wake up from VLPS
wake up from VLPS
1,629 次查看
martinodeluca
Good Morning,
I have a problem with my application. As I read in many ap notes S32k144 goes in VLPS and can be wake up by an async interrupt by means of low power timer. I didn't find any example in which this "feature" is explained with a snippet code. I tried in many ways but I don't know how to do it. I would like to have some suggestion from you.
Best Regards
Martino
1,508 次查看
victorjimenez
Hello Martino,
Within the newest SDK, you will find an example called power_mode_switch_s32k144. This project makes exactly what you are looking for. You can send the S32K144EVB to VLPS mode, to wake up the MCU, the project uses an interrupt triggered by the SW3.
TIC
