SPI with DMA implementation in LInux kernel for s32vxx
I am currently working on SPI with DMA for S32V234.
I have tested SPI code it is working fine. I am tested for SPI1 and chip select 0 and mode 3 it is working fine.
Now i have to implement SPI with DMA code.
Please see the below links i have taken as a reference for s32v234, I made little bit changes in that link source code.
http://lists.infradead.org/pipermail/linux-arm-kernel/2014-February/235598.html
https://www.toradex.com/community/questions/1961/vf61-linux-spi-dma-support.html
1. Can you please suggest which link is suitable for s32v234?
2. How to write dtsi for "spi with dma"? I wrote the below lines, when compiled it's getting error?
     spi1: spi@400C0000 {
                                compatible = "fsl,s32v234-dspi";
                                reg = <0x0 0x400C0000 0x0 0x1000>;
                                interrupts = <0 62 4>;
                                clocks = <&clks S32V234_CLK_SYS6>;
                                clock-names = "dspi";
                                spi-num-chipselects = <4>;
                                bus-num = <1>;
                                spi-cpol;
                                spi-cpha;
                                /* TODO: Update the dma when edma ip is activated*/
                                use-dma;
                                dmas =  <&edma 12>,
                                        <&edma 13>;
                                dma-names = "rx","tx";
                                status = "disabled";
ERROR (phandle_references): Reference to non-existent node or label "edma"
ERROR: Input tree has errors, aborting (use -f to force output)
scripts/Makefile.lib:293: recipe for target 'arch/arm64/boot/dts/freescale/s32v234-evb.dtb' failed
make[2]: *** [arch/arm64/boot/dts/freescale/s32v234-evb.dtb] Error 2
scripts/Makefile.build:403: recipe for target 'arch/arm64/boot/dts/freescale' failed
make[1]: *** [arch/arm64/boot/dts/freescale] Error 2
arch/arm64/Makefile:89: recipe for target 'dtbs' failed
make: *** [dtbs] Error 2
3. Please give do you have any reference code SPI with DMA for S32V234.
I am waiting for your reply.
Thanks & Regards,
Ramanjineyulu.
%3CLINGO-SUB%20id%3D%22lingo-sub-655900%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELinux%20%E5%86%85%E6%A0%B8%E4%B8%AD%E9%92%88%E5%AF%B9%20s32vxx%20%E7%9A%84%20SPI%20%E5%92%8C%20DMA%20%E5%AE%9E%E7%8E%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-655900%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%E4%B8%BA%20S32V234%20%E5%BC%80%E5%8F%91%E5%B8%A6%E6%9C%89%20DMA%20%E7%9A%84%20SPI%E3%80%82%3CBR%20%2F%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%B5%8B%E8%AF%95%E4%BA%86%20SPI%20%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%AE%83%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%E3%80%82%E6%88%91%E5%AF%B9%20SPI1%20%E5%92%8C%E8%8A%AF%E7%89%87%E9%80%89%E6%8B%A9%200%20%E5%92%8C%E6%A8%A1%E5%BC%8F%203%20%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%EF%BC%8C%E5%AE%83%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E6%88%91%E5%BF%85%E9%A1%BB%E7%94%A8%20DMA%20%E4%BB%A3%E7%A0%81%E5%AE%9E%E7%8E%B0%20SPI%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%8F%82%E9%98%85%E4%BB%A5%E4%B8%8B%E6%88%91%E4%BD%9C%E4%B8%BA%20s32v234%20%E5%8F%82%E8%80%83%E7%9A%84%E9%93%BE%E6%8E%A5%EF%BC%8C%E6%88%91%E5%AF%B9%E8%AF%A5%E9%93%BE%E6%8E%A5%E6%BA%90%E4%BB%A3%E7%A0%81%E5%81%9A%E4%BA%86%E4%B8%80%E4%BA%9B%E6%9B%B4%E6%94%B9%E3%80%82%3CBR%20%2F%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Flists.infradead.org%252Fpipermail%252Flinux-arm-kernel%252F2014-February%252F235598.html%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Flists.infradead.org%2Fpipermail%2Flinux-arm-kernel%2F2014-February%2F235598.html%3C%2FA%3E%3CBR%20%2F%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fwww.toradex.com%252Fcommunity%252Fquestions%252F1961%252Fvf61-linux-spi-dma-support.html%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.toradex.com%2Fcommunity%2Fquestions%2F1961%2Fvf61-linux-spi-dma-support.html%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%E6%82%A8%E8%83%BD%E5%90%A6%E5%BB%BA%E8%AE%AE%E5%93%AA%E4%B8%AA%E9%93%BE%E6%8E%A5%E9%80%82%E5%90%88s32v234%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.%E2%80%9Cspi%20with%20dma%E2%80%9D%E7%9A%84dtsi%E6%80%8E%E4%B9%88%E5%86%99%EF%BC%9F%E6%88%91%E5%86%99%E4%BA%86%E4%B8%8B%E9%9D%A2%E5%87%A0%E8%A1%8C%EF%BC%8C%E7%BC%96%E8%AF%91%E6%97%B6%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%EF%BC%9F%3CBR%20%2F%3Espi1%EF%BC%9Aspi%40400C0000%7B%3CBR%20%2F%3E%E5%85%BC%E5%AE%B9%3D%E2%80%9Cfsl%EF%BC%8Cs32v234-dspi%E2%80%9D%EF%BC%9B%3CBR%20%2F%3E%E5%AF%84%E5%AD%98%E5%99%A8%3D%26lt%3B0x0%200x400C0000%200x0%200x1000%26gt%3B%EF%BC%9B%3CBR%20%2F%3E%E4%B8%AD%E6%96%AD%20%3D%20%26lt%3B0%2062%204%26gt%3B%EF%BC%9B%3CBR%20%2F%3E%E6%97%B6%E9%92%9F%3D%26lt%3B%26amp%3Bclks%20S32V234_CLK_SYS6%26gt%3B%EF%BC%9B%3CBR%20%2F%3E%E6%97%B6%E9%92%9F%E5%90%8D%E7%A7%B0%3D%E2%80%9Cdspi%E2%80%9D%EF%BC%9B%3CBR%20%2F%3E%20spi%20%E6%95%B0%E9%87%8F%E8%8A%AF%E7%89%87%E9%80%89%E6%8B%A9%20%3D%20%26lt%3B4%26gt%3B%3B%3CBR%20%2F%3E%E6%80%BB%E7%BA%BF%E5%8F%B7%3D%26lt%3B1%26gt%3B%EF%BC%9B%3CBR%20%2F%3E%20spi-cpol%EF%BC%9B%3CBR%20%2F%3E%20spi-cpha%EF%BC%9B%3CBR%20%2F%3E%20%2F*%20TODO%3A%20%E5%BD%93%20edma%20ip%20%E6%BF%80%E6%B4%BB%E6%97%B6%E6%9B%B4%E6%96%B0%20dma%20*%2F%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%20DMA%EF%BC%9B%3CBR%20%2F%3E%20dmas%20%3D%20%26lt%3B%26amp%3Bedma%2012%26gt%3B%2C%3CBR%20%2F%3E%20%26lt%3B%26amp%3Bedma%2013%26gt%3B%3B%3CBR%20%2F%3E%20dma%E5%90%8D%E7%A7%B0%3D%E2%80%9Crx%E2%80%9D%EF%BC%8C%E2%80%9Ctx%E2%80%9D%EF%BC%9B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8A%B6%E6%80%81%3D%E2%80%9C%E5%B7%B2%E7%A6%81%E7%94%A8%E2%80%9D%EF%BC%9B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%88phandle_references%EF%BC%89%EF%BC%9A%E5%BC%95%E7%94%A8%E4%B8%8D%E5%AD%98%E5%9C%A8%E7%9A%84%E8%8A%82%E7%82%B9%E6%88%96%E6%A0%87%E7%AD%BE%E2%80%9Cedma%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%88phandle_references%EF%BC%89%EF%BC%9A%E5%BC%95%E7%94%A8%E4%B8%8D%E5%AD%98%E5%9C%A8%E7%9A%84%E8%8A%82%E7%82%B9%E6%88%96%E6%A0%87%E7%AD%BE%E2%80%9Cedma%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E8%BE%93%E5%85%A5%E6%A0%91%E6%9C%89%E9%94%99%E8%AF%AF%EF%BC%8C%E4%B8%AD%E6%AD%A2%EF%BC%88%E4%BD%BF%E7%94%A8-f%E5%BC%BA%E5%88%B6%E8%BE%93%E5%87%BA%EF%BC%89%3CBR%20%2F%3E%E8%84%9A%E6%9C%AC%2FMakefile.lib%3A293%EF%BC%9A%E7%9B%AE%E6%A0%87%E2%80%9Carch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32v234-evb.dtb%E2%80%9D%E7%9A%84%E9%85%8D%E6%96%B9%E5%A4%B1%E8%B4%A5%E7%9A%84%3CBR%20%2F%3E%E4%BD%BF%5B2%5D%EF%BC%9A***%20%5Barch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32v234-evb.dtb%5D%E9%94%99%E8%AF%AF%202%3CBR%20%2F%3E%E8%84%9A%E6%9C%AC%2FMakefile.build%3A403%EF%BC%9A%E7%9B%AE%E6%A0%87%E2%80%9Carch%2Farm64%2Fboot%2Fdts%2Ffreescale%E2%80%9D%E7%9A%84%E9%85%8D%E6%96%B9%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3Emake%5B1%5D%3A%20***%20%5Barch%2Farm64%2Fboot%2Fdts%2Ffreescale%5D%20%E9%94%99%E8%AF%AF%202%3CBR%20%2F%3E%20arch%2Farm64%2FMakefile%3A89%3A%20%E7%9B%AE%E6%A0%87%E2%80%98dtbs%E2%80%99%E7%9A%84%E9%85%8D%E6%96%B9%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3Emake%3A%20***%20%5Bdtbs%5D%20%E9%94%99%E8%AF%AF%202%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.%E8%AF%B7%E6%8F%90%E4%BE%9B%E4%B8%80%E4%B8%8BS32V234%E5%B8%A6%E6%9C%89DMA%E7%9A%84SPI%E5%8F%82%E8%80%83%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E7%AD%89%E5%BE%85%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E5%92%8C%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3E%E6%8B%89%E6%9B%BC%E5%90%89%E5%86%85%E4%B9%8C%E5%8D%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎10-20-2016 11:41 PM
更新人:
