s32k148 boot loader
s32k148 boot loader
sathish_sekar
Hello All,
I am working on to modify the bootloader / startup sequence for s32k148.
Able to identify the bootloader code, but i required to modify the startup code.
i.e in startupcode I want to select the another bootloader(i require to use multi bootloader, selection is based on switch/jumper settings.)
Could any help me to identify the startupcode to modify?
Startup code files are available in my PC in the following path   ...\Bootloader_Software\S32K148_bootloader\Project_Settings\Startup_Code
But unable to identify the sequence, from where boot loader sequence is called.
NOTE:
I am using windows PC, and installed necessary softwares/ not using linux.
dianabatrlova
I have already sent you the answer to your first request with the same question below:
https://community.nxp.com/message/1141058
If you have any questions or something is not clear, please, let me know.
Diana
