header file “hse_interface.h” not found
gumu
Contributor V
I am using the example Hse_Ip_AesEncAsyncIrq_S32K344 in RTD 4.0, and during compilation, I encountered the error: “fatal error: hse_interface.h: No such file or directory.” Do I lack some dependencies?
lukaszadrapa
Hi @gumu
Take a look at Integration Manual which can be found on path like this:
c:\NXP\S32DS.3.5\S32DS\software\PlatformSDK_S32K3\RTD\Crypto_43_HSE_TS_T40D34M40I0R0\doc\RTD_CRYPTO_43_HSE_IM.pdf
See section:
3.2 Files required for compilation
... and especially:
3.2.0.0.8 HSE Interface Files
The interface files need to be copied from your HSE Firmware folder. From path like this:
c:\NXP\HSE_FW_S32K344_0_2_40_0\hse_ab_swap\interface\
Lukas
