install TCP\IP stack create a question.
6,564件の閲覧回数
leonordo
hello,everyone:
i install S32K344 TCP\IP statck create a question,install fail.
Reason:
Operation details Software being installed: com.nxp.RTD.S32K396.root.feature.feature.group 3.0.0.202303311831 Missing requirement: com.nxp.RTD.S32K396.root.feature.feature.group 3.0.0.202303311831 requires 'org.eclipse.equinox.p2.iu; com.nxp.s32ds.s32k396.dev.feature.feature.group 1.0.0' but it could not be found
Should i intall this stack acorrding to "window->perferences->S32DS Extensions and Updates" or "Help->Install new software"?
3 返答(返信)
6,545件の閲覧回数
lukaszadrapa
Hi @leonordo
there's always Release Note file for each SW package like this:
And this file contains detailed description how to install such package and what needs to be installed before that. See please section "6.4 Installation of TCP/IP Stack package over RTD" in this file. Have you followed all the steps?
Lukas
6,525件の閲覧回数
leonordo
hello,Lukas:
  I follow this document when install TCP\IP stack,but install end,example peoject about TCP\IP doesn't appear.
6,557件の閲覧回数
leonordo
this is my fail reason acorrding to "window->perferences->S32DS Extensions and Updates" and then select "help->S32DS extensions and updates" to update "TCPIP_STACK for S32K3XX version 1.0.3"
