hse_interface.h missing from CRYPTO_43_HSE
Rmpr
I want to try to encrypt some messages using the HSE, I've configured the CRYPTO_43_HSE to use the AES cypher. After updating the code in the peripherals, it says that the hse_interface.h file is missing.
My target device is the S32K342, and I'm using RTD's 4.0.0. Is there any way to solve this?
Thank you in advance
lukaszadrapa
Hi @Rmpr
Please take a look at section "3.2.0.0.8 HSE Interface Files:" in the Crypto Integration Manual which can be found at this path:
c:\NXP\S32DS.3.5\S32DS\software\PlatformSDK_S32K3\RTD\Crypto_43_HSE_TS_T40D34M40I0R0\doc\RTD_CRYPTO_43_HSE_IM.pdf
It says that interface files need to be copied from HSE Firmware folder like this (just an example, it depends on used firmware version):
c:\NXP\HSE_FW_S32K344_0_2_40_0\hse_ab_swap\interface\
Lukas
Rmpr
I've located the files, but it doesn't say where I should copy them to.
lukaszadrapa
Hi @Rmpr
Lukas
%3CLINGO-SUB%20id%3D%22lingo-sub-2084508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ehse_interface.h%20missing%20from%20CRYPTO_43_HSE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2084508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EI%20want%20to%20try%20to%20encrypt%20some%20messages%20using%20the%20HSE%2C%20I've%20configured%20the%20CRYPTO_43_HSE%20to%20use%20the%20AES%20cypher.%20After%20updating%20the%20code%20in%20the%20peripherals%2C%20it%20says%20that%20the%20hse_interface.h%20file%20is%20missing.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EMy%20target%20device%20is%20the%20S32K342%2C%20and%20I'm%20using%20RTD's%204.0.0.%20Is%20there%20any%20way%20to%20solve%20this%3F%3C%2FP%3E%3CP%3EThank%20you%20in%20advance%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2084611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20hse_interface.h%20missing%20from%20CRYPTO_43_HSE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2084611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI've%20located%20the%20files%2C%20but%20it%20doesn't%20say%20where%20I%20should%20copy%20them%20to.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2084595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20hse_interface.h%20missing%20from%20CRYPTO_43_HSE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2084595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F220829%22%20target%3D%22_blank%22%3E%40Rmpr%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPlease%20take%20a%20look%20at%20section%20%223.2.0.0.8%20HSE%20Interface%20Files%3A%22%20in%20the%20Crypto%20Integration%20Manual%20which%20can%20be%20found%20at%20this%20path%3A%3C%2FP%3E%0A%3CP%3Ec%3A%5CNXP%5CS32DS.3.5%5CS32DS%5Csoftware%5CPlatformSDK_S32K3%5CRTD%5CCrypto_43_HSE_TS_T40D34M40I0R0%5Cdoc%5CRTD_CRYPTO_43_HSE_IM.pdf%3C%2FP%3E%0A%3CP%3EIt%20says%20that%20interface%20files%20need%20to%20be%20copied%20from%20HSE%20Firmware%20folder%20like%20this%20(just%20an%20example%2C%20it%20depends%20on%20used%20firmware%20version)%3A%3C%2FP%3E%0A%3CP%3Ec%3A%5CNXP%5CHSE_FW_S32K344_0_2_40_0%5Chse_ab_swap%5Cinterface%5C%3C%2FP%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E
