how use can 2.0b protocol communication?
rlaxortn
i am using s32k314 and s32ds 3.6, RTD 4.0.0 Version.
it is not can 2.0a and can-fd.
i wanna use 2.0b can protocol.
bcause i gonna use extended CAN ID.
would you know me a can configure and example code for using CAN 2.0B?
it is current setting about can.
it work for CAN 2.0A.
thanks to help.
Tags (3)
PetrS
it would be enough to set rx_info parameter accordingly before MB is configured
rx_info.msg_id_type = FLEXCAN_MSG_ID_EXT;
FlexCAN_Ip_ConfigRxMb(INST_FLEXCAN_0, RX_MB_IDX, &rx_info, 0xFACE);
Also check how mask acceptance register is set.
BR, Petr
