freeMASTER
freeMASTER
REWQ
FREEMASTER3.2,第二次安装时,由于第一次没有卸载干净导致无法再次安装。正常情况不应该是覆盖第一次吗。现在无法安装
petervlna
Freemaster 3.2 failed to install on its second attempt because the first installation wasn't completely uninstalled. Shouldn't it normally overwrite the first one? It's now unable to install.
No — installers like FreeMASTER (ZeroG / InstallAnywhere–based) typically will not just overwrite a broken previous install.
What you’re seeing is actually expected behavior.
Please have a look at this thread:
https://community.nxp.com/t5/FreeMASTER/Deinstalltion-FreeMaster-3-2/m-p/1593805
Peter
%3CLINGO-SUB%20id%3D%22lingo-sub-2380512%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3EfreeMASTER%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2380512%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EFREEMASTER%203.2%3A%20I%20was%20unable%20to%20reinstall%20it%20because%20the%20previous%20version%20wasn't%20completely%20uninstalled.%20Normally%2C%20shouldn't%20it%20just%20overwrite%20the%20previous%20installation%3F%20Now%20I%20can't%20install%20it.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2380586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20freeMASTER%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2380586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3EFreemaster%203.2%20failed%20to%20install%20on%20its%20second%20attempt%20because%20the%20first%20installation%20wasn't%20completely%20uninstalled.%20Shouldn't%20it%20normally%20overwrite%20the%20first%20one%3F%20It's%20now%20unable%20to%20install.%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3ENo%20%E2%80%94%20installers%20like%20FreeMASTER%20(ZeroG%20%2F%20InstallAnywhere%E2%80%93based)%20typically%20will%20not%20just%20overwrite%20a%20broken%20previous%20install.%3CBR%20%2F%3EWhat%20you%E2%80%99re%20seeing%20is%20actually%20expected%20behavior.%3C%2FP%3E%0A%3CP%3EPlease%20have%20a%20look%20at%20this%20thread%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FFreeMASTER%2FDeinstalltion-FreeMaster-3-2%2Fm-p%2F1593805%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FFreeMASTER%2FDeinstalltion-FreeMaster-3-2%2Fm-p%2F1593805%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EPeter%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
