how to start with clock_ip_ReferencePoints
jimmy623
In S32k358, how can I use  already defined clk ?
Thanks!
danielmartynek
Hello @jimmy623,
I see, it is a bug in RTD 3.0.0, it has been fixed in RTD 4.0.0
danielmartynek
Hello @jimmy623,
The references can be used by other RTD drivers.
Such as BaseNXP Osif Config, see below.
There is no list of drivers dependent on the clock reference points.
jimmy623
How can i use to LPUART driver ?
default Baud rate is 40M ,which mismatch to Reference design.
Thanks!
danielmartynek
Hello @jimmy623,
The LPUART modules are clocked either by AIPS_PLAT_CLK or AIPS_SLOW_CLK depending on the number of the instance, this cannot be changed. Refer to the RM.
jimmy623
This is a Bug?
danielmartynek
Which RTD version is it?
Thank you.
jimmy623
RTD AUTOSAR 4.7
danielmartynek
That is the Autosar version, I mean RTD version.
For example, in this version, it is correct:
jimmy623
I will check RTD 4.0 later
danielmartynek
Hello @jimmy623,
