s32k312 init sram ecc from jlink?
1,864件の閲覧回数
victory
Contributor V
Hi Nxp,
    i'm working on a ramcode application using jlink. currently i found a problem on in virgin chip. after jlink connect to chip,  sram in some area is '----' unaccessible,  it probably a ecc sram not initialized,  and i cant write ramcode to sram.
   so my question is how to init these sram on jlink at begining, is there a mininum reference code, or which code is MUST do in startup_cm7.s before lable "RamInit" , thanks.
3 返答(返信)
1,824件の閲覧回数
petervlna
I am not familiar with Jlink, but seems that user can execute debugger scripts.
https://wiki.segger.com/J-Link_script_files
I know that Lauterbach offers possibilities to fully control RAM init in statup scripts.
This is rather question for Segger then NXP.
Peter
1,820件の閲覧回数
victory
Contributor V
i found s32ds have a jlinkscript to use eDMA to init ecc ram, copy it and works.
1,837件の閲覧回数
victory
Contributor V
append:
i've found segger wiki https://wiki.segger.com/NXP_S32K3xx#ECC_RAM,  is it possible for me to use jlink initial the reset region of sram, currently i just use jlink write memory api(32bit /64bit)  will fail to write.
