view function run time
qianghu
With IAR Embedded Workbench 、PE and S32K146,how I can view the time a function run?
Tags (3)
danielmartynek
This is rather a question for IAR support.
But if you want to measure the execution time of a function, you can use DWT.
ARM Information Center
Cycle Counting on ARM Cortex-M with DWT | MCU on Eclipse
danielmartynek
qianghu
Thank you very much!
