libgpiod tools not working on s32g
1,662件の閲覧回数
bou6
Knowing that for playing with gpios, the sysfs api is now deprecated and it is replaced by the new libgpiod https://git.kernel.org/pub/scm/libs/libgpiod/libgpiod.git/about/, I tried to compile the library and use it on my target (S32G Eval board), unfortunately I got some errors that let me feel that the library is not yet fully implemented, so the question is: is the libgpiod supported ?, is there any example on how to use it? maybe I am using it wrong. This is the error I got : gpioinfo 0 gpiochip0 - 19 lines: gpioinfo: unable to retrieve the line object from chip: Invalid argument Expected result: gpioinfo 0 gpiochip0 - 19 lines: line 0: unnamed unused input active-high [...]
1,645件の閲覧回数
bpe
This Forum is not valid for questions about S32G. I will contact you by e-Mail for this time with a quick advise on how you can start with Linux on S32G, to receive more help, please use only tickets
Platon
