#s32k396 sgen
#s32k396 sgen
772 次查看
maaong
I am currently working with the S32K396 MCU and would like to implement RDC-less functionality using the SGEN peripheral.
I am using the S32 Design Studio and the RTD model for Basic Software configuration.
Assuming that the SGEN is properly configured, I would like to know which peripheral I can use to output the signal generated by SGEN so that I can observe it on an oscilloscope.
Additionally, which MCAL driver(s) should be configured in order to use the SGEN module?
Lastly, is it even possible to output a sine wave generated by SGEN to a physical pin?
Thank you for your support.
标记 (1)
1 回复
747 次查看
petervlna
SGEN is not currently supported by RTD.
You can use baremetal example code which is on our web for single motor control kit:
https://www.nxp.com/design/design-center/development-boards-and-designs/MCSPTR2AK396
There is set HW trigger, but you can modify it according to your needs.
Yes. Refer to IOMUX table attached to reference manual.
Peter
