3%81%AA%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3ERTU0_CORE_DIV2_CLK%E3%82%92MC_CGM_3_MUX4_CSC%EF%BC%88%E4%BE%8B%EF%BC%9ASEL_CTL%20%3D%200x3D%EF%BC%89%E7%B5%8C%E7%94%B1%E3%81%A7CLKOUT_4%EF%BC%88BGA594%E3%81%AEPAD_040%EF%BC%89%E3%81%AB%E9%85%8D%E7%B7%9A%E3%81%97%E3%80%81MC_CGM_3_MUX4_DC_0%E3%81%AB10%E3%81%AE%E5%88%86%E5%91%A8%E5%99%A8%EF%BC%88%E4%BE%8B%EF%BC%9ADIV%20%3D%200x9%EF%BC%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%B7%BB%E4%BB%98%E3%81%AE%E8%A8%98%E9%8C%B2%E7%B0%BF%E3%82%82%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82CLKOUT_4%E3%81%A750MHz%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81(a)%20RTU0_CORE_DIV2_CLK%E3%81%AF500MHz%E3%80%81(b)%20RTU0_CORE_CLK%E3%81%AF1GHz%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E6%8E%A8%E6%B8%AC%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CGM_3_MUX_4_Register_Configuration.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CGM_3_MUX_4_Register_Configuration.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CGM_3_MUX_4_Register_Configuration.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CGM_3_MUX_4_Register_Configuration.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CGM_3_MUX_4_Register_Configuration.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CGM_3_MUX_4_Register_Configuration.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CGM_3_MUX_4_Register_Configuration.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CGM_3_MUX_4_Register_Configuration.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383545i36C238F396D827E8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CGM_3_MUX_4_Register_Configuration.png%22%20alt%3D%22CGM_3_MUX_4_Register_Configuration.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECGM_3_MUX_4_Register_Configuration.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CLOCKOUT4_Measurements_RTU0_CORE_DIV2_CLK_50MHz.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CLOCKOUT4_Measurements_RTU0_CORE_DIV2_CLK_50MHz.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CLOCKOUT4_Measurements_RTU0_CORE_DIV2_CLK_50MHz.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CLOCKOUT4_Measurements_RTU0_CORE_DIV2_CLK_50MHz.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CLOCKOUT4_Measurements_RTU0_CORE_DIV2_CLK_50MHz.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CLOCKOUT4_Measurements_RTU0_CORE_DIV2_CLK_50MHz.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CLOCKOUT4_Measurements_RTU0_CORE_DIV2_CLK_50MHz.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CLOCKOUT4_Measurements_RTU0_CORE_DIV2_CLK_50MHz.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383548iC98078EC49FA7E3B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CLOCKOUT4_Measurements_RTU0_CORE_DIV2_CLK_50MHz.png%22%20alt%3D%22CLOCKOUT4_Measurements_RTU0_CORE_DIV2_CLK_50MHz.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECLOCKOUT4_Measurements_RTU0_CORE_DIV2_CLK_50MHz.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%EF%BC%88%EF%BC%92%EF%BC%89S32Z%20RTD2.0.1%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6GPIO%E3%81%B8%E3%81%AE%E3%83%94%E3%83%B3%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%AE%E5%AE%9F%E8%A1%8C%E6%99%82%E9%96%93%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%82%AA%E3%82%B7%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%83%81%E3%83%A3%E3%83%8D%E3%83%ABCH5%20-%20TESTFLAG%E3%81%AE%E3%83%8F%E3%82%A4%2F%E3%83%AD%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%A0%E3%81%AF%E7%B4%843.4%CE%BCs%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E5%BD%BC%E3%82%89%E3%81%AE%E5%8B%95%E3%81%8D%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E9%81%85%E3%81%99%E3%81%8E%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202026-04-25%20123853.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-25%20123853.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-25%20123853.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-25%20123853.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-25%20123853.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-25%20123853.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-25%20123853.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-25%20123853.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383551i953CE096312FD10E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%202026-04-25%20123853.png%22%20alt%3D%22Screenshot%202026-04-25%20123853.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%202026-04-25%20123853.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Setting_GPIO_Low_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_Low_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_Low_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_Low_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_Low_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_Low_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_Low_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_Low_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383549i34C2E01D659469F5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Setting_GPIO_Low_3.4us.png%22%20alt%3D%22Setting_GPIO_Low_3.4us.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESetting_GPIO_Low_3.4us.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Setting_GPIO_High_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_High_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_High_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_High_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_High_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_High_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_High_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Setting_GPIO_High_3.4us.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383550i91DC76C42E27B98D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Setting_GPIO_High_3.4us.png%22%20alt%3D%22Setting_GPIO_High_3.4us.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESetting_GPIO_High_3.4us.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%EF%BC%88%EF%BC%93%EF%BC%89%E4%BD%95%E3%81%8C%E8%B6%B3%E3%82%8A%E3%81%AA%E3%81%84%E3%81%AE%E3%81%8B%E3%82%88%E3%81%8F%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2356609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32Z%20RTU0%20core0%20performance%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2356609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AE%E8%A1%A8%E7%A4%BA%E5%86%99%E7%9C%9F%E3%82%82%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Scan%20from%202026-04-27%2009_28_21%20AM.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Scan%20from%202026-04-27%2009_28_21%20AM.jpg%22%20style%3D%22width%3A%20279px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Scan%20from%202026-04-27%2009_28_21%20AM.jpg%22%20style%3D%22width%3A%20279px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Scan%20from%202026-04-27%2009_28_21%20AM.jpg%22%20style%3D%22width%3A%20279px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Scan%20from%202026-04-27%2009_28_21%20AM.jpg%22%20style%3D%22width%3A%20279px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Scan%20from%202026-04-27%2009_28_21%20AM.jpg%22%20style%3D%22width%3A%20279px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Scan%20from%202026-04-27%2009_28_21%20AM.jpg%22%20style%3D%22width%3A%20279px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Scan%20from%202026-04-27%2009_28_21%20AM.jpg%22%20style%3D%22width%3A%20279px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383703i21FECFF5B6C92395%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Scan%20from%202026-04-27%2009_28_21%20AM.jpg%22%20alt%3D%22Scan%20from%202026-04-27%2009_28_21%20AM.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScan%20from%202026-04-27%2009_28_21%20AM.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%200%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2356604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32Z%20RTU0%20core0%20performance%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2356604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F236188%22%20target%3D%22_blank%22%3E%40Joey_z%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E8%BF%85%E9%80%9F%E3%81%AA%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AB%E3%80%81%E3%81%94%E8%B3%AA%E5%95%8F%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E7%A7%81%E3%81%AE%E5%9B%9E%E7%AD%94%E3%82%92%E8%A8%98%E8%BC%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1)%20%E7%A7%81%E3%81%AFS32Z2XX%E3%83%9E%E3%82%B6%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8S32Z2XX%E3%83%89%E3%83%BC%E3%82%BF%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Ea)%20S32ZXX%E3%83%9E%E3%82%B6%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%20X-S32X-MB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3A%3CBR%20%2F%3E%20b)%20S32ZXX%E3%83%89%E3%83%BC%E3%82%BF%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%20SCH-50588%20REV%20B2%20%2F%20700-50588%20REV%20A2%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22S32Z2XX_Complete_Setup.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Complete_Setup.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Complete_Setup.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Complete_Setup.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Complete_Setup.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Complete_Setup.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Complete_Setup.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Complete_Setup.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383695iF5820893A0717FB2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22S32Z2XX_Complete_Setup.jpg%22%20alt%3D%22S32Z2XX_Complete_Setup.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32Z2XX_Complete_Setup.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22S32Z2XX_Motherboard_Tag.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Motherboard_Tag.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Motherboard_Tag.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Motherboard_Tag.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Motherboard_Tag.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Motherboard_Tag.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Motherboard_Tag.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Motherboard_Tag.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383696i67693169B9569321%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22S32Z2XX_Motherboard_Tag.jpg%22%20alt%3D%22S32Z2XX_Motherboard_Tag.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32Z2XX_Motherboard_Tag.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22S32Z2XX_Daughterboard_Tag.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Daughterboard_Tag.jpg%22%20style%3D%22width%3A%20311px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Daughterboard_Tag.jpg%22%20style%3D%22width%3A%20311px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Daughterboard_Tag.jpg%22%20style%3D%22width%3A%20311px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Daughterboard_Tag.jpg%22%20style%3D%22width%3A%20311px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Daughterboard_Tag.jpg%22%20style%3D%22width%3A%20311px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Daughterboard_Tag.jpg%22%20style%3D%22width%3A%20311px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32Z2XX_Daughterboard_Tag.jpg%22%20style%3D%22width%3A%20311px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383697i7DF2E8EEBDDCE198%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22S32Z2XX_Daughterboard_Tag.jpg%22%20alt%3D%22S32Z2XX_Daughterboard_Tag.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32Z2XX_Daughterboard_Tag.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E2)%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AFS32DS%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B33.6.7%E3%83%93%E3%83%AB%E3%83%89260420%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%8A%E3%82%88%E3%81%B3%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82S32DS%E3%81%AE%E4%BB%A5%E5%89%8D%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%EF%BC%88%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B33.6.6%E3%82%843.6.5%E3%81%AA%E3%81%A9%EF%BC%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E5%A4%89%E6%9B%B4%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%AFS32Z2XX%E3%81%ABRTD2.0.1%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202026-04-27%20092032.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092032.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092032.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092032.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092032.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092032.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092032.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092032.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383698iF5CBE97A41904962%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%202026-04-27%20092032.png%22%20alt%3D%22Screenshot%202026-04-27%20092032.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%202026-04-27%20092032.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202026-04-27%20092336.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092336.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092336.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092336.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092336.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092336.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092336.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202026-04-27%20092336.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383700i93421940C0E24948%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%202026-04-27%20092336.png%22%20alt%3D%22Screenshot%202026-04-27%20092336.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%202026-04-27%20092336.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E3)%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%E3%82%92DM%E3%81%A7%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2356207%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32Z%20RTU0%20core0%20performance%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2356207%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CSPAN%3EDirkEtzler%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E9%A1%A7%E5%AE%A2%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%81%A9%E3%81%A1%E3%82%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E2.%20S32DS%E3%81%AEIDE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8BIDE%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E3.%20%E3%83%86%E3%82%B9%E3%83%88%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%B8%E3%83%A7%E3%83%BC%E3%82%A4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2357714%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32Z%20RTU0%20core0%20performance%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2357714%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CSPAN%3EDirkEtzler%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%A8%E8%A9%B3%E7%B4%B0%E3%81%AA%E6%83%85%E5%A0%B1%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A2%BA%E8%AA%8D%E3%81%AE%E3%81%8A%E6%89%8B%E4%BC%9D%E3%81%84%E3%82%92%E3%81%95%E3%81%9B%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E5%BE%8C%E3%81%BB%E3%81%A9%E3%81%8A%E8%BF%94%E4%BA%8B%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%B8%E3%83%A7%E3%83%BC%E3%82%A4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2358201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32Z%20RTU0%20core0%20performance%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2358201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81DirkEtzler%3C%2FP%3E%0A%3CP%3E%E8%BF%94%E4%BF%A1%E3%81%8C%E9%81%85%E3%81%8F%E3%81%AA%E3%82%8A%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%EF%BC%88%EF%BC%91%EF%BC%89MC_CGM_3_MUX4_CSC%EF%BC%88%E4%BE%8B%EF%BC%9ASEL_CTL%20%3D%200x3D%EF%BC%89%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6RTU0_CORE_DIV2_CLK%E3%82%92CLKOUT_4%EF%BC%88BGA594%E3%81%AEPAD_040%EF%BC%89%E3%81%AB%E9%85%8D%E7%B7%9A%E3%81%97%E3%80%81MC_CGM_3_MUX4_DC_0%EF%BC%88%E4%BE%8B%EF%BC%9ADIV%20%3D%200x9%EF%BC%89%E3%81%AB10%E3%81%AE%E5%88%86%E5%91%A8%E5%99%A8%E3%82%92%E5%90%AB%E3%82%81%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%B7%BB%E4%BB%98%E3%81%AE%E8%A8%98%E9%8C%B2%E7%B0%BF%E3%82%82%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82CLKOUT_4%E3%81%A750MHz%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81(a)%20RTU0_CORE_DIV2_CLK%E3%81%AF500MHz%E3%80%81(b)%20RTU0_CORE_CLK%E3%81%AF1GHz%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E6%8E%A8%E6%B8%AC%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%26gt%3B%26gt%3B%26gt%3B%E3%81%93%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%A7%E3%81%99%E3%81%8C%E3%80%817%E3%81%A8%E3%81%84%E3%81%86%E6%95%B0%E5%AD%97%E3%81%AFRTU0_CORE_DIV2_CLK%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81GPR3.CLKOUT4SE%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%81%A6%E3%81%93%E3%81%AE%E5%80%A4%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_0-1777434680768.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1777434680768.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1777434680768.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1777434680768.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1777434680768.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1777434680768.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383922i342E3A6FCEE00F10%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_0-1777434680768.png%22%20alt%3D%22Joey_z_0-1777434680768.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_0-1777434680768.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%B8%E3%83%A7%E3%83%BC%E3%82%A4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2359660%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32Z%20RTU0%20core0%20performance%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2359660%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F236188%22%20target%3D%22_blank%22%3E%40Joey_z%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CEM%3E%26gt%3B%26gt%3B%26gt%3B%E3%81%93%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%A7%E3%81%99%E3%81%8C%E3%80%817%E3%81%A8%E3%81%84%E3%81%86%E6%95%B0%E5%AD%97%E3%81%AFRTU0_CORE_DIV2_CLK%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81GPR3.CLKOUT4SE%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%81%A6%E3%81%93%E3%81%AE%E5%80%A4%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FEM%3E%3C%2FP%3E%3CP%3EGPR3.CLKOUT4SEL%5BMUXSEL%5D%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E8%A8%AD%E5%AE%9A%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AC%E3%82%AF%E3%82%B5%E3%81%A7RTU0_CORE_DIV2_CLK%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB7%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2360478%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32Z%20RTU0%20core0%20performance%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2360478%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F236188%22%20target%3D%22_blank%22%3E%40Joey_z%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E5%85%88%E3%81%BB%E3%81%A9%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%80%81%E8%BF%94%E4%BF%A1%E3%81%A8%E3%81%97%E3%81%A6%E8%AA%8D%E8%AD%98%E3%81%95%E3%82%8C%E3%81%9F%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A2%BA%E4%BF%A1%E3%81%8C%E6%8C%81%E3%81%A6%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82GPR3.CLKOUT4SEL%5BMUXSEL%5D%E3%81%8C0x7%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%20%3CSPAN%3ERTU0_CORE_DIV2_CLK%E3%81%8C%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AC%E3%82%AF%E3%82%B5%E7%B5%8C%E7%94%B1%E3%81%A7%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E5%87%BA%E5%8A%9B%E3%83%94%E3%83%B3%E3%81%A750MHz%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81RTU0%E3%82%B3%E3%82%A2%E3%81%AF1GHz%E3%81%A7%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%8E%A8%E6%B8%AC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%B3%E3%82%A2%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%921GHz%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E6%9C%9F%E5%BE%85%E9%80%9A%E3%82%8A%E3%81%AE%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%EF%BC%88%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81CoreMark%E3%83%86%E3%82%B9%E3%83%88%E3%83%99%E3%83%B3%E3%83%81%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%EF%BC%89%E3%80%81%E4%BB%96%E3%81%AB%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E8%A8%AD%E5%AE%9A%E3%83%9F%E3%82%B9%E3%81%8C%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%A9%E3%81%AE%E8%B5%B7%E5%8B%95%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%A8%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%AA%E3%83%B3%E3%82%AB%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E8%AA%BF%E3%81%B9%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E7%96%91%E3%82%8F%E3%81%97%E3%81%84%E7%82%B9%E3%81%AF%E4%BD%95%E3%82%82%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2360805%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32Z%20RTU0%20core0%20performance%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2360805%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CSPAN%3EDirkEtzler%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%A8%E8%A9%B3%E7%B4%B0%E3%81%AA%E6%83%85%E5%A0%B1%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E6%A7%8B%E6%88%90%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81AN14245%E3%81%AE%E7%AC%AC3%E7%AB%A0%E3%81%A8%E7%AC%AC4%E7%AB%A0%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E6%A9%9F%E6%A7%8B%E3%81%AF%E3%83%A1%E3%83%A2%E3%83%AA%E6%80%A7%E8%83%BD%E3%81%AE%E5%90%91%E4%B8%8A%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_0-1778036409619.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1778036409619.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1778036409619.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384427i4E75224FF4928D02%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_0-1778036409619.png%22%20alt%3D%22Joey_z_0-1778036409619.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_0-1778036409619.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%95%E3%82%89%E3%81%AB%E3%80%81GPIO%E3%81%AE%E3%82%BF%E3%83%BC%E3%83%B3%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AF%E6%B8%AC%E5%AE%9A%E6%99%82%E3%81%AB%E4%B8%BB%E3%81%AB%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%83%91%E3%82%B9%E3%81%AE%E3%80%8C%E9%81%85%E5%BB%B6%E3%80%8D%E3%82%92%E5%8F%8D%E6%98%A0%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81CPU%E3%82%B3%E3%82%A2%E3%81%AE%E6%BC%94%E7%AE%97%E6%80%A7%E8%83%BD%E3%81%AB%E3%81%9A%E3%82%8C%E3%81%8C%E7%94%9F%E3%81%98%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%81%93%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%AFCoreMark%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E3%81%AE%E9%9A%9B%E3%81%AE%E5%8F%82%E8%80%83%E8%B3%87%E6%96%99%E3%81%A8%E3%81%97%E3%81%A6%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%B8%E3%83%A7%E3%83%BC%E3%82%A4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2363445%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32Z%20RTU0%20core0%20performance%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2363445%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F236188%22%20target%3D%22_blank%22%3E%40Joey_z%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%94%E6%8C%87%E6%91%98%E3%81%84%E3%81%9F%E3%81%A0%E3%81%84%E3%81%9F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%EF%BC%88AN14245%20S32ZE%20%E5%AE%89%E5%85%A8%E3%81%A7%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%81%AA%E9%AB%98%E6%80%A7%E8%83%BD%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%EF%BC%89%E3%81%AE%E7%AC%AC3%E7%AB%A0%E3%81%A8%E7%AC%AC4%E7%AB%A0%E3%82%92%E3%80%81%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E6%AD%A3%E3%81%97%E3%81%84%E8%A8%AD%E5%AE%9A%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E7%A2%BA%E8%AA%8D%E3%81%95%E3%81%9B%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A1%E3%81%AA%E3%81%BF%E3%81%AB%E3%80%81%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9FCoreMark%E3%82%B9%E3%82%B3%E3%82%A2%E3%81%8C%E4%BD%8E%E3%81%99%E3%81%8E%E3%82%8B%E3%81%AE%E3%81%8C%E3%80%81%E3%81%9D%E3%82%82%E3%81%9D%E3%82%82%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88CASE%E3%82%92%E4%BE%9D%E9%A0%BC%E3%81%97%E3%81%9F%E7%90%86%E7%94%B1%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
