Hi NXP,
my environment is jlink v11 and s32DS. it works until yesterday, when starting debug, it can stop at main entry, then run step into, or any other operation, it goes to unknown state. the abnormal as attached.
1. debug can't halt CPU.
2. read sram failed.
but with the same hardware and elf file, i use ozone , it works normally.
here my debug cofig. it's same compare to it's working time.
