errors with S32M24xEVB
558 次查看
Fero36
Junior Contributor I
I have tried example codes for this kit and the S32M24xEVB_BLDC_6Step_Sensorless is the only one working. What am I doing wrong? The hall gives theese errors (missing headers):
....Building file: ../generate/src/Dpga_Ip_BOARD_INITPERIPHERALS_PBcfg.c
C:/Users/nitro/workspaceS32DS.3.5_DP_V10/S32M24xEVB_BLDC_6Step_Hall/generate/include/Adc_Ip_BOARD_INITPERIPHERALS_PBcfg.h:44:10: fatal error: Adc_Ip_Types.h: No such file or directory
Building file: ../generate/src/Ftm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.c
44 | #include "Adc_Ip_Types.h"
compilation terminated.
../generate/src/Aec_Ip_Cfg.c:41:10: fatal error: Aec_Ip_Types.h: No such file or directory
Invoking: Standard S32DS C Compiler
41 | #include "Aec_Ip_Types.h"
make: *** [generate/src/subdir.mk:78: generate/src/Adc_Ip_BOARD_INITPERIPHERALS_PBcfg.o] Error 1
make: *** Waiting for unfinished jobs....
make: *** [generate/src/subdir.mk:78: generate/src/Aec_Ip_Cfg.o] Error 1
../generate/src/Aec_Ip_Sa_BOARD_INITPERIPHERALS_PBcfg.c:42:10: fatal error: Aec_Ip_Types.h: No such file or directory
Building file: ../generate/src/Ftm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.c
42 | #include "Aec_Ip_Types.h"
arm-none-eabi-gcc "@generate/src/Adc_Ip_BOARD_INITPERIPHERALS_PBcfg.args" -MMD -MP -MF"generate/src/Dpga_Ip_BOARD_INITPERIPHERALS_PBcfg.d" -MT"generate/src/Dpga_Ip_BOARD_INITPERIPHERALS_PBcfg.o" -o "generate/src/Dpga_Ip_BOARD_INITPERIPHERALS_PBcfg.o" "../generate/src/Dpga_Ip_BOARD_INITPERIPHERALS_PBcfg.c"
make: *** [generate/src/subdir.mk:79: generate/src/Aec_Ip_Sa_BOARD_INITPERIPHERALS_PBcfg.o] Error 1
arm-none-eabi-gcc "@generate/src/Adc_Ip_BOARD_INITPERIPHERALS_PBcfg.args" -MMD -MP -MF"generate/src/Ftm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.d" -MT"generate/src/Ftm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.o" -o "generate/src/Ftm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.o" "../generate/src/Ftm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.c"
In file included from ../generate/src/CDD_Gdu_BOARD_INITPERIPHERALS_PBcfg.c:43:
arm-none-eabi-gcc "@generate/src/Adc_Ip_BOARD_INITPERIPHERALS_PBcfg.args" -MMD -MP -MF"generate/src/Ftm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.d" -MT"generate/src/Ftm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.o" -o "generate/src/Ftm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.o" "../generate/src/Ftm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.c"
C:/Users/nitro/workspaceS32DS.3.5_DP_V10/S32M24xEVB_BLDC_6Step_Hall/generate/include/Gdu_Ip_BOARD_INITPERIPHERALS_PBcfg.h:46:10: fatal error: Gdu_Ip_Types.h: No such file or directory
46 | #include "Gdu_Ip_Types.h"
make: *** [generate/src/subdir.mk:80: generate/src/CDD_Gdu_BOARD_INITPERIPHERALS_PBcfg.o] Error 1
In file included from ../generate/src/Dpga_Ip_BOARD_INITPERIPHERALS_PBcfg.c:41:
C:/Users/nitro/workspaceS32DS.3.5_DP_V10/S32M24xEVB_BLDC_6Step_Hall/generate/include/Dpga_Ip_BOARD_INITPERIPHERALS_PBcfg.h:43:10: fatal error: Dpga_Ip_Types.h: No such file or directory
43 | #include "Dpga_Ip_Types.h"
make: *** [generate/src/subdir.mk:80: generate/src/Dpga_Ip_BOARD_INITPERIPHERALS_PBcfg.o] Error 1
In file included from C:/Users/nitro/workspaceS32DS.3.5_DP_V10/S32M24xEVB_BLDC_6Step_Hall/generate/include/Ftm_Pwm_Ip_Cfg.h:54,
from ../generate/src/Ftm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.c:41:
C:/Users/nitro/workspaceS32DS.3.5_DP_V10/S32M24xEVB_BLDC_6Step_Hall/generate/include/Ftm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.h:45:10: fatal error: Ftm_Pwm_Ip_Types.h: No such file or directory
45 | #include "Ftm_Pwm_Ip_Types.h"
In file included from ../generate/src/Ftm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.c:47:
C:/Users/nitro/workspaceS32DS.3.5_DP_V10/S32M24xEVB_BLDC_6Step_Hall/generate/include/Ftm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.h:46:10: fatal error: Ftm_Gpt_Ip_Types.h: No such file or directory
46 | #include "Ftm_Gpt_Ip_Types.h"
make: *** [generate/src/subdir.mk:80: generate/src/Ftm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.o] Error 1
make: *** [generate/src/subdir.mk:80: generate/src/Ftm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.o] Error 1
"make -j8 all" terminated with exit code 2. Build might be incomplete.
The PMSM_FOC is like incomplete:
-j8 all
Cannot run program "": Launching failed
Error: Program "" not found in PATH
1 回复
533 次查看
Robin_Shen
Did you click click on "Update Code" button for generating configuration files by refer to 4.2 Use Configuration Tool?
Did you install SW32K1_S32M24x_RTD_4.4_R21-11_2.0.0_D2308_DS_Updatesite.zip and SW32K1_S32M24x_RTD_R21-11_2.0.0_P04_D2404_DS_updatesite.zip by refer to 2. Get Software of S32M24X Board Setup Guides?
I am able to build the those three projects without error.
C:\NXP\MC_DevKits\S32M24xEVB\sw\S32M24xEVB_BLDC_6Step_Sensorless and S32M24xEVB_BLDC_6Step_Hall and S32M24xEVB_PMSM_FOC_1Sh
Did you download S32 Design Studio - Releases & Updates here?
And don't forget to install NXP GCC for Arm Embedded Processors v10.2 build 1728 by S32DS Extensions and Updates
Robin
- If this post answers your question, please click the "ACCEPT AS SOLUTION" button. Thank you!
%3CLINGO-SUB%20id%3D%22lingo-sub-2379659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32M24xEVB%20%E7%9A%84%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E8%AF%95%E8%BF%87%E8%AF%A5%E5%A5%97%E4%BB%B6%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%8F%AA%E6%9C%89%20S32M24xEVB_BLDC_6Step_Sensorless%20%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%E6%88%91%E5%81%9A%E9%94%99%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%9F%E5%A4%A7%E5%8E%85%E7%BB%99%E5%87%BA%E4%BA%86%E8%BF%99%E4%BA%9B%E9%94%99%E8%AF%AF%EF%BC%88%E7%BC%BA%E5%B0%91%E6%A0%87%E5%A4%B4%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CP%3E....Building%20file%3A%20..%2Fgenerate%2Fsrc%2FDpga_Ip_BOARD_INITPERIPHERALS_PBcfg.c%3CBR%20%2F%3EC%3A%2FUsers%2Fnitro%2FworkspaceS32DS.3.5_DP_V10%2FS32M24xEVB_BLDC_6Step_Hall%2Fgenerate%2Finclude%2FAdc_Ip_BOARD_INITPERIPHERALS_PBcfg.h%3A44%3A10%3A%20fatal%20error%EF%BC%9AAdc_Ip_Types.h%EF%BC%9ANo%20such%20file%20or%20directory%3CBR%20%2F%3EBuilding%20file%3A%20..%2Fgenerate%2Fsrc%2FFtm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.c%3CBR%20%2F%3E44%20%7C%20%23include%22Adc_Ip_Types.h%22%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~~~~~~%3CBR%20%2F%3E%E7%BC%96%E8%AF%91%E7%BB%88%E6%AD%A2%E3%80%82%3CBR%20%2F%3E..%2Fgenerate%2Fsrc%2FAec_Ip_Cfg.c%3A41%3A10%3A%20fatal%20error%EF%BC%9AAec_Ip_Types.h%EF%BC%9ANo%20such%20file%20or%20directory%3CBR%20%2F%3EInvoking%EF%BC%9A%E6%A0%87%E5%87%86%20S32DS%20C%20%E7%BC%96%E8%AF%91%E5%99%A8%3CBR%20%2F%3E41%20%7C%20%23include%22Aec_Ip_Types.h%22%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~~~~~~%3CBR%20%2F%3E%E7%BC%96%E8%AF%91%E7%BB%88%E6%AD%A2%E3%80%82%3CBR%20%2F%3Emake%EF%BC%9A***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A78%3A%20generate%2Fsrc%2FAdc_Ip_BOARD_INITPERIPHERALS_PBcfg.o%5D%20***.%E9%94%99%E8%AF%AF%201%3CBR%20%2F%3Emake%EF%BC%9A***%20Waiting%20for%20unfinished%20jobs....%3CBR%20%2F%3Emake%EF%BC%9A***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A78%3A%20generate%2Fsrc%2FAec_Ip_Cfg.o%5D%20Error%201%3CBR%20%2F%3E..%2Fgenerate%2Fsrc%2FAec_Ip_Sa_BOARD_INITPERIPHERALS_PBcfg.c%3A42%3A10%3A%20fatal%20error%EF%BC%9AAec_Ip_Types.h%EF%BC%9ANo%20such%20file%20or%20directory%3CBR%20%2F%3EBuilding%20file%3A%20..%2Fgenerate%2Fsrc%2FFtm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.c%3CBR%20%2F%3E42%20%7C%20%23include%22Aec_Ip_Types.h%22%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%20%40generate%20%2Fsrc%2Fadc_ip_board_initPeriperiperals_pbcfg.args%20%22-MMD%20-MP%20-MF%22generate%2Fsrc%2FDpga_Ip_BOARD_INITPERIPHERALS_PBcfg.d%22-MT%22generate%2Fsrc%2FDpga_Ip_BOARD_INITPERIPHERALS_PBcfg.o%22-o%22generate%2Fsrc%2FDpga_Ip_BOARD_INITPERIPHERALS_PBcfg.o%22%22..%2Fgenerate%2Fsrc%2FDpga_Ip_BOARD_INITPERIPHERALS_PBcfg.c%22%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~~~~~~%3CBR%20%2F%3E%E8%B0%83%E7%94%A8%EF%BC%9AStandard%20S32DS%20C%20Compiler%3CBR%20%2F%3E%E7%BC%96%E8%AF%91%E7%BB%88%E6%AD%A2%E3%80%82%3CBR%20%2F%3E%E8%B0%83%E7%94%A8%EF%BC%9A%E6%A0%87%E5%87%86%20S32DS%20C%20%E7%BC%96%E8%AF%91%E5%99%A8%3CBR%20%2F%3Emake%EF%BC%9A***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A79%3A%20generate%2Fsrc%2FAec_Ip_Sa_BOARD_INITPERIPHERALALS_PBcfg.o%5D%20***%E9%94%99%E8%AF%AF%201%20%3CBR%20%2F%3E%20arm-none-eabi-gcc%20%22%20%40generate%20%2Fsrc%2Fadc_ip_board_initPeriperherals_pbcfg.args%20%22-MMD%20-MP%20-MF%22generate%2Fsrc%2FFtm_Pwm_Ip_BOARD_INITPERIPHERALALS_PBcfg.d%22-MT%22generate%2Fsrc%2FFtm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.o%22-o%22generate%2Fsrc%2FFtm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.o%22%22..%2Fgenerate%2Fsrc%2FFtm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.c%22%3CBR%20%2F%3E%E5%9C%A8%E6%96%87%E4%BB%B6%E4%B8%AD%E5%8C%85%E5%90%AB%E6%9D%A5%E8%87%AA...%2Fgenerate%2Fsrc%2Fcdd_gdu_board_initPeriperiperals_pbcfg.c%3A43%3A%20arm-none-eabi-gcc%20%22%20%40generate%20%2Fsrc%2Fadc_ip_board_board_initPeriperherals_pbcfg.args%20%22%20%3CBR%20%2F%3E-MMD%20-MP%20-MF%22generate%2Fsrc%2FFtm_Gpt_Ip_BOARD_INITPERIPHERALALS_PBcfg.d%22-MT%22generate%2Fsrc%2FFtm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.o%22-o%22generate%2Fsrc%2FFtm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.o%22%22..%2Fgenerate%2Fsrc%2FFtm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.c%22%3CBR%20%2F%3EC%3A%2FUsers%2Fnitro%2FworkspaceS32DS.3.5_DP_V10%2FS32M24xEVB_BLDC_6Step_Hall%2Fgenerate%2Finclude%2FGdu_Ip_BOARD_INITPERIPHERALS_PBcfg.h%3A46%3A10%3A%20fatal%20error%EF%BC%9AGdu_Ip_Types.h%EF%BC%9ANo%20such%20file%20or%20directory%3CBR%20%2F%3E46%20%7C%20%23include%22Gdu_Ip_Types.h%22%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~~~~~~%3CBR%20%2F%3E%E7%BC%96%E8%AF%91%E7%BB%88%E6%AD%A2%E3%80%82%3CBR%20%2F%3Emake%EF%BC%9A***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A80%3A%20generate%2Fsrc%2FCDD_Gdu_BOARD_INITPERIPHERALALS_PBcfg.o%5D%20***Error%201%3CBR%20%2F%3EIn%20file%20included%20from%20..%2Fgenerate%2Fsrc%2FDpga_Ip_BOARD_INITPERIPHERALS_PBcfg.c%3A41%3A%3CBR%20%2F%3EC%3A%2FUsers%2Fnitro%2FworkspaceS32DS.3.5_DP_V10%2FS32M24xEVB_BLDC_6Step_Hall%2Fgenerate%2Finclude%2FDpga_Ip_BOARD_INITPERIPHERALS_PBcfg.h%3A43%3A10%3A%20fatal%20error%EF%BC%9ADpga_Ip_Types.h%EF%BC%9ANo%20such%20file%20or%20directory%3CBR%20%2F%3E43%20%7C%20%23include%22Dpga_Ip_Types.h%22%3CBR%20%2F%3E%20%7C%20%5E~~~~~~~~~~~~~~~~%3CBR%20%2F%3E%E7%BC%96%E8%AF%91%E7%BB%88%E6%AD%A2%E3%80%82%3CBR%20%2F%3Emake%EF%BC%9A***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A80%3A%20generate%2Fsrc%2FDpga_Ip_BOARD_INITPERIPHERALS_PBcfg.o%5D%20***.Error%201%3CBR%20%2F%3EIn%20file%20included%20from%20C%3A%2FUsers%2Fnitro%2FworkspaceS32DS.3.5_DP_V10%2FS32M24xEVB_BLDC_6Step_Hall%2Fgenerate%2Finclude%2FFtm_Pwm_Ip_Cfg.h%3A54%2C%3CBR%20%2F%3Efrom%20.%2Fgenerate%2Fsrc%2FFtm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.c%3A41%3A%3CBR%20%2F%3EC%3A%2FUsers%2Fnitro%2FworkspaceS32DS.3.5_DP_V10%2FS32M24xEVB_BLDC_6Step_Hall%2Fgenerate%2Finclude%2FFtm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.h%3A45%3A10%3A%20fatal%20error%EF%BC%9AFtm_Pwm_Ip_Types.h%EF%BC%9ANo%20such%20file%20or%20directory%3CBR%20%2F%3E45%20%7C%20%23include%22Ftm_Pwm_Ip_Types.h%22%3CBR%20%2F%3E%20%7C%20%5E~~~~~~~~~~~~~~~~~~~%3CBR%20%2F%3E%E7%BC%96%E8%AF%91%E7%BB%88%E6%AD%A2%E3%80%82%3CBR%20%2F%3E%E5%9C%A8%E4%BB%8E%20..%2Fgenerate%2Fsrc%2FFtm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.c%3A47%E5%8C%85%E5%90%AB%E7%9A%84%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%9A%3CBR%20%2F%3EC%3A%2FUsers%2Fnitro%2FworkspaceS32DS.3.5_DP_V10%2FS32M24xEVB_BLDC_6Step_Hall%2Fgenerate%2Finclude%2FFtm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.h%3A46%3A10%3A%20fatal%20error%EF%BC%9AFtm_Gpt_Ip_Types.h%EF%BC%9ANo%20such%20file%20or%20directory%3CBR%20%2F%3E46%20%7C%20%23include%22Ftm_Gpt_Ip_Types.h%22%3CBR%20%2F%3E%20%7C%20%5E~~~~~~~~~~~~~~~~~~~%3CBR%20%2F%3E%E7%BC%96%E8%AF%91%E7%BB%88%E6%AD%A2%E3%80%82%3CBR%20%2F%3Emake%EF%BC%9A***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A80%3A%20generate%2Fsrc%2FFtm_Pwm_Ip_BOARD_INITPERIPHERALALS_PBcfg.o%5D%20***%20%5Bgenerate%2Fsrc%2FFtm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.o%5D%20Make%E9%94%99%E8%AF%AF%201%3CBR%20%2F%3Emake%EF%BC%9A***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A80%3A%20generate%2Fsrc%2FFtm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.o%5D%20***.%E9%94%99%E8%AF%AF%201%20%3CBR%20%2F%3E%20%22%20make-j8%20all%20%22%20%E4%BB%A5%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%202%20%E7%BB%88%E6%AD%A2%E3%80%82%E7%89%88%E6%9C%AC%E5%8F%AF%E8%83%BD%E4%B8%8D%E5%AE%8C%E6%95%B4%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EPMSM_FOC%20%E5%B0%B1%E5%83%8F%E6%98%AF%E4%B8%8D%E5%AE%8C%E6%95%B4%E7%9A%84%EF%BC%9A%3C%2FP%3E%3CP%3E-j8%20all%3CBR%20%2F%3E%E6%97%A0%E6%B3%95%E8%BF%90%E8%A1%8C%E7%A8%8B%E5%BA%8F%22%22%20%EF%BC%9A%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E7%A8%8B%E5%BA%8F%22%22%20%E6%9C%AA%E5%9C%A8%20PATH%20%E4%B8%AD%E6%89%BE%E5%88%B0%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20errors%20with%20S32M24xEVB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%3C%2FP%3E%0A%3CDIV%3E%0A%3CDIV%3E%E6%82%A8%E6%98%AF%E5%90%A6%E7%82%B9%E5%87%BB%E4%BA%86%22%3CSTRONG%3E%E6%9B%B4%E6%96%B0%E4%BB%A3%E7%A0%81%3C%2FSTRONG%3E%22%20%E6%8C%89%E9%92%AE%EF%BC%8C%E5%8F%82%E7%85%A7%3CSPAN%3E%20%3C%2FSPAN%3E%204%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fs32m24x-board-setup-guides%3AGS-S32M24XEVB%3Fsection%3Dbuild-run_build-run-2%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E.2%20%E4%BD%BF%E7%94%A8%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%3C%2FA%3E%E7%94%9F%E6%88%90%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%EF%BC%9F%3C%2FDIV%3E%0A%E4%BD%A0%E6%98%AF%E5%90%A6%E5%B7%B2%E5%8F%82%E8%80%83%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fs32m24x-board-setup-guides%3AGS-S32M24XEVB%3Fsection%3Dget-software%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E2.%20%E8%8E%B7%E5%8F%96%E8%BD%AF%E4%BB%B6%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%EF%BC%8C%E5%AE%89%E8%A3%85%E4%BA%86%20SW32K1_S32M24x_RTD_4.4_R21-11_2.0.0_D2308_DS_Updatesite.zip%20%E5%92%8C%20SW32K1_S32M24x_RTD_R21-11_2.0.0_P04_D2404_DS_updatesite.zip%EF%BC%88%E5%87%BA%E8%87%AA%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3ES32M24X%20%E6%9D%BF%E8%AE%BE%E7%BD%AE%E6%8C%87%E5%8D%97%3C%2FSTRONG%3E%EF%BC%89%EF%BC%9F%3C%2FDIV%3E%0A%3CDIV%3E%E6%88%91%E8%83%BD%E5%A4%9F%E6%AF%AB%E6%97%A0%E9%94%99%E8%AF%AF%E5%9C%B0%E6%9E%84%E5%BB%BA%E8%BF%99%E4%B8%89%E4%B8%AA%E9%A1%B9%E7%9B%AE%E3%80%82%3CBR%20clear%3D%22none%22%20%2F%3EC%3A%3CSTRONG%3E%5CNXP%5CMC_DevKits%5CS32M24xEVB%5Csw%5CS32M24xEVB_BLDC_6Step_Sensorless%3C%2FSTRONG%3Eand%3CSTRONG%3ES32M24xEVB_BLDC_6Step_Hall%3C%2FSTRONG%3Eand%3CSTRONG%3ES32M24xEVB_PMSM_FOC_1Sh%3C%2FSTRONG%3E%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CP%3E%E4%BD%A0%E5%9C%A8%E8%BF%99%E9%87%8C%E4%B8%8B%E8%BD%BD%E4%BA%86%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-Design-Studio-Knowledge-Base%2FS32-Design-Studio-Releases-amp-Updates%2Fta-p%2F1119315%22%20target%3D%22_self%22%3ES32%20Design%20Studio-%E7%89%88%E6%9C%AC%20%26amp%3B%20%E6%9B%B4%E6%96%B0%3C%2FA%3E%E4%BA%86%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%88%AB%E5%BF%98%E4%BA%86%E5%AE%89%E8%A3%85%20%E9%80%82%E7%94%A8%E4%BA%8E%3CSTRONG%3E%20Arm%20%E5%B5%8C%E5%85%A5%E5%BC%8F%E5%A4%84%E7%90%86%E5%99%A8%E7%9A%84%E6%81%A9%E6%99%BA%E6%B5%A6%20GCC%20v10.2%20%E7%89%88%E6%9C%AC%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%201728%20%E7%94%B1%3CSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%20S32DS%20%E6%89%A9%E5%B1%95%E5%92%8C%E6%9B%B4%E6%96%B0%E6%8F%90%E4%BE%9B%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E7%A5%9D%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3ERobin%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22ACCEPT%20AS%20SOLUTION%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%0A%3CP%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
