ftm3 interrupt service routine
已解决
跳至解决方案
1,433 次查看
sandeepc
hi community i need generate a 1sec delay by using periodic timer but i couldnt able to find isr routine its going to the default isr so how can i know exact isr for s32k144w
S32 Design Studio for S32 Platform
Version: 3.4
Build id: 201217 (Update 3)
sdk=3.4
1 解答
1,416 次查看
Senlent
Hi@sandeepc
you can refer to "ftm_ periodic_interrupt_s32k144w"  if you installed RTM 4.0.X in S32 DS V3.4
在原帖中查看解决方案
1 回复
1,417 次查看
Senlent
Hi@sandeepc
