s32k312 flexcan
s32k312 flexcan
428 次查看
fengba_360
Hello, if I use FLEX CAN RX FIFO to receive CAN messages, is there a way to know whether the received data frame is a standard frame or an extended frame,  my FIFO IdFilterTable is configured with both standard frame and extended frame entries。
5 回复数
384 次查看
fengba_360
I'm using an SDK, are there corresponding API functions?
382 次查看
Senlent
Hi@fengba_360
You should know that Enhance Receiver FIFO must enable CAN FD, so I don’t know what your intention is.
This CS bit should
include the IDE bit.
398 次查看
Senlent
Hi@fengba_360
314 次查看
fengba_360
Actually, my goal is to identify whether a frame received through the legacy FIFO is an extended frame or a standard frame. Based on your guidance, am I correct in understanding that I can check if the received message is a standard frame or an extended frame by performing the operation cs >> 22 & 0x01 on the structure's content? thanks!
299 次查看
Senlent
Hi@fengba_360
cs >> 22 & 0x01 ,yes, it's right to get IDE bit value.
