s32k312 Writing dflash Indicates whether the pflash program interrupts running
已解决
跳至解决方案
3,348 次查看
Neo1096
When I use S32K312 chip pflash storage program, dflash as storage data, that when I run the program, including a 10us interrupt program, then I write data to dflash in the main loop will affect the interrupt response? What if it does? Do you need to map interrupts to ram?
Looking forward to hearing from you. Thank you
1 解答
3,317 次查看
danielmartynek
Hi @Neo1096,
DFlash and PFlash are two separate blocks.
The program can run from PFlash, which can include the vector table and ISRs, while the DFlash is being programmed.
The ISRs must not access data in DFlash though.
在原帖中查看解决方案
4 回复数
3,318 次查看
danielmartynek
Hi @Neo1096,
3,308 次查看
WenWenDar
hi, I enable an interrupt of 100us per cycle. Then I erase one sector of data flash.
I called an API function called "C40_Ip_MainInterfaceSectorErase"  to erase data flash
During erasure, interrupts cannot be responded to.
After erasure, interrupts can be responded to normally.
So, how to achieve the goal to enter interrupts while erasing data flash?
Looking forward to your reply
3,289 次查看
danielmartynek
What version of the RTD drivers do you use?
3,267 次查看
WenWenDar
hi, I used RTD 1.0.0.  And this question has been solved. The solution can be found in the following link.
https://community.nxp.com/t5/S32K/During-the-process-of-writing-dflash-if-an-interrupt-occurs-will/m...
%3CLINGO-SUB%20id%3D%22lingo-sub-1864004%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Es32k312%20%E5%86%99%E5%85%A5dflash%20%E6%8C%87%E7%A4%BApflash%E7%A8%8B%E5%BA%8F%E6%98%AF%E5%90%A6%E4%B8%AD%E6%96%AD%E8%BF%90%E8%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1864004%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8S32K312%E8%8A%AF%E7%89%87%E7%9A%84pflash%E5%AD%98%E5%82%A8%E7%A8%8B%E5%BA%8F%EF%BC%8Cdflash%E4%BD%9C%E4%B8%BA%E5%AD%98%E5%82%A8%E6%95%B0%E6%8D%AE%EF%BC%8C%E9%82%A3%E5%BD%93%E6%88%91%E8%BF%90%E8%A1%8C%E7%A8%8B%E5%BA%8F%E7%9A%84%E6%97%B6%E5%80%99%EF%BC%8C%E5%8C%85%E6%8B%AC%E4%B8%80%E4%B8%AA10us%E7%9A%84%E4%B8%AD%E6%96%AD%E7%A8%8B%E5%BA%8F%EF%BC%8C%E9%82%A3%E4%B9%88%E6%88%91%E5%9C%A8%E4%B8%BB%E5%BE%AA%E7%8E%AF%E4%B8%AD%E5%BE%80dflash%E4%B8%AD%E5%86%99%E5%85%A5%E6%95%B0%E6%8D%AE%E6%98%AF%E5%90%A6%E4%BC%9A%E5%BD%B1%E5%93%8D%E4%B8%AD%E6%96%AD%E5%93%8D%E5%BA%94%EF%BC%9F%E5%A6%82%E6%9E%9C%E7%A1%AE%E5%AE%9E%E5%A6%82%E6%AD%A4%E6%80%8E%E4%B9%88%E5%8A%9E%EF%BC%9F%E6%82%A8%E9%9C%80%E8%A6%81%E5%B0%86%E4%B8%AD%E6%96%AD%E6%98%A0%E5%B0%84%E5%88%B0%20RAM%20%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%E6%9C%9F%E5%BE%85%E6%82%A8%E7%9A%84%E5%9B%9E%E9%9F%B3%E3%80%82%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1866637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9As32k312%E5%86%99%E5%85%A5dflash%E6%8C%87%E7%A4%BApflash%E7%A8%8B%E5%BA%8F%E6%98%AF%E5%90%A6%E4%B8%AD%E6%96%AD%E8%BF%90%E8%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1866637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20RTD%201.0.0%E3%80%82%E8%80%8C%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%B7%B2%E7%BB%8F%E5%BE%97%E5%88%B0%E8%A7%A3%E5%86%B3%E3%80%82%3CSPAN%3E%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E5%8F%AF%E4%BB%A5%E5%9C%A8%E4%BB%A5%E4%B8%8B%E9%93%BE%E6%8E%A5%E4%B8%AD%E6%89%BE%E5%88%B0%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FDuring-the-process-of-writing-dflash-if-an-interrupt-occurs-will%2Fm-p%2F1866055%2Femcs_t%2FS2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufExXN0lRVzlGRkJaSlowfDE4NjYwNTV8U1VCU0NSSVBUSU9OU3xoSw%23M35386%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FDuring-the-process-of-writing-dflash-if-an-interrupt-occurs-will%2Fmp%2F1866055%2Femcs_t%2FS2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufExXN0lRVzlGRkJaSlowfDE4NjYwNTV8U1VCU0NSSVBUSU9OU3xoSw%23M35386%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1865141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9As32k312%E5%86%99%E5%85%A5dflash%E6%8C%87%E7%A4%BApflash%E7%A8%8B%E5%BA%8F%E6%98%AF%E5%90%A6%E4%B8%AD%E6%96%AD%E8%BF%90%E8%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1865141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CSPAN%3E%E6%88%91%E5%90%AF%E7%94%A8%E4%BA%86%E6%AF%8F%E5%91%A8%E6%9C%9F100us%E7%9A%84%E4%B8%AD%E6%96%AD%E3%80%82%E7%84%B6%E5%90%8E%E6%88%91%E6%93%A6%E9%99%A4%E4%BA%86%E4%B8%80%E4%B8%AA%E6%95%B0%E6%8D%AE%E9%97%AA%E5%AD%98%E6%89%87%E5%8C%BA%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E8%B0%83%E7%94%A8%E4%BA%86%E4%B8%80%E4%B8%AA%E5%90%8D%E4%B8%BA%E2%80%9CC40_Ip_MainInterfaceSectorErase%E2%80%9D%E7%9A%84%20API%20%E5%87%BD%E6%95%B0%E6%9D%A5%E6%93%A6%E9%99%A4%E6%95%B0%E6%8D%AE%E9%97%AA%E5%AD%98%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%93%A6%E9%99%A4%E6%9C%9F%E9%97%B4%EF%BC%8C%E6%97%A0%E6%B3%95%E5%93%8D%E5%BA%94%E4%B8%AD%E6%96%AD%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%93%A6%E9%99%A4%E5%90%8E%E5%8D%B3%E5%8F%AF%E6%AD%A3%E5%B8%B8%E5%93%8D%E5%BA%94%E4%B8%AD%E6%96%AD%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%82%A3%E4%B9%88%EF%BC%8C%E5%A6%82%E4%BD%95%E5%AE%9E%E7%8E%B0%E6%93%A6%E9%99%A4%E6%95%B0%E6%8D%AEflash%E7%9A%84%E5%90%8C%E6%97%B6%E8%BF%9B%E5%85%A5%E4%B8%AD%E6%96%AD%E7%9A%84%E7%9B%AE%E7%9A%84%E5%91%A2%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%9C%9F%E5%BE%85%E4%BD%A0%E7%9A%84%E7%AD%94%E5%A4%8D%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
