hse fw installation
hse fw installation
youxi
Hello:
I have installed hse fw (ab _ swap) on the S32k312, but only in a block whose address starts with 0x00500000. I want to know how to install hse fw (ab _ swap) into a block starting with an address of 0x00400000
VaneB
Hi @youxi
As the IVT is not provided, FW-IMG is placing the at address 0x00400000 to start the firmware installation.
So it is not possible to install HSE at this memory block.
B.R.
VaneB
youxi
hi @VaneB
But the hse only works when both blocks have the hse firmware. All I want to know how to make both blocks can install on the hse firmware
VaneB
Hi @youxi
As all the HSE information is under NDA, please create a support ticket.
