s32k344 CAN Reception code
3,721 次查看
ash123456789
I am Sending Can msg after receiving Can msg but its sending Can msg without receiving what went wrong
5 回复数
3,695 次查看
PetrS
change a code little bit...
FlexCAN_Ip_SetStartMode(INST_FLEXCAN_0);
FlexCAN_Ip_ConfigRxMb(INST_FLEXCAN_0, RX_MB_IDX, &rx_info, MSG_ID);
FlexCAN_Ip_Receive(INST_FLEXCAN_0, RX_MB_IDX, &RxData, false);
while(1)
      if(FlexCAN_Ip_GetTransferStatus(INST_FLEXCAN_0, RX_MB_IDX) == FLEXCAN_STATUS_SUCCESS)
               FlexCAN_Ip_Send(INST_FLEXCAN_0, TX_MB_IDX, &tx_info, MSG_ID, &RxData);
This is if receive does not use a polling option. If you want to have pooling one you need to call FlexCAN_Ip_MainFunctionRead to process received frame and update driver status.
Do not clear MB flag, it is done by driver.
BR, Petr
3,662 次查看
ash123456789
please help me to find out mistake why its not working
3,669 次查看
ash123456789
its not working is there any document where it shown step by step how do configure and transmit or receive in both method like polling and intruppt
3,643 次查看
PetrS
3,596 次查看
ash123456789
but i am using setup RTD version 5.0.0
and design studio 3.5
this refernce example code is not working in my code
