eMcem_Init() return is E_NOT_OK
已解决
跳至解决方案
3,700 次查看
Sylvia_jiang
I am working on the EVB Q172 with testing EIM/ERM in example code SPD_101_S32K344, Bist/eMcem/SafetyBase modules imported keep defaults. I find NCF_S0 value is always is 1 in debugging eMcem_Init(). What shall I do to clear NCF0 fault and have eMcem_Init() performed successfully?
标记 (1)
1 解答
3,672 次查看
cuongnguyenphu
I found a demo project in S32K3 SPD 1.0.2 in below link:
 https://nxp.flexnetoperations.com/control/frse/download?agree=Accept&element=14032037
This demo use eMcem_Init() successfully, so you can refer to it
在原帖中查看解决方案
3 回复数
3,673 次查看
cuongnguyenphu
3,113 次查看
Sjoshi11
Hi, the link you've given looks useful to me. but I am not able to access it. It is redirecting me to login page again and again. could you give some code snippet or a different link which might work?
3,088 次查看
cuongnguyenphu
