S32E2 IPCF latency timings between M33 and R52
PrabhanjanKopp
I am working with S32E2 and configuring the IPCF framework and here is my setup
  • Device: S32E288
  • IPCF transport: Shared Memory + MRU notification
  • Communication: M33 ↔ R52
  • IPCF channel type: Managed channel
  • 1 IPCF channel configured
  • Interrupt mode (not polling)
  • Ping/Pong RTT test implemented
Communication is functioning correctly in both directions.
I use STM to measure the timing ticks between the 2 cores.
Measurement flow:
R52:
timestamp
send PING
M33:
receive PING
immediately send PONG from RX callback
R52:
receive PONG
compute RTT
The values computed for a STM running on 24Mhz are close to 200us RTT(Round trip time). My transport overhead is about 30us but the transfer itself takes up bulk of the time. I have tried various things like increasing MRU IRQ notification but has not improved the timings. Having optimisation in code from -o0 to -o1 helped but -o2 didnt make any difference. The payload itself is 16 bytes.
Questions:
1. what is expected IPCF latency for managed /unmanaged channels.
2. can we acheive a low double digit latency?
If you need any more details, please reply back.
Joey_z
Hi,PrabhanjanKopp
Thank you for contacting us.
For your testing scenario, you can try to refer to GreenVIP. The Loop Time is about 20-30us.(S32ZE_GreenVIP_1.x.1/doc/UG_S32ZE_GreenVIP.pdf)
If you have other issue, you can contact us at any time.
Joey
PrabhanjanKopp
Hi Joey,
Thank you for your reply. I am using S32 DS for setting up my cores and was wondering is GreenVIP is any different? Also , it will be most helpful to get the document link(or the doc itself)  that you referring in your message. Is there a reference project that I can compare my settings against? I suspect there might be some configuration mismatch.
Prabhanjan
Joey_z
Hi,Prabhanjan
The link of GreenVIP download as the following:
S32E2 Safe and Secure High-Performance Real-Time Processors with Actuation Support | NXP Semiconduct...
Automotive Software Package Manager | NXP Semiconductors
The EB tresos IDE is used for the GreenVIP, both S32DS and EB tresos can be used to develop applications for S32E. Hope this information can help you; you can contact us at any time if you still have question about this.
Joey
PrabhanjanKopp
Thank you for that. I found that I can get the timings down when I switch to unmanaged channel. It is close to 60us . Will see if I can get it further down.
Joey_z
Hi,PrabhanjanKopp
Thank you for your reply and information.
For the 60us result, was it tested by your customer program or by our Greenvip?
Joey
%3CLINGO-SUB%20id%3D%22lingo-sub-2413097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32E2%20IPCF%20latency%20timings%20between%20M33%20and%20R52%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2413097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20working%20with%20S32E2%20and%20configuring%20the%20IPCF%20framework%20and%20here%20is%20my%20setup%3C%2FP%3E%3CDIV%3E%3CUL%3E%3CLI%3EDevice%3A%20S32E288%3C%2FLI%3E%3CLI%3EIPCF%20transport%3A%20Shared%20Memory%20%2B%20MRU%20notification%3C%2FLI%3E%3CLI%3ECommunication%3A%20M33%20%E2%86%94%20R52%3C%2FLI%3E%3CLI%3EIPCF%20channel%20type%3A%20Managed%20channel%3C%2FLI%3E%3CLI%3E1%20IPCF%20channel%20configured%3C%2FLI%3E%3CLI%3EInterrupt%20mode%20(not%20polling)%3C%2FLI%3E%3CLI%3EPing%2FPong%20RTT%20test%20implemented%3C%2FLI%3E%3C%2FUL%3E%3CP%3ECommunication%20is%20functioning%20correctly%20in%20both%20directions.%3C%2FP%3E%3CP%3EI%20use%20STM%20to%20measure%20the%20timing%20ticks%20between%20the%202%20cores.%3C%2FP%3E%3CP%3EMeasurement%20flow%3A%3C%2FP%3E%3CDIV%3E%3CSPAN%3ER52%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Etimestamp%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Esend%20PING%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EM33%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereceive%20PING%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eimmediately%20send%20PONG%20from%20RX%20callback%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ER52%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereceive%20PONG%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecompute%20RTT%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CP%3EThe%20values%20computed%20for%20a%20STM%20running%20on%2024Mhz%20are%20close%20to%20200us%20RTT(Round%20trip%20time).%20My%20transport%20overhead%20is%20about%2030us%20but%20the%20transfer%20itself%20takes%20up%20bulk%20of%20the%20time.%20I%20have%20tried%20various%20things%20like%20increasing%20MRU%20IRQ%20notification%20but%20has%20not%20improved%20the%20timings.%20Having%20optimisation%20in%20code%20from%20-o0%20to%20-o1%20helped%20but%20-o2%20didnt%20make%20any%20difference.%20The%20payload%20itself%20is%2016%20bytes.%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3EQuestions%3A%3CBR%20%2F%3E1.%20what%20is%20expected%20IPCF%20latency%20for%20managed%20%2Funmanaged%20channels.%3C%2FP%3E%3CP%3E2.%20can%20we%20acheive%20a%20low%20double%20digit%20latency%3F%3C%2FP%3E%3CP%3EIf%20you%20need%20any%20more%20details%2C%20please%20reply%20back.%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2413280%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32E2%20IPCF%20latency%20timings%20between%20M33%20and%20R52%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2413280%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2CPrabhanjanKopp%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20contacting%20us.%3C%2FP%3E%0A%3CP%3EFor%20your%20testing%20scenario%2C%20you%20can%20try%20to%20refer%20to%20GreenVIP.%20The%20Loop%20Time%20is%20about%2020-30us.(S32ZE_GreenVIP_1.x.1%2Fdoc%2FUG_S32ZE_GreenVIP.pdf)%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_0-1789354232929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1789354232929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1789354232929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1789354232929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1789354232929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1789354232929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F396305iB585F26D7253BDB4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_0-1789354232929.png%22%20alt%3D%22Joey_z_0-1789354232929.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_0-1789354232929.png%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_0-1789354232929.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_0-1789354232929.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_0-1789354232929.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_0-1789354232929.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_0-1789354232929.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_1-1789354243644.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_1-1789354243644.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_1-1789354243644.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_1-1789354243644.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_1-1789354243644.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_1-1789354243644.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F396306iC75EA3F5EB2727A3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_1-1789354243644.png%22%20alt%3D%22Joey_z_1-1789354243644.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_1-1789354243644.png%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_1-1789354243644.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_1-1789354243644.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_1-1789354243644.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_1-1789354243644.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_1-1789354243644.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EIf%20you%20have%20other%20issue%2C%20you%20can%20contact%20us%20at%20any%20time.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EJoey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2413547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32E2%20IPCF%20latency%20timings%20between%20M33%20and%20R52%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2413547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Joey%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you%20for%20your%20reply.%20I%20am%20using%20S32%20DS%20for%20setting%20up%20my%20cores%20and%20was%20wondering%20is%20GreenVIP%20is%20any%20different%3F%20Also%20%2C%20it%20will%20be%20most%20helpful%20to%20get%20the%20document%20link(or%20the%20doc%20itself)%26nbsp%3B%20that%20you%20referring%20in%20your%20message.%20Is%20there%20a%20reference%20project%20that%20I%20can%20compare%20my%20settings%20against%3F%20I%20suspect%20there%20might%20be%20some%20configuration%20mismatch.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EPrabhanjan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2413567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32E2%20IPCF%20latency%20timings%20between%20M33%20and%20R52%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2413567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CSPAN%3EPrabhanjan%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20your%20reply.%3C%2FP%3E%0A%3CP%3EThe%20link%20of%20GreenVIP%20download%20as%20the%20following%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2FS32E2%3Fadobe_mc%3DTS%253D1789452470%257CMCMID%253D48028588193863623953736068729907749694%257CMCORGID%253D26D5971254C83D130A4C98A4%252540AdobeOrg%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ES32E2%20Safe%20and%20Secure%20High-Performance%20Real-Time%20Processors%20with%20Actuation%20Support%20%7C%20NXP%20Semiconductors%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fapp-autopackagemgr%2Fautomotive-software-package-manager%3AAUTO-SW-PACKAGE-MANAGER%3Fticket%3DST-1622-eZekaUSAnaamU7nlIITC9l1IhLk-nxp%26amp%3BcurrentTab%3D0%26amp%3BselectedDevices%3DS32Z2%252FE2%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EAutomotive%20Software%20Package%20Manager%20%7C%20NXP%20Semiconductors%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_0-1789452520972.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1789452520972.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1789452520972.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1789452520972.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F396379i438E6E2385FDDF29%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_0-1789452520972.png%22%20alt%3D%22Joey_z_0-1789452520972.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_0-1789452520972.png%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_0-1789452520972.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_0-1789452520972.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_0-1789452520972.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_1-1789452649226.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_1-1789452649226.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_1-1789452649226.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_1-1789452649226.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F396380i6A982831A4AF9DDE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_1-1789452649226.png%22%20alt%3D%22Joey_z_1-1789452649226.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_1-1789452649226.png%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_1-1789452649226.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_1-1789452649226.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_1-1789452649226.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThe%20EB%20tresos%20IDE%20is%20used%20for%20the%20GreenVIP%2C%20both%20S32DS%20and%20EB%20tresos%20can%20be%20used%20to%20develop%20applications%20for%20S32E.%20Hope%20this%20information%20can%20help%20you%3B%20you%20can%20contact%20us%20at%20any%20time%20if%20you%20still%20have%20question%20about%20this.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EJoey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2414747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32E2%20IPCF%20latency%20timings%20between%20M33%20and%20R52%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2414747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20for%20that.%20I%20found%20that%20I%20can%20get%20the%20timings%20down%20when%20I%20switch%20to%20unmanaged%20channel.%20It%20is%20close%20to%2060us%20.%20Will%20see%20if%20I%20can%20get%20it%20further%20down.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2414824%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32E2%20IPCF%20latency%20timings%20between%20M33%20and%20R52%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2414824%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CSPAN%3EPrabhanjanKopp%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20your%20reply%20and%20information.%3C%2FP%3E%0A%3CP%3EFor%20the%2060us%20result%2C%20was%20it%20tested%20by%20your%20customer%20program%20or%20by%20our%20Greenvip%3F%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EJoey%3C%2FP%3E%3C%2FLINGO-BODY%3E
