what values to select as arguments for eMcem_setupinjectionChannel
343件の閲覧回数
Rudved_3366
Hello @danielmartynek
We are using S32K394 microcontroller, and I am facing an issue selecting the right bit values for the below function 2nd 3rd arguments:
how we have to select values to pass in 2nd and 3rd arguments,
if i take below example to inject a single bit and double bit errors, then what values i need to pass and how do i select the data and check bits:
and i tried with one example with some random values for SRAM and after inject the fault and before write or read some memory its randomly injecting some memory location, but i want to inject any specific memory location how do i perform that activity:
example code which i tried:
please help me how to select these 2 argument values based on memory and how do inject fault in specific location.
Thankyou!
6 返答(返信)
255件の閲覧回数
danielmartynek
Hello @Rudved_3366,
Regarding your initial request involving an error injection into SRAM0, please refer to the EMI_2_CH_0 definition in the Reference Manual.
EMCEM_EIM_2_CH_0 targets SRAM0 and provides access to 64 data bits and 8 check bits.
You configured:
eMcem_SetupInjectionChannel(EMCEM_EIM_2_CH_0, 55U, 66U);
According to the Error Injection Channel Descriptor n, Word0 (EICHD0_WORD0 – EICHD4_WORD0) description in the Reference Manual:
Data bit index 55 corresponds to WORD[1], bit 23.
Check bit index 66 corresponds to WORD[0], bit 26.
As a result, the injection setup inverts one data bit and one check bit in SRAM0. In this configuration, the generated fault pattern is interpreted as an uncorrectable ECC error, which is reported by ERM0_CH0.
Regarding DTCM_1.
It seems to be all correct.
The ERM channel identifies the error source, in this case CH12 corresponds to DTCM1.
The ERM address is the latched address associated with that channel, not a complete global address.
237件の閲覧回数
Rudved_3366
Hello @danielmartynek :
Thank you for the info, i have got clarity on how to select on bits but as per info in the emcem manual after injecting the fault we need to read or write corresponding fault injection related memory area but currently i am not performing that action but still faults are injecting, how it works then?
Below info is is present in section 3.4.2 of S32K3 eMcem(S32K3_SAF_EMCEM_UM) Software Product Rev. 10.0 — 21 January 2025
208件の閲覧回数
danielmartynek
Hello @Rudved_3366,
This could be caused by the fact that your stack or application data is located in the memory region where the fault is being injected.
Please analyze the address captured by the ERM and then locate the corresponding address in the .map file. This will help determine whether the injected fault is affecting the stack, a global variable, or another critical memory region used by the application.
217件の閲覧回数
Rudved_3366
@danielmartynek : And additional to above question:
Can you please give me some more info about what is latched address? how can I map this to global address, if it's an offset address of DTCM then I can do DTCM start address is 0x20000000 and add the offset address, it will be sure that fault is injected at within the expected address.
205件の閲覧回数
danielmartynek
Yes, that is correct. Simply add the value captured by the ERM to the base address of the affected memory region identified by the ERM channel. In your case, the memory base address is 0x20000000
312件の閲覧回数
Rudved_3366
Also, I'm injecting the fault to DTCM1, and fault injection is happening but the memory address reporting in the register is not from DTCM1.
please find the attched screenshots:
Calling functions to inject fault:
Debugger:
EIM module data:
ERM status info:
Setting NCE10 is okay, as its default setting as we are not initialized the ITCM0,
but you can see NCE2 error is set.
But the address reporting here is wrong as per memory allocation excel screen shot which i attached:
And here also once I'm injecting the fault before reading or writing memory I'm getting an error.(this I'm testing in Trace32 debugger).
%3CLINGO-SUB%20id%3D%22lingo-sub-2418919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EeMcem_setupinjectionChannel%20%E3%81%AE%E5%BC%95%E6%95%B0%E3%81%A8%E3%81%97%E3%81%A6%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E5%80%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2418919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F160001%22%20target%3D%22_blank%22%3E%40danielmartynek%20%E3%81%95%E3%82%93%E3%80%82%3C%2FA%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AFS32K394%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AE2%2F3%E3%81%AE%E5%BC%95%E6%95%B0%E3%81%AE%E6%AD%A3%E3%81%97%E3%81%84%E3%83%93%E3%83%83%E3%83%88%E5%80%A4%E3%82%92%E9%81%B8%E3%81%B6%E3%81%AE%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Rudved_3366_0-1791348958519.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_0-1791348958519.png%22%20style%3D%22width%3A%20312px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_0-1791348958519.png%22%20style%3D%22width%3A%20312px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_0-1791348958519.png%22%20style%3D%22width%3A%20312px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397387i8974CA43C1646ACF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Rudved_3366_0-1791348958519.png%22%20alt%3D%22Rudved_3366_0-1791348958519.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E2%E7%95%AA%E7%9B%AE%E3%81%A83%E7%95%AA%E7%9B%AE%E3%81%AE%E5%BC%95%E6%95%B0%E3%81%AB%E6%B8%A1%E3%81%99%E5%80%A4%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%80%81%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E4%BE%8B%E3%82%92%E5%8F%82%E8%80%83%E3%81%AB%E3%80%811%E3%83%93%E3%83%83%E3%83%88%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A82%E3%83%93%E3%83%83%E3%83%88%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E6%B3%A8%E5%85%A5%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%80%A4%E3%82%92%E6%B8%A1%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%A6%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Rudved_3366_1-1791349271216.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_1-1791349271216.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_1-1791349271216.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_1-1791349271216.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397388i4A1EB7EC17DDCB4B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Rudved_3366_1-1791349271216.png%22%20alt%3D%22Rudved_3366_1-1791349271216.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ESRAM%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%81%AA%E5%80%A4%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A61%E3%81%A4%E3%81%AE%E4%BE%8B%E3%82%92%E8%A9%A6%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E9%9A%9C%E5%AE%B3%E3%82%92%E6%B3%A8%E5%85%A5%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%9F%E3%81%AF%E8%AA%AD%E3%81%BF%E5%87%BA%E3%81%97%E3%81%AE%E5%89%8D%E3%81%AB%E3%80%81%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%81%AB%E3%83%A1%E3%83%A2%E3%83%AA%E4%BD%8D%E7%BD%AE%E3%81%8C%E6%B3%A8%E5%85%A5%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E4%BD%8D%E7%BD%AE%E3%82%92%E6%B3%A8%E5%85%A5%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%9D%E3%81%AE%E6%93%8D%E4%BD%9C%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E8%A9%A6%E3%81%97%E3%81%9F%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Rudved_3366_2-1791349426218.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_2-1791349426218.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_2-1791349426218.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_2-1791349426218.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397389iF46ED4B7CEC8067F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Rudved_3366_2-1791349426218.png%22%20alt%3D%22Rudved_3366_2-1791349426218.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Rudved_3366_3-1791349463809.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_3-1791349463809.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_3-1791349463809.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_3-1791349463809.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397390i760925453ED52E93%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Rudved_3366_3-1791349463809.png%22%20alt%3D%22Rudved_3366_3-1791349463809.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Rudved_3366_4-1791349492570.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_4-1791349492570.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_4-1791349492570.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_4-1791349492570.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397391i5AE9F4B55AAF7008%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Rudved_3366_4-1791349492570.png%22%20alt%3D%22Rudved_3366_4-1791349492570.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%93%E3%82%8C%E3%82%892%E3%81%A4%E3%81%AE%E5%BC%95%E6%95%B0%E5%80%A4%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%A8%E3%80%81%E7%89%B9%E5%AE%9A%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E9%9A%9C%E5%AE%B3%E3%82%92%E6%B3%A8%E5%85%A5%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2419278%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20what%20values%20to%20select%20as%20arguments%20for%20eMcem_setupinjectionChannel%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2419278%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F160001%22%20target%3D%22_blank%22%3E%40danielmartynek%3C%2FA%3E%20%3A%20%E4%B8%8A%E8%A8%98%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E5%8A%A0%E3%81%88%E3%81%A6%EF%BC%9A%3C%2FP%3E%3CP%3E%E3%83%A9%E3%83%83%E3%83%81%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%A8%E3%81%AF%E4%BD%95%E3%81%8B%E3%80%81%E3%82%82%E3%81%86%E5%B0%91%E3%81%97%E8%A9%B3%E3%81%97%E3%81%8F%E6%95%99%E3%81%88%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%93%E3%82%8C%E3%82%92%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%82%82%E3%81%97DTCM%E3%81%AE%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AA%E3%82%89%E3%80%81DTCM%E3%81%AE%E9%96%8B%E5%A7%8B%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%920x20000000%E3%81%AB%E3%81%97%E3%81%A6%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8C%E3%81%B0%E3%80%81%E3%81%9D%E3%81%AE%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%88%E3%81%8C%E6%9C%9F%E5%BE%85%E3%81%95%E3%82%8C%E3%82%8B%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E5%86%85%E3%81%AB%E7%A2%BA%E5%AE%9F%E3%81%AB%E6%B3%A8%E5%85%A5%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2419160%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20what%20values%20to%20select%20as%20arguments%20for%20eMcem_setupinjectionChannel%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2419160%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F160001%22%20target%3D%22_blank%22%3E%40danielmartynek%20%E3%81%95%E3%82%93%3C%2FA%3E%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E9%81%B8%E6%8A%9E%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81emcem%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E9%9A%9C%E5%AE%B3%E3%82%92%E6%B3%A8%E5%85%A5%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E9%9A%9C%E5%AE%B3%E6%B3%A8%E5%85%A5%E9%96%A2%E9%80%A3%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E9%A0%98%E5%9F%9F%E3%82%92%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%9D%E3%81%AE%E6%93%8D%E4%BD%9C%E3%81%AF%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E9%9A%9C%E5%AE%B3%E3%81%8C%E6%B3%A8%E5%85%A5%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%AF%E3%80%81S32K3%20eMcem(S32K3_SAF_EMCEM_UM)%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E8%A3%BD%E5%93%81%20Rev.%2010.0%20%E2%80%94%202025%E5%B9%B41%E6%9C%8821%E6%97%A5%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B33.4.2%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Rudved_3366_0-1791393370958.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_0-1791393370958.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_0-1791393370958.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_0-1791393370958.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397454iB9C94ADAFDBB99D9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Rudved_3366_0-1791393370958.png%22%20alt%3D%22Rudved_3366_0-1791393370958.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2419118%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20what%20values%20to%20select%20as%20arguments%20for%20eMcem_setupinjectionChannel%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2419118%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F267166%22%20target%3D%22_blank%22%3E%E3%80%81%40Rudved_3366%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CP%3ESRAM0%E3%81%B8%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E6%B3%A8%E5%85%A5%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%9C%80%E5%88%9D%E3%81%AE%E8%A6%81%E6%9C%9B%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AEEMI_2_CH_0%E5%AE%9A%E7%BE%A9%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22danielmartynek_0-1791379485949.png%22%20style%3D%22width%3A%20762px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1791379485949.png%22%20style%3D%22width%3A%20762px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1791379485949.png%22%20style%3D%22width%3A%20762px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1791379485949.png%22%20style%3D%22width%3A%20762px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397433i198CBCC0752E10C5%2Fimage-dimensions%2F762x120%3Fv%3Dv2%22%20width%3D%22762%22%20height%3D%22120%22%20role%3D%22button%22%20title%3D%22danielmartynek_0-1791379485949.png%22%20alt%3D%22danielmartynek_0-1791379485949.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EEMCEM_EIM_2_CH_0%20SRAM0%E3%82%92%E5%AF%BE%E8%B1%A1%E3%81%A8%E3%81%97%E3%80%8164%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%A88%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%93%E3%83%83%E3%83%88%E3%81%B8%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%A8%AD%E5%AE%9A%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FP%3E%0A%3CP%3EeMcem_SetupInjectionChannel(EMCEM_EIM_2_CH_0%E3%80%8155U%E3%80%8166U)%3B%3C%2FP%3E%0A%3CP%3E%E5%8F%82%E8%80%83%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E6%B3%A8%E5%85%A5%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E8%A8%98%E8%BF%B0%E5%AD%90n%E3%80%81Word0(EICHD0_WORD0%20%E2%80%93%20EICHD4_WORD0)%E3%81%AE%E8%A8%98%E8%BF%B0%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%3A%3C%2FP%3E%0A%3CP%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%83%93%E3%83%83%E3%83%88%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B955%E3%81%AF%E3%80%81WORD%5B1%5D%E3%81%AE%E3%83%93%E3%83%83%E3%83%8823%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%93%E3%83%83%E3%83%88%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B966%E3%81%8CWORD%5B0%5D%E3%81%AE%E3%83%93%E3%83%83%E3%83%8826%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%AE%E7%B5%90%E6%9E%9C%E3%80%81%E6%B3%A8%E5%85%A5%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81SRAM0%E5%86%85%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%83%93%E3%83%83%E3%83%881%E3%81%A4%E3%81%A8%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%93%E3%83%83%E3%83%881%E3%81%A4%E3%81%8C%E5%8F%8D%E8%BB%A2%E3%81%95%E3%82%8C%E3%82%8B%E3%80%82%E3%81%93%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%AF%E3%80%81%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E9%9A%9C%E5%AE%B3%E3%83%91%E3%82%BF%E3%83%BC%E3%83%B3%E3%81%AF%E8%A8%82%E6%AD%A3%E4%B8%8D%E5%8F%AF%E8%83%BD%E3%81%AAECC%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E8%A7%A3%E9%87%88%E3%81%95%E3%82%8C%E3%80%81ERM0_CH0%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EDTCM_1%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E6%AD%A3%E3%81%97%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EERM%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AF%E8%AA%A4%E3%82%8A%E6%BA%90%E3%82%92%E7%89%B9%E5%AE%9A%E3%81%97%E3%80%81%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AFCH12%E3%81%8CDTCM1%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EERM%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF%E3%80%81%E3%81%9D%E3%81%AE%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AB%E9%96%A2%E9%80%A3%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%9F%E3%83%A9%E3%83%83%E3%83%81%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E5%AE%8C%E5%85%A8%E3%81%AA%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2418964%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20what%20values%20to%20select%20as%20arguments%20for%20eMcem_setupinjectionChannel%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2418964%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81DTCM1%E3%81%AB%E9%9A%9C%E5%AE%B3%E3%82%92%E6%B3%A8%E5%85%A5%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E9%9A%9C%E5%AE%B3%E6%B3%A8%E5%85%A5%E8%87%AA%E4%BD%93%E3%81%AF%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%82%E3%81%AE%E3%81%AE%E3%80%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%82%8B%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AFDTCM1%E3%81%8B%E3%82%89%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E6%B7%BB%E4%BB%98%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E9%96%A2%E6%95%B0%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%A6%E9%9A%9C%E5%AE%B3%E3%82%92%E6%B3%A8%E5%85%A5%E3%81%99%E3%82%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Rudved_3366_0-1791359209291.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_0-1791359209291.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_0-1791359209291.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_0-1791359209291.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397398i272F5442DC4B664D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Rudved_3366_0-1791359209291.png%22%20alt%3D%22Rudved_3366_0-1791359209291.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%EF%BC%9A%3C%2FP%3E%3CP%3EEIM%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%83%87%E3%83%BC%E3%82%BF%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Rudved_3366_1-1791359491636.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_1-1791359491636.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_1-1791359491636.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_1-1791359491636.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397399i6EC39DC73F548761%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Rudved_3366_1-1791359491636.png%22%20alt%3D%22Rudved_3366_1-1791359491636.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Rudved_3366_2-1791359515152.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_2-1791359515152.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_2-1791359515152.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_2-1791359515152.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397400i5AE6A945CCD47C61%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Rudved_3366_2-1791359515152.png%22%20alt%3D%22Rudved_3366_2-1791359515152.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EERM%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E6%83%85%E5%A0%B1%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Rudved_3366_3-1791359562115.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_3-1791359562115.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_3-1791359562115.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_3-1791359562115.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397401i9AC2CFF29E376178%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Rudved_3366_3-1791359562115.png%22%20alt%3D%22Rudved_3366_3-1791359562115.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ENCE10%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82ITCM0%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81NCE2%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%9F%E3%83%A1%E3%83%A2%E3%83%AA%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AEExcel%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Rudved_3366_4-1791359711559.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_4-1791359711559.png%22%20style%3D%22width%3A%20363px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_4-1791359711559.png%22%20style%3D%22width%3A%20363px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_4-1791359711559.png%22%20style%3D%22width%3A%20363px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397402iDDC628E9C41C6EFF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Rudved_3366_4-1791359711559.png%22%20alt%3D%22Rudved_3366_4-1791359711559.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Rudved_3366_5-1791359740070.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_5-1791359740070.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_5-1791359740070.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rudved_3366_5-1791359740070.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397403i854212A8E73D9AB3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Rudved_3366_5-1791359740070.png%22%20alt%3D%22Rudved_3366_5-1791359740070.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%81%93%E3%81%93%E3%81%A7%E3%82%82%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%E3%81%AE%E5%89%8D%E3%81%AB%E9%9A%9C%E5%AE%B3%E3%82%92%E6%B3%A8%E5%85%A5%E3%81%99%E3%82%8B%E3%81%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82(%E3%81%93%E3%82%8CTrace32%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2419384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20what%20values%20to%20select%20as%20arguments%20for%20eMcem_setupinjectionChannel%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2419384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F267166%22%20target%3D%22_blank%22%3E%E3%80%81%40Rudved_3366%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%82%84%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E6%95%85%E9%9A%9C%E3%81%8C%E6%B3%A8%E5%85%A5%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%A1%E3%83%A2%E3%83%AA%E9%A0%98%E5%9F%9F%E3%81%AB%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3EERM%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%8F%96%E5%BE%97%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E5%88%86%E6%9E%90%E3%81%97%E3%80%81.map%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%86%85%E3%81%A7%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E7%89%B9%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E6%B3%A8%E5%85%A5%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%88%E3%81%8C%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%80%81%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%E5%A4%89%E6%95%B0%E3%80%81%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E4%BB%96%E3%81%AE%E9%87%8D%E8%A6%81%E3%81%AA%E3%83%A1%E3%83%A2%E3%83%AA%E9%A0%98%E5%9F%9F%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%82%92%E4%B8%8E%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E5%88%A4%E6%96%AD%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2419386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20what%20values%20to%20select%20as%20arguments%20for%20eMcem_setupinjectionChannel%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2419386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%9D%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82ERM%E3%81%8C%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%97%E3%81%9F%E5%80%A4%E3%82%92%E3%80%81ERM%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%A7%E7%89%B9%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E5%BD%B1%E9%9F%BF%E3%82%92%E5%8F%97%E3%81%91%E3%81%9F%E3%83%A1%E3%83%A2%E3%83%AA%E9%A0%98%E5%9F%9F%E3%81%AE%E3%83%99%E3%83%BC%E3%82%B9%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E5%8A%A0%E7%AE%97%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%99%E3%83%BC%E3%82%B9%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF0x20000000%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E
