s32k312 Platform ISR, IntCtrl_ip ISR difference
coo
I'm trying to use lin channel 5.
But there's an interruption setting on the platform Interrupt setting found for IntCtrl_lp.
May I know the difference between the two?
Which module's isr should I enable if I try to use an interrupt on Lean Channel 5?
Does it matter which one of the two I use?
danielmartynek
Hello @coo,
If this is an autosar project, use the Platform driver.
If it is a non-autosar project, and you don't use the Plaform driver in it, you need to use the IntCtrl_lp driver.
