wolfssl on s32k144
wolfssl on s32k144
Chandrakant
Hello team, I am trying to use RSA-2048 based Signature generation & Verification using wolfssl on s32k144EVB. So I used wolfssl source files from NXP folder found under design studio installation & built it as static library. I have attached the user_settings.h file for which i'm building the application. I'm getting stack smashing error when generating signature for data. "unsigned char* privKey" is der pkcs1 key 2048bit , "size_t privKeyLen" is the sizeof privKey byte array is 1218 bytes. Also i've attached the test application source file here. Requesting your help with this issue.
lukaszadrapa
Hi @Chandrakant
wolfSSL is not supported directly by NXP. Issues such as RSA configuration, build flags, memory model problems, or stack usage errors are outside of NXP’s supported scope.
For wolfSSL‑specific help, please use:
wolfSSL Community Support https://www.wolfssl.com/forums/
Lukas
Chandrakant
OK @lukaszadrapa, Thanks will check with wolfssl
%3CLINGO-SUB%20id%3D%22lingo-sub-2318500%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ewolfssl%20on%20s32k144%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2318500%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20team%2C%20I%20am%20trying%20to%20use%20%3CSTRONG%3ERSA-2048%20based%3C%2FSTRONG%3E%20Signature%20generation%20%26amp%3B%20Verification%20using%20wolfssl%20on%20s32k144EVB.%20So%20I%20used%20wolfssl%20source%20files%20from%20NXP%20folder%20found%20under%20design%20studio%20installation%20%26amp%3B%20built%20it%20as%20static%20library.%20I%20have%20attached%20the%20user_settings.h%20file%20for%20which%20i'm%20building%20the%20application.%20I'm%20getting%20%3CSTRONG%3Estack%20smashing%20error%3C%2FSTRONG%3E%20when%20generating%20signature%20for%20data.%20%22unsigned%20char*%20privKey%22%20is%20%3CSTRONG%3Eder%20pkcs1%20key%202048bit%3C%2FSTRONG%3E%20%2C%20%22size_t%20privKeyLen%22%20is%20the%20sizeof%20privKey%20byte%20array%20is%201218%20bytes.%20Also%20i've%20attached%20the%20test%20application%20source%20file%20here.%20Requesting%20your%20help%20with%20this%20issue.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2319142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20wolfssl%20on%20s32k144%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2319142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EOK%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F37795%22%20target%3D%22_blank%22%3E%40lukaszadrapa%3C%2FA%3E%2C%20Thanks%20will%20check%20with%20wolfssl%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2319009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20wolfssl%20on%20s32k144%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2319009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253255%22%20target%3D%22_blank%22%3E%40Chandrakant%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EwolfSSL%20is%20not%20supported%20directly%20by%20NXP.%20Issues%20such%20as%20RSA%20configuration%2C%20build%20flags%2C%20memory%20model%20problems%2C%20or%20stack%20usage%20errors%20are%20outside%20of%20NXP%E2%80%99s%20supported%20scope.%3C%2FP%3E%0A%3CP%3EFor%20wolfSSL%E2%80%91specific%20help%2C%20please%20use%3A%3C%2FP%3E%0A%3CP%3EwolfSSL%20Community%20Support%20%3CA%20href%3D%22https%3A%2F%2Fwww.wolfssl.com%2Fforums%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.wolfssl.com%2Fforums%2F%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E
