secure flash on s32k58
bryan_hong
Senior Contributor I
dear nxp
Is secure flash supported on s32k358 ?
If so, Could you provide example for secure flash on s32k358 ?
Bryan
bryan_hong
dear Lukas
Can we request technical support from NXP for securely operating an externally mounted flash?
Bryan
bryan_hong
dear Lukas
Thanks for your reply~
Is there example source code for HSE? It seems that HSE has the capability to generate and import keys, so it would be helpful to have example code and related references
Bryan
lukaszadrapa
Hi @bryan_hong
There’s no secure flash which could be used by user. When HSE firmware is installed, certain flash areas are allocated exclusively for HSE resources. These areas are sometimes called as secure flash but users can’t access it, it’s hidden for user.
Users can import keys to HSE. These are stored to secure flash by HSE. This mechanism is dedicated to keys only, it is not recommended to use it for own data. This was already discussed here:
https://community.nxp.com/t5/S32K/Store-User-Specific-value-in-the-secure-NVM/m-p/1856763/highlight/...
As mentioned, usual approach is to encrypt data by a key stored in HSE and also use SMR services for verification of that area.
Lukas
%3CLINGO-SUB%20id%3D%22lingo-sub-2347930%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Esecure%20flash%20on%20s32k58%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2347930%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Edear%20nxp%3C%2FP%3E%3CP%3EIs%20secure%20flash%20supported%20on%20s32k358%20%3F%3C%2FP%3E%3CP%3EIf%20so%2C%20Could%20you%20provide%20example%20for%20secure%20flash%20on%20s32k358%20%3F%3C%2FP%3E%3CP%3EThanks%2C%3CBR%20%2F%3EBryan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2348760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20secure%20flash%20on%20s32k58%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2348760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Edear%20Lukas%3C%2FP%3E%3CP%3EThanks%20for%20your%20reply~%3C%2FP%3E%3CP%3EIs%20there%20example%20source%20code%20for%20HSE%3F%20It%20seems%20that%20HSE%20has%20the%20capability%20to%20generate%20and%20import%20keys%2C%20so%20it%20would%20be%20helpful%20to%20have%20example%20code%20and%20related%20references%3C%2FP%3E%3CP%3EThanks%2C%3CBR%20%2F%3EBryan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2348106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20secure%20flash%20on%20s32k58%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2348106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F107445%22%20target%3D%22_blank%22%3E%40bryan_hong%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThere%E2%80%99s%20no%20secure%20flash%20which%20could%20be%20used%20by%20user.%20When%20HSE%20firmware%20is%20installed%2C%20certain%20flash%20areas%20are%20allocated%20exclusively%20for%20HSE%20resources.%20These%20areas%20are%20sometimes%20called%20as%20secure%20flash%20but%20users%20can%E2%80%99t%20access%20it%2C%20it%E2%80%99s%20hidden%20for%20user.%3C%2FP%3E%0A%3CP%3EUsers%20can%20import%20keys%20to%20HSE.%20These%20are%20stored%20to%20secure%20flash%20by%20HSE.%20This%20mechanism%20is%20dedicated%20to%20keys%20only%2C%20it%20is%20not%20recommended%20to%20use%20it%20for%20own%20data.%20This%20was%20already%20discussed%20here%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FStore-User-Specific-value-in-the-secure-NVM%2Fm-p%2F1856763%2Fhighlight%2Ftrue%23M34785%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FStore-User-Specific-value-in-the-secure-NVM%2Fm-p%2F1856763%2Fhighlight%2Ftrue%23M34785%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EAs%20mentioned%2C%20usual%20approach%20is%20to%20encrypt%20data%20by%20a%20key%20stored%20in%20HSE%20and%20also%20use%20SMR%20services%20for%20verification%20of%20that%20area.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2349954%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20secure%20flash%20on%20s32k58%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2349954%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Edear%20Lukas%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ECan%20we%20request%20technical%20support%20from%20NXP%20for%20securely%20operating%20an%20externally%20mounted%20flash%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%2C%3CBR%20%2F%3EBryan%3C%2FP%3E%3C%2FLINGO-BODY%3E
