s32k118 CAN Rx Interrupt
2,996 次查看
ArushThomas
Hi all,
I am using the s32k118 MCU and need to interface with a CAN bus. I've been polling the CAN bus every 100ms with the CAN_Receive() function to retrieve any messages from the bus, but unfortunately I do miss a lot of messages, since there are more than one message on the bus every 100ms.
My end goal is to asynchronously add all received messages to a Queue of CAN messages, which I can parse periodically. I was hoping to accomplish this with a CAN Rx Interrupt, which would be triggered whenever the MCU detects a message on the bus. Unfortunately, I'm not able to set up such an ISR.
I've tried setting up an ISR with the interrupt_manager component, on the CAN0_ORed_0_31_MB_IRQn IRQ. But it seems my ISR is being triggered only after I call CAN_Receive() in my main() function. This does not meet my requirements, as I was hoping to all the CAN_Receive() function exclusively in the ISR. Furthermore, after being triggered once, the code appears to get stuck in continuously calling the ISR over and over.
I tried installing a callback function with CAN_InstallEventCallback(), but again, the callback function is only called after I call CAN_Receive() or CAN_Send(). So again, it doesn't seem like I can depend on the Callback to catch all messages from the bus.
Finally, I used the Rx FIFO feature, which does successfully add all messages to a the Mailbox 0 in a buffer-type format. This is what I need... except it's limited to a maximum of 6 messages.
I'm anticipating a need for ~16 messages to be buffered at a time.
To illustrate the issues I've faced with Polling, ISR and Callback, I've attached a "CAN_Example" project. Hope it serves to further clarify the problem.
How do I accomplish this task, of buffering incoming CAN messages for future parsing?
标记 (2)
2,971 次查看
Senlent
Hi@ArushThomas
You can refer to the demo in the link below which shows how to receive or transmit CAN frames using MB or FIFO interrupts.
https://community.nxp.com/t5/S32K-Knowledge-Base/S32K1xx-FlexCAN-Mask-Setting-Demo/ta-p/1519753
2,972 次查看
Senlent
Hi@ArushThomas
2,953 次查看
ArushThomas
Thanks, that solves the issue!
Seems like the key point I'd missed was to call FLEXCAN_DRV_Receive(),  FLEXCAN_DRV_RxFifo() or CAN_Receive() at least once on each Mailbox, for the Callback to work properly.
%3CLINGO-SUB%20id%3D%22lingo-sub-1886051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Es32k118%20CAN%20Rx%E4%B8%AD%E6%96%AD%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1886051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20s32k118%20MCU%20%E5%B9%B6%E4%B8%94%E9%9C%80%E8%A6%81%E4%B8%8E%20CAN%20%E6%80%BB%E7%BA%BF%E8%BF%9E%E6%8E%A5%E3%80%82%E6%88%91%E4%B8%80%E7%9B%B4%E4%BD%BF%E7%94%A8%20CAN_Receive()%20%E5%87%BD%E6%95%B0%E6%AF%8F%20100%20%E6%AF%AB%E7%A7%92%E8%BD%AE%E8%AF%A2%E4%B8%80%E6%AC%A1%20CAN%20%E6%80%BB%E7%BA%BF%EF%BC%8C%E4%BB%A5%E4%BB%8E%E6%80%BB%E7%BA%BF%E4%B8%AD%E6%A3%80%E7%B4%A2%E4%BB%BB%E4%BD%95%E6%B6%88%E6%81%AF%EF%BC%8C%E4%BD%86%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E6%88%91%E7%A1%AE%E5%AE%9E%E9%94%99%E8%BF%87%E4%BA%86%E5%BE%88%E5%A4%9A%E6%B6%88%E6%81%AF%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%AF%8F%20100%20%E6%AF%AB%E7%A7%92%E6%80%BB%E7%BA%BF%E4%B8%8A%E5%B0%B1%E4%BC%9A%E5%87%BA%E7%8E%B0%E5%A4%9A%E6%9D%A1%E6%B6%88%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E6%9C%80%E7%BB%88%E7%9B%AE%E6%A0%87%E6%98%AF%E5%B0%86%E6%89%80%E6%9C%89%E6%8E%A5%E6%94%B6%E5%88%B0%E7%9A%84%E6%B6%88%E6%81%AF%E5%BC%82%E6%AD%A5%E6%B7%BB%E5%8A%A0%E5%88%B0%20CAN%20%E6%B6%88%E6%81%AF%E9%98%9F%E5%88%97%E4%B8%AD%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%88%91%E5%8F%AF%E4%BB%A5%E5%AE%9A%E6%9C%9F%E8%A7%A3%E6%9E%90%E8%BF%99%E4%BA%9B%E6%B6%88%E6%81%AF%E3%80%82%E6%88%91%E5%B8%8C%E6%9C%9B%E9%80%9A%E8%BF%87%20CAN%20Rx%20%E4%B8%AD%E6%96%AD%E6%9D%A5%E5%AE%9E%E7%8E%B0%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%8C%E5%8F%AA%E8%A6%81%20MCU%20%E6%A3%80%E6%B5%8B%E5%88%B0%E6%80%BB%E7%BA%BF%E4%B8%8A%E7%9A%84%E6%B6%88%E6%81%AF%EF%BC%8C%E5%B0%B1%E4%BC%9A%E8%A7%A6%E5%8F%91%E8%AF%A5%E4%B8%AD%E6%96%AD%E3%80%82%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E8%AE%BE%E7%BD%AE%E8%BF%99%E6%A0%B7%E7%9A%84%20ISR%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E5%9C%A8%20CAN0_ORed_0_31_MB_IRQn%20IRQ%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20interrupt_manager%20%E7%BB%84%E4%BB%B6%E8%AE%BE%E7%BD%AE%20ISR%E3%80%82%E4%BD%86%E4%BC%BC%E4%B9%8E%E5%8F%AA%E6%9C%89%E5%9C%A8%E6%88%91%E8%B0%83%E7%94%A8%20main()%20%E5%87%BD%E6%95%B0%E4%B8%AD%E7%9A%84%20CAN_Receive()%3CEM%3E%E5%90%8E%3C%2FEM%3E%E6%88%91%E7%9A%84%20ISR%20%E6%89%8D%E4%BC%9A%E8%A2%AB%E8%A7%A6%E5%8F%91%E3%80%82%E8%BF%99%E4%B8%8D%E7%AC%A6%E5%90%88%E6%88%91%E7%9A%84%E8%A6%81%E6%B1%82%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E5%B8%8C%E6%9C%9B%E5%9C%A8%20ISR%20%E4%B8%AD%E4%B8%93%E9%97%A8%E4%BD%BF%E7%94%A8%20CAN_Receive()%20%E5%87%BD%E6%95%B0%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8C%E5%9C%A8%E8%A7%A6%E5%8F%91%E4%B8%80%E6%AC%A1%E4%B9%8B%E5%90%8E%EF%BC%8C%E4%BB%A3%E7%A0%81%E4%BC%BC%E4%B9%8E%E9%99%B7%E5%85%A5%E4%B8%8D%E6%96%AD%E9%87%8D%E5%A4%8D%E8%B0%83%E7%94%A8%20ISR%20%E7%9A%84%E7%8A%B6%E6%80%81%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20CAN_InstallEventCallback()%20%E5%AE%89%E8%A3%85%E5%9B%9E%E8%B0%83%E5%87%BD%E6%95%B0%EF%BC%8C%E4%BD%86%E5%90%8C%E6%A0%B7%EF%BC%8C%E5%8F%AA%E6%9C%89%E5%9C%A8%E8%B0%83%E7%94%A8%20CAN_Receive()%20%E6%88%96%20CAN_Send()%3CEM%3E%E5%90%8E%3C%2FEM%3E%E6%89%8D%E4%BC%9A%E8%B0%83%E7%94%A8%E5%9B%9E%E8%B0%83%E5%87%BD%E6%95%B0%E3%80%82%E6%89%80%E4%BB%A5%EF%BC%8C%E5%86%8D%E6%AC%A1%E7%9C%8B%E6%9D%A5%EF%BC%8C%E6%88%91%E4%BC%BC%E4%B9%8E%E4%B8%8D%E8%83%BD%E4%BE%9D%E9%9D%A0%E5%9B%9E%E8%B0%83%E6%9D%A5%E6%8D%95%E8%8E%B7%E6%9D%A5%E8%87%AA%E6%80%BB%E7%BA%BF%E7%9A%84%E6%89%80%E6%9C%89%E6%B6%88%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%80%E5%90%8E%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%20Rx%20FIFO%20%E5%8A%9F%E8%83%BD%EF%BC%8C%E8%AF%A5%E5%8A%9F%E8%83%BD%E7%A1%AE%E5%AE%9E%E6%88%90%E5%8A%9F%E5%9C%B0%E5%B0%86%E6%89%80%E6%9C%89%E6%B6%88%E6%81%AF%E4%BB%A5%E7%BC%93%E5%86%B2%E5%8C%BA%E6%A0%BC%E5%BC%8F%E6%B7%BB%E5%8A%A0%E5%88%B0%E9%82%AE%E7%AE%B1%200%E3%80%82%E8%BF%99%E5%B0%B1%E6%98%AF%E6%88%91%E9%9C%80%E8%A6%81%E7%9A%84...%E9%99%A4%E4%BA%86%E6%9C%80%E5%A4%9A%206%20%E6%9D%A1%E6%B6%88%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ArushThomas_0-1718187128272.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ArushThomas_0-1718187128272.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F283690i91B8E4DC2CACF1C2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22ArushThomas_0-1718187128272.png%22%20alt%3D%22ArushThomas_0-1718187128272.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E9%A2%84%E8%AE%A1%E4%B8%80%E6%AC%A1%E9%9C%80%E8%A6%81%E7%BC%93%E5%86%B2%E5%A4%A7%E7%BA%A6%2016%20%E6%9D%A1%E6%B6%88%E6%81%AF%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%B8%BA%E4%BA%86%E8%AF%B4%E6%98%8E%E6%88%91%E5%9C%A8%E8%BD%AE%E8%AF%A2%E3%80%81ISR%20%E5%92%8C%E5%9B%9E%E8%B0%83%E6%96%B9%E9%9D%A2%E9%81%87%E5%88%B0%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E9%99%84%E5%8A%A0%E4%BA%86%E4%B8%80%E4%B8%AA%E2%80%9CCAN_Example%E2%80%9D%E9%A1%B9%E7%9B%AE%E3%80%82%E5%B8%8C%E6%9C%9B%E5%AE%83%E6%9C%89%E5%8A%A9%E4%BA%8E%E8%BF%9B%E4%B8%80%E6%AD%A5%E6%BE%84%E6%B8%85%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E5%A6%82%E4%BD%95%E5%AE%8C%E6%88%90%E8%BF%99%E9%A1%B9%E4%BB%BB%E5%8A%A1%EF%BC%8C%E5%8D%B3%E7%BC%93%E5%86%B2%E4%BC%A0%E5%85%A5%E7%9A%84%20CAN%20%E6%B6%88%E6%81%AF%E4%BB%A5%E4%BE%9B%E5%B0%86%E6%9D%A5%E8%A7%A3%E6%9E%90%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1886627%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9As32k118%20CAN%20Rx%E4%B8%AD%E6%96%AD%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1886627%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%E9%97%AE%E9%A2%98%E8%A7%A3%E5%86%B3%E4%BA%86%EF%BC%81%3C%2FP%3E%3CP%3E%E4%BC%BC%E4%B9%8E%E6%88%91%E9%94%99%E8%BF%87%E7%9A%84%E5%85%B3%E9%94%AE%E7%82%B9%E6%98%AF%3CSPAN%3E%E5%9C%A8%E6%AF%8F%E4%B8%AA%E9%82%AE%E7%AE%B1%E4%B8%8A%E8%87%B3%E5%B0%91%E8%B0%83%E7%94%A8%E4%B8%80%E6%AC%A1%3C%2FSPAN%3E%3CSPAN%3EFLEXCAN_DRV_Receive()%E3%80%81%3C%2FSPAN%3E%20FLEXCAN_DRV_RxFifo()%20%E6%88%96%20CAN_Receive()%EF%BC%8C%E4%BB%A5%E4%BD%BF%E5%9B%9E%E8%B0%83%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1886509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9As32k118%20CAN%20Rx%E4%B8%AD%E6%96%AD%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1886509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22mailto%3AHi%40ArushThomas%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E4%BD%A0%E5%A5%BD%40ArushThomas%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E4%B8%8B%E9%9D%A2%E9%93%BE%E6%8E%A5%E4%B8%AD%E7%9A%84%E6%BC%94%E7%A4%BA%EF%BC%8C%E5%85%B6%E4%B8%AD%E5%B1%95%E7%A4%BA%E4%BA%86%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20MB%20%E6%88%96%20FIFO%20%E4%B8%AD%E6%96%AD%E6%8E%A5%E6%94%B6%E6%88%96%E4%BC%A0%E8%BE%93%20CAN%20%E5%B8%A7%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K1xx-FlexCAN-Mask-Setting-Demo%2Fta-p%2F1519753%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K1xx-FlexCAN-Mask-Setting-Demo%2Fta-p%2F1519753%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
