s32k344 flexcan example
1,259 次查看
Jayraj1
i want s32k344 flexcan code which run on normal/user mode
i want to see output on bus like pcan or CANoe
if flex can is not available then classic can example for s32k3 series will be ok as of now i want to only test the pins of CAN
1 回复
1,242 次查看
Senlent
