s32k312
s32k312
3,522 次查看
LEEYM
hello.
i want to debugging my s32kevb board, but it's not working.
so, what these mean.. and how to fix it.
thanks, your favor.
PEmicro GDB Launch Failure : Error during flash programming. Terminating debug session.
PE-ERROR: Error downloading to the device. Terminating debug session.
UsageFault: The processor has attempted to execute an undefined instruction.
HardFault: A fault has been escalated to a hard fault.
Disconnected from "127.0.0.1" via 127.0.0.1. Disconnection by port "52610" from 6224
Disconnected from "127.0.0.1" via 127.0.0.1. Disconnection by port "52615" from 7224
INFO: DAP IDCODE = 0x6BA02477
Target Disconnected.
标记 (1)
7 回复数
3,378 次查看
LEEYM
Did you follow the 3.2 Plug in the Power Supply method to make the FS26 SBC start with disabled watchdog?
-> YES, AND 4 LED ON , WITH PLUG IN MY 12V JACK
IS IT PROBLEM WITH MY BOARD?
WHAT IS MEAN ABOUT THIS PORBLEM MESSAGE..
I WANT TO KNOW THESE MEAN AND HOW TO FIX.........
3,370 次查看
Robin_Shen
Q1. What was the last program downloaded?
Q2. Is the FS26 hot?
Q3. If a low-level pulse can be observed on the reset pin, please use an oscilloscope or logic analyzer to measure the frequency.
Q4. Please tell me which LEDs are light. If you don't tell me the specific information, it will be difficult for me to help you find the root cause quickly.
3,361 次查看
LEEYM
 - JUST PROGRAMMING MY WORK SPACE
- NO.
- I DON'T HAVE IT .. BUT I THINK IT'S OK
-LED D1 , D2 , PV3V, D5 LOCATION IS 12V DC PORT LEFT
3,351 次查看
Robin_Shen
External debugger or onboard debugger did you select?
Follow the steps 3.3 Connect the Debugger Cable,
Connect a micro-USB cable to the J40 connector to debug via the on-board S32K3 debugger.
The D14 should light up. And then you will see the Port: Embedded Multilink Rev A in PEmicro Debugger configuration view:
3,335 次查看
LEEYM
I USE ON BOARD THE BUG NAME :  Debugger : U-Multilink
AND, WHEN I CONNECTED BY, POWER, USB, AND J12 DUBUGGER PINS
TURN ON TRTPWR IN MY DEBUGGER...
And when I did it for the first time, it was debugging
I can't do it all of a sudden
I changed it to GDBMI FORT NUMBER and SERVER FORT NUMBER
But now it's the same environment you sent me
3,321 次查看
Robin_Shen
Please note that some older versions of Multilink do not support S32K3, see the discussion in: s32ds-v3.4 debug s32k344 via PE
Tell me the version of S32K3 RTD you use.
Or send me the project you tested for checking.
Have you tried the onboard debugger (J40) with J12 disconnected?
3,501 次查看
Robin_Shen
Is the FS26 hot?
Robin
%3CLINGO-SUB%20id%3D%22lingo-sub-2134606%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K312%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2134606%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E%E6%82%A8%E5%A5%BD%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E6%88%91%E6%83%B3%E8%B0%83%E8%AF%95%E6%88%91%E7%9A%84%20s32kevb%20%E6%9D%BF%EF%BC%8C%E4%BD%86%E5%AE%83%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E9%82%A3%E4%B9%88%EF%BC%8C%E8%BF%99%E4%BA%9B%E6%84%8F%E5%91%B3%E7%9D%80%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EPemicro%20GDB%20%E7%94%A8%E4%B8%8A%E5%B8%82%E5%A4%B1%E8%B4%A5%EF%BC%9A%E9%97%AA%E5%AD%98%E7%BC%96%E7%A8%8B%E6%9C%9F%E9%97%B4%E5%87%BA%E9%94%99%E3%80%82%E7%BB%88%E6%AD%A2%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EPE-ERROR%EF%BC%9A%E4%B8%8B%E8%BD%BD%E5%88%B0%E8%AE%BE%E5%A4%87%E6%97%B6%E5%87%BA%E9%94%99%E3%80%82%E7%BB%88%E6%AD%A2%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%BD%BF%E7%94%A8%E6%95%85%E9%9A%9C%EF%BC%9A%E5%A4%84%E7%90%86%E5%99%A8%E8%AF%95%E5%9B%BE%E6%89%A7%E8%A1%8C%E6%9C%AA%E5%AE%9A%E4%B9%89%E7%9A%84%E6%8C%87%E4%BB%A4%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%A1%AC%E6%95%85%E9%9A%9C%EF%BC%9A%E6%95%85%E9%9A%9C%E5%B7%B2%E5%8D%87%E7%BA%A7%E4%B8%BA%E7%A1%AC%E6%95%85%E9%9A%9C%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%80%9A%E8%BF%87%20127.0.0.1%20%E4%B8%8E%22127.0.0.1%22%20%E6%96%AD%E5%BC%80%E8%BF%9E%E6%8E%A5%E3%80%82%E9%80%9A%E8%BF%87%E7%AB%AF%E5%8F%A3%E6%96%AD%E5%BC%80%2252610%22%20from%206224%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%80%9A%E8%BF%87%20127.0.0.1%20%E4%B8%8E%22127.0.0.1%22%20%E6%96%AD%E5%BC%80%E8%BF%9E%E6%8E%A5%E3%80%82%E9%80%9A%E8%BF%87%E7%AB%AF%E5%8F%A3%E6%96%AD%E5%BC%80%2252615%22%20from%207224%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EINFO%EF%BC%9ADAP%20IDCODE%20%3D%200x6BA02477%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%9B%AE%E6%A0%87%E5%B7%B2%E6%96%AD%E5%BC%80%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20s32k312%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8CMultilink%20%E7%9A%84%E6%9F%90%E4%BA%9B%E6%97%A7%E7%89%88%E6%9C%AC%E4%B8%8D%E6%94%AF%E6%8C%81%20S32K3%20%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2Fs32ds-v3-4-debug-s32k344-via-PE%2Ftd-p%2F1374701%22%20target%3D%22_self%22%3E%20s32ds-v3.4%20%E9%80%9A%E8%BF%87%20PE%20%E8%B0%83%E8%AF%95%20s32k344%20%E4%B8%AD%E7%9A%84%E8%AE%A8%E8%AE%BA%E3%80%82%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%20S32K3%20RTD%20%E7%89%88%E6%9C%AC%E3%80%82%3CBR%20%2F%3E%E6%88%96%E8%80%85%E6%8A%8A%E4%BD%A0%E6%B5%8B%E8%AF%95%E8%BF%87%E7%9A%84%E9%A1%B9%E7%9B%AE%E5%8F%91%E7%BB%99%E6%88%91%E6%A3%80%E6%9F%A5%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E5%9C%A8%E6%96%AD%E5%BC%80%20J12%20%E8%BF%9E%E6%8E%A5%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E8%AF%95%E8%BF%87%E6%9D%BF%E8%BD%BD%E8%B0%83%E8%AF%95%E5%99%A8%20(J40)%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136294%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20s32k312%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136294%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E6%9D%BF%E4%B8%8A%E7%9A%84%E9%94%99%E8%AF%AF%E5%90%8D%E7%A7%B0%EF%BC%9A%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%9AU-Multilink%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E8%BF%9E%E6%8E%A5%E7%94%B5%E6%BA%90%E3%80%81USB%20%E5%92%8C%20j12%20dubugger%20%E5%BC%95%E8%84%9A%E6%97%B6%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%9C%A8%E6%88%91%E7%9A%84%E8%B0%83%E8%AF%95%E5%99%A8%E4%B8%AD%E6%89%93%E5%BC%80%20trtpwr...%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E6%88%91%E7%AC%AC%E4%B8%80%E6%AC%A1%E5%81%9A%E7%9A%84%E6%97%B6%E5%80%99%E6%98%AF%E5%9C%A8%E8%B0%83%E8%AF%95%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E6%88%91%E7%AA%81%E7%84%B6%E5%81%9A%E4%B8%8D%E5%88%B0%E4%BA%86%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E6%88%91%E6%8A%8A%E5%AE%83%E6%94%B9%E6%88%90%E4%BA%86%20GDBMI%20FORT%20NUMBER%20%E5%92%8C%20SERVER%20FORT%20NUMBER%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E4%BD%86%E7%8E%B0%E5%9C%A8%E8%BF%98%E6%98%AF%E4%BD%A0%E5%8F%91%E7%BB%99%E6%88%91%E7%9A%84%E9%82%A3%E4%B8%AA%E7%8E%AF%E5%A2%83%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136233%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20s32k312%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136233%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E9%80%89%E6%8B%A9%E4%BA%86%E5%A4%96%E9%83%A8%E8%B0%83%E8%AF%95%E5%99%A8%E8%BF%98%E6%98%AF%E6%9D%BF%E8%BD%BD%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%8C%89%E7%85%A7%E6%AD%A5%E9%AA%A4%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fgetting-started-with-the-s32k312evb-q172-evaluation-board-for-general-purpose%3AGS-S32K312EVB-Q172%3Fsection%3Dplug-it-in_plug-it-in-3%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E3.3%20%E8%BF%9E%E6%8E%A5%E8%B0%83%E8%AF%95%E5%99%A8%E7%94%B5%E7%BC%86%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%B0%86%E4%B8%80%E6%A0%B9%E5%BE%AE%E5%9E%8B%20USB%20%E7%94%B5%E7%BC%86%E8%BF%9E%E6%8E%A5%E5%88%B0%3C%2FSPAN%3E%20%3CCODE%20translate%3D%22no%22%3EJ40%3C%2FCODE%3E%20%3CSPAN%3E%E8%BF%9E%E6%8E%A5%E5%99%A8%EF%BC%8C%E9%80%9A%E8%BF%87%E6%9D%BF%E8%BD%BD%20S32K3%20%E8%B0%83%E8%AF%95%E5%99%A8%3C%2FSPAN%3E%E8%BF%9B%E8%A1%8C%E8%B0%83%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ED14%20%E5%BA%94%E8%AF%A5%E4%BC%9A%E4%BA%AE%E8%B5%B7%E3%80%82%E7%84%B6%E5%90%8E%EF%BC%8C%E6%82%A8%E5%B0%86%E5%9C%A8%20PEmicro%20%E8%B0%83%E8%AF%95%E5%99%A8%E9%85%8D%E7%BD%AE%E8%A7%86%E5%9B%BE%E4%B8%AD%E7%9C%8B%E5%88%B0%E7%AB%AF%E5%8F%A3%EF%BC%9AEmbedded%20Multilink%20Rev%20A%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22PEmicro%20Debugger%20Configuration.png%22%20style%3D%22width%3A%20905px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PEmicro%20Debugger%20Configuration.png%22%20style%3D%22width%3A%20905px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348185i1FFED639179BE088%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22PEmicro%20Debugger%20Configuration.png%22%20alt%3D%22PEmicro%20Debugger%20Configuration.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136180%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20s32k312%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136180%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EQ1.%E6%9C%80%E5%90%8E%E4%B8%8B%E8%BD%BD%E7%9A%84%E7%A8%8B%E5%BA%8F%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E-%20%E5%8F%AA%E6%98%AF%E5%9C%A8%E7%BC%96%E7%A8%8B%E6%88%91%E7%9A%84%E5%B7%A5%E4%BD%9C%E7%A9%BA%E9%97%B4%3C%2FP%3E%3CP%3E%3CSPAN%3EQ2.FS26%20%E7%83%AD%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E-%20%E4%B8%8D%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSPAN%3EQ3%E3%80%82%E5%A6%82%E6%9E%9C%E5%8F%AF%E4%BB%A5%E5%9C%A8%20RESET%20%E5%BC%95%E8%84%9A%E4%B8%8A%E8%A7%82%E5%AF%9F%E5%88%B0%E4%BD%8E%E7%94%B5%E5%B9%B3%E8%84%89%E5%86%B2%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%E7%A4%BA%E6%B3%A2%E5%99%A8%E6%88%96%E9%80%BB%E8%BE%91%E5%88%86%E6%9E%90%E4%BB%AA%E6%9D%A5%E6%B5%8B%E9%87%8F%E9%A2%91%E7%8E%87%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E-%20%E6%88%91%E6%B2%A1%E6%9C%89......%E4%BD%86%E6%88%91%E8%A7%89%E5%BE%97%E8%BF%98%E5%8F%AF%E4%BB%A5%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EQ4.%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E5%93%AA%E4%BA%9B%20LED%20%E6%98%AF%E5%85%89%E6%BA%90%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E4%B8%8D%E5%91%8A%E8%AF%89%E6%88%91%E5%85%B7%E4%BD%93%E4%BF%A1%E6%81%AF%EF%BC%8C%E6%88%91%E5%B0%86%E5%BE%88%E9%9A%BE%E5%B8%AE%E6%82%A8%E8%BF%85%E9%80%9F%E6%89%BE%E5%88%B0%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E-led%20d1%E3%80%81d2%E3%80%81pv3v%E3%80%81d5%20%E4%BD%8D%E7%BD%AE%E4%B8%BA%E5%B7%A6%E4%BE%A7%2012%20%E4%BC%8F%E7%9B%B4%E6%B5%81%E7%AB%AF%E5%8F%A3%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136166%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20s32k312%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136166%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EQ1%E3%80%82%E4%B8%8A%E6%AC%A1%E4%B8%8B%E8%BD%BD%E7%9A%84%E7%A8%8B%E5%BA%8F%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EQ2%E3%80%82FS26%20%E5%BE%88%E7%81%AB%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EQ3%E3%80%82%E5%A6%82%E6%9E%9C%E5%8F%AF%E4%BB%A5%E5%9C%A8%20RESET%20%E5%BC%95%E8%84%9A%E4%B8%8A%E8%A7%82%E5%AF%9F%E5%88%B0%E4%BD%8E%E7%94%B5%E5%B9%B3%E8%84%89%E5%86%B2%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%E7%A4%BA%E6%B3%A2%E5%99%A8%E6%88%96%E9%80%BB%E8%BE%91%E5%88%86%E6%9E%90%E4%BB%AA%E6%9D%A5%E6%B5%8B%E9%87%8F%E9%A2%91%E7%8E%87%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EQ4.%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E5%93%AA%E4%BA%9B%20LED%20%E6%98%AF%E5%85%89%E6%BA%90%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E4%B8%8D%E5%91%8A%E8%AF%89%E6%88%91%E5%85%B7%E4%BD%93%E4%BF%A1%E6%81%AF%EF%BC%8C%E6%88%91%E5%B0%86%E5%BE%88%E9%9A%BE%E5%B8%AE%E6%82%A8%E8%BF%85%E9%80%9F%E6%89%BE%E5%88%B0%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20s32k312%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E6%82%A8%E6%98%AF%E5%90%A6%E6%8C%89%E7%85%A7%20%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fgetting-started-with-the-s32k312evb-q172-evaluation-board-for-general-purpose%3AGS-S32K312EVB-Q172%3Fsection%3Dplug-it-in_plug-it-in-2%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E3.2%20%E6%8F%92%E5%85%A5%E7%94%B5%E6%BA%90%3C%2FA%3E%3CSPAN%3E%E6%96%B9%E6%B3%95%E4%BD%BF%20FS26%20SBC%20%E5%9C%A8%E7%9C%8B%E9%97%A8%E7%8B%97%E7%A6%81%E7%94%A8%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%90%AF%E5%8A%A8%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E-%26gt%3B%20%E6%98%AF%E7%9A%84%EF%BC%8C4%20%E4%B8%AA%20LED%20%E7%81%AF%E4%BA%AE%E7%9D%80%EF%BC%8C%E6%8F%92%E5%A4%B4%E6%8F%92%E5%9C%A8%E6%88%91%E7%9A%84%2012%20%E4%BC%8F%E6%8F%92%E5%AD%94%E4%B8%AD%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E6%88%91%E7%9A%84%E6%9D%BF%E6%9C%89%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E6%98%AF%E4%BB%80%E4%B9%88%E6%84%8F%E6%80%9D%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E8%BF%99%E4%BA%9B%E6%84%8F%E6%80%9D%E4%BB%A5%E5%8F%8A%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3.........%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2134698%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20s32k312%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2134698%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%3C%2FP%3E%0A%3CP%3E%E6%9C%80%E5%90%8E%E4%B8%8B%E8%BD%BD%E7%9A%84%E7%A8%8B%E5%BA%8F%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3CBR%20%2F%3EFS26%20%E7%83%AD%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E5%8F%AF%E4%BB%A5%E5%9C%A8%20RESET%20%E5%BC%95%E8%84%9A%E4%B8%8A%E8%A7%82%E5%AF%9F%E5%88%B0%E4%BD%8E%E7%94%B5%E5%B9%B3%E8%84%89%E5%86%B2%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%E7%A4%BA%E6%B3%A2%E5%99%A8%E6%88%96%E9%80%BB%E8%BE%91%E5%88%86%E6%9E%90%E4%BB%AA%E6%9D%A5%E6%B5%8B%E9%87%8F%E9%A2%91%E7%8E%87%E3%80%82%3CBR%20%2F%3E%E6%82%A8%E6%98%AF%E5%90%A6%E6%8C%89%E7%85%A7%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fgetting-started-with-the-s32k312evb-q172-evaluation-board-for-general-purpose%3AGS-S32K312EVB-Q172%3Fsection%3Dplug-it-in_plug-it-in-2%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E3.2%20%E6%8F%92%E5%85%A5%E7%94%B5%E6%BA%90%E7%9A%84%3C%2FA%3E%E6%96%B9%E6%B3%95%E4%BD%BF%20FS26%20SBC%20%E5%9C%A8%E7%9C%8B%E9%97%A8%E7%8B%97%E7%A6%81%E7%94%A8%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%90%AF%E5%8A%A8%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%EF%BC%8C%3CBR%20%2F%3ERobin%3C%2FP%3E%3C%2FLINGO-BODY%3E
