s32k144 MPU and Flash Protection
kmh48301
Hi.
I need to protect and unprotect flash memory dynamically.
I found the Flash Protection by Flash Configuration Field and FLASH_DRV_SetDFlashProtection
cannot unprotect dynamically. (can protect dynamically)
and Flash Protection by MPU is not the solution.
Even though I protect the flash memory not to Program by MPU (deleting the right to write by CPU), FTFC command works.
Can you please give me any alternative?
Best Regards
Phillip
danielmartynek
Hello Phillip,
It was under a discussion in the thread below, please scroll down to the last comment.
https://community.nxp.com/t5/S32K/S32K144-System-MPU-fails-to-write-protect-Flash-memory-region/m-p/...
Thank you,
BR, Daniel
kmh48301
Hi, Daniel
Thank you so much for great solution!
danielmartynek
Hello Phillip,
Thank you,
BR, Daniel
