s32ds for s32k3 code generator error
3,358件の閲覧回数
huangjia
I add a FlexCAN IP module to code generator on s32ds for s32k3, but it doesn't generate any code file of FlexCAN. I've already generated some modules such as uart, platform, mcu, mcl etc. Should i create a new project?
3 返答(返信)
3,351件の閲覧回数
Robin_Shen
Hi huangjia,
What's the version of S32K3 RTD installed with S32DS3.4? Did you update the latest RTD?
I am using S32K3 RTD AUTOSAR 4.4 Version 1.0.0 and can’t reproduce the phenomenon you said.
Robin
3,341件の閲覧回数
huangjia
I am using S32K3 RTD AUTOSAR 4.4 Version 1.0.0 also, but i generated some Mcal file. I uploaded the whole project(split into 2 files), please take look at the project if conveniently. Thanks a lot.
3,275件の閲覧回数
Robin_Shen
Sorry for late reply. I'm not sure why your project had always removed the FlexCAN generation files, however when we tried with a new project and added the same components, we couldn't see the issue. Please find the attachment. So maybe it's a good idea to try with a new project and add the same components.
