s32k312 Cyclic wake-up current
795 次查看
mogilipuri_harish
hello team
we are using S32K312 uC. can you provide the cyclic current for S32K312.
785 次查看
danielmartynek
Hello @mogilipuri_harish,
This has to be calculated for each use case.
In the S32K3xx Datasheet rev.6, there is an example:
To estimate the RUN and STANDBY consumption in your application, use the S32K Power Estimation Tool (PET).
https://www.nxp.com/products/processors-and-microcontrollers/s32-automotive-platform/s32k-auto-gener...
