debug problem when pmic is not in debug mode
ChangruiKhoo
我使用的是S32K388芯片,并且使用了pmic  FS26(MFS2633HMDC3AD)
我遇到了这样的问题,当我的pmic不属于debug 模式时,我无法通过调试器MULTI LINK debug mcu S32K388,这是否正常呢,
我的pmic的mcal配置如下,我关闭了看门狗的reaction,问题还是存在
<?xml version='1.0'?>
<datamodel version="7.0"
xmlns="http://www.tresos.de/_projects/DataModel2/16/root.xsd"
xmlns:a="http://www.tresos.de/_projects/DataModel2/16/attribute.xsd"
xmlns:v="http://www.tresos.de/_projects/DataModel2/06/schema.xsd"
xmlns:d="http://www.tresos.de/_projects/DataModel2/06/data.xsd">
<d:ctr type="AUTOSAR" factory="autosar"
xmlns:ad="http://www.tresos.de/_projects/DataModel2/08/admindata.xsd"
xmlns:cd="http://www.tresos.de/_projects/DataModel2/08/customdata.xsd"
xmlns:f="http://www.tresos.de/_projects/DataModel2/14/formulaexpr.xsd"
xmlns:icc="http://www.tresos.de/_projects/DataModel2/08/implconfigclass.xsd"
xmlns:mt="http://www.tresos.de/_projects/DataModel2/11/multitest.xsd"
xmlns:variant="http://www.tresos.de/_projects/DataModel2/11/variant.xsd">
<d:lst type="TOP-LEVEL-PACKAGES">
<d:ctr name="Sbc_fs26" type="AR-PACKAGE">
<d:lst type="ELEMENTS">
<d:chc name="Sbc_fs26" type="AR-ELEMENT" value="MODULE-CONFIGURATION">
<d:ctr type="MODULE-CONFIGURATION">
<a:a name="DEF" value="ASPath:/TS_T40D34M60I0R0/Sbc_fs26"/>
<d:var name="POST_BUILD_VARIANT_USED" type="BOOLEAN" value="false"/>
<d:var name="IMPLEMENTATION_CONFIG_VARIANT" type="ENUMERATION"
value="VariantPreCompile">
<a:a name="IMPORTER_INFO" value="@DEF"/>
</d:var>
<d:ctr name="CommonPublishedInformation" type="IDENTIFIABLE">
<d:var name="ModuleId" type="INTEGER" value="255">
</d:var>
<d:var name="VendorId" type="INTEGER" value="43">
</d:var>
<d:var name="ArReleaseMajorVersion" type="INTEGER" value="4">
</d:var>
<d:var name="ArReleaseMinorVersion" type="INTEGER" value="9">
</d:var>
<d:var name="ArReleaseRevisionVersion" type="INTEGER" value="0">
</d:var>
<d:var name="SwMajorVersion" type="INTEGER" value="6">
</d:var>
<d:var name="SwMinorVersion" type="INTEGER" value="0">
</d:var>
<d:var name="SwPatchVersion" type="INTEGER" value="0">
</d:var>
</d:ctr>
<d:ctr name="SbcDemEventParameterRefs" type="IDENTIFIABLE">
<a:a name="ENABLE" value="false"/>
<d:ref name="SBC_FS26_E_TIMEOUT" type="REFERENCE" >
</d:ref>
<d:ref name="SBC_FS26_E_DEVICE_STATUS" type="REFERENCE" >
</d:ref>
</d:ctr>
<d:ctr name="SpiConfig" type="IDENTIFIABLE">
<d:ref name="SpiChannelRef" type="REFERENCE"
value="ASPath:/Spi/Spi/SpiDriver/SpiChannel_FS26"/>
<d:ref name="SpiSequenceRef" type="REFERENCE"
value="ASPath:/Spi/Spi/SpiDriver/SpiSequence_FS26"/>
<d:var name="SpiAsync" type="BOOLEAN" value="false">
</d:var>
<d:var name="SbcQueueLength" type="INTEGER" value="16">
</d:var>
</d:ctr>
<d:ctr name="DriverConfig" type="IDENTIFIABLE">
<d:var name="CloseInitFS" type="BOOLEAN" value="true">
</d:var>
<d:var name="ClearFaultCounter" type="BOOLEAN" value="true">
</d:var>
<d:var name="ExitDebugMode" type="BOOLEAN" value="false">
</d:var>
<d:var name="ReleaseSafetyOutputs" type="ENUMERATION"
value="SBC_FS26_FS_NONE"/>
<d:var name="ExternalWatchdog" type="BOOLEAN" value="false">
</d:var>
<d:var name="WatchdogType" type="ENUMERATION"
value="SBC_FS26_WD_CHALLENGER"/>
<d:var name="u16WatchdogToken" type="STRING" value="5AB2">
</d:var>
<d:var name="bAsilDLevel" type="BOOLEAN" value="true"/>
<d:var name="SbcRstbCheckNotification" type="FUNCTION-NAME"
value="NULL_PTR">
</d:var>
<d:var name="SbcWatchdogNotification" type="FUNCTION-NAME"
value="NULL_PTR">
</d:var>
<d:var name="SbcCheckWatchdogRefreshNotification"
type="FUNCTION-NAME" value="NULL_PTR">
</d:var>
<d:var name="SbcDisableWatchdogTimer" type="BOOLEAN"
value="false">
</d:var>
</d:ctr>
<d:ctr name="InitConfig" type="IDENTIFIABLE">
<d:ctr name="ovuvSafe1Reg" type="IDENTIFIABLE">
<a:a name="SHORT-NAME" value="ovuvSafe1Reg"/>
<d:var name="u16VmonPreOvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_PRE_OV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonPreUvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_PRE_UV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonCoreOvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_CORE_OV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonCoreUvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_CORE_UV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonLdo1OvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_LDO1_OV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonLdo1UvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_LDO1_UV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonLdo2OvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_LDO2_OV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonLdo2UvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_LDO2_UV_FS_REACTION_NO_EFFECT"/>
</d:ctr>
<d:ctr name="ovuvSafe2Reg" type="IDENTIFIABLE">
<d:var name="u16VmonExtOvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_EXT_OV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonExtUvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_EXT_UV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonRefOvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_REF_OV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonRefUvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_REF_UV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonTrk2OvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_TRK2_OV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonTrk2UvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_TRK2_UV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonTrk1OvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_TRK1_OV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonTrk1UvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_TRK1_UV_FS_REACTION_NO_EFFECT"/>
</d:ctr>
<d:ctr name="wdCfgReg" type="IDENTIFIABLE">
<d:var name="u16WdErrLimit" type="ENUMERATION"
value="SBC_FS26_FS_WD_ERR_LIMIT_6">
</d:var>
<d:var name="u16WdRfrLimit" type="ENUMERATION"
value="SBC_FS26_FS_WD_RFR_LIMIT_1">
</d:var>
<d:var name="u16WdFs" type="ENUMERATION"
value="SBC_FS26_FS_WD_FS_REACTION_NO_EFFECT"/>
</d:ctr>
<d:ctr name="safeInputsReg" type="IDENTIFIABLE">
<d:var name="u16FccuCfg" type="ENUMERATION"
value="SBC_FS26_FS_FCCU_CFG_NO"/>
<d:var name="u16Fccu12FltPol" type="ENUMERATION"
value="SBC_FS26_FS_FCCU12_FLT_POL_0_1">
</d:var>
<d:var name="u16Fccu1FltPol" type="ENUMERATION"
value="SBC_FS26_FS_FCCU1_FLT_POL_LOW">
</d:var>
<d:var name="u16Fccu2FltPol" type="ENUMERATION"
value="SBC_FS26_FS_FCCU2_FLT_POL_LOW">
</d:var>
<d:var name="u16Fccu12Fs" type="ENUMERATION"
value="SBC_FS26_FS_FCCU12_FS_REACTION_FS0B"/>
<d:var name="u16Fccu1Fs" type="ENUMERATION"
value="SBC_FS26_FS_FCCU1_FS_REACTION_FS0B"/>
<d:var name="u16Fccu2Fs" type="ENUMERATION"
value="SBC_FS26_FS_FCCU2_FS_REACTION_FS0B"/>
<d:var name="u16Wake2LpPol" type="ENUMERATION"
value="SBC_FS26_FS_WAKE2_LP_POLARITY_LOW">
</d:var>
<d:var name="u16ErrmonFaultPol" type="ENUMERATION"
value="SBC_FS26_FS_ERRMON_FLT_POLARITY_LOW">
</d:var>
<d:var name="u16ErrmonAckTime" type="ENUMERATION"
value="SBC_FS26_FS_ERRMON_ACK_TIME_8MS">
</d:var>
<d:var name="u16ErrmonFs" type="ENUMERATION"
value="SBC_FS26_FS_ERRMON_FS_REACTION_FS0B"/>
<d:var name="u16Fccu12Filt" type="ENUMERATION"
value="SBC_FS26_FS_FCCU12_FILT_6US">
</d:var>
</d:ctr>
<d:ctr name="fssmReg" type="IDENTIFIABLE">
<d:var name="u16FltErrCntLimit" type="ENUMERATION"
value="SBC_FS26_FS_FLT_ERR_CNT_LIMIT_6">
</d:var>
<d:var name="u16FltErrFs" type="ENUMERATION"
value="SBC_FS26_FS_FLT_ERR_REACTION_NO_EFFECT"/>
<d:var name="u16RstbDur" type="ENUMERATION"
value="SBC_FS26_FS_RSTB_DUR_10MS">
</d:var>
<d:var name="u16BackupFs0b" type="ENUMERATION"
value="SBC_FS26_FS_BACKUP_SAFETY_PATH_FS0B_NO"/>
<d:var name="u16BackupFs1b" type="ENUMERATION"
value="SBC_FS26_FS_BACKUP_SAFETY_PATH_FS1B_NO"/>
<d:var name="u16ClkMonDis" type="ENUMERATION"
value="SBC_FS26_FS_CLK_MON_DIS_DISABLED"/>
<d:var name="u16Dis8s" type="ENUMERATION"
value="SBC_FS26_FS_DIS8S_DISABLED"/>
</d:ctr>
<d:ctr name="wdwDurationReg" type="IDENTIFIABLE">
<d:var name="u16WdwPeriod" type="ENUMERATION"
value="SBC_FS26_FS_WDW_PERIOD_INFINITE"/>
<d:var name="u16WdwDc" type="ENUMERATION"
value="SBC_FS26_FS_WDW_DC_62C_37O">
</d:var>
<d:var name="u16WdwRecovery" type="ENUMERATION"
value="SBC_FS26_FS_WDW_RECOVERY_INFINITE"/>
</d:ctr>
<d:ctr name="abistOnDemand" type="IDENTIFIABLE">
<d:var name="Abist2Ext" type="ENUMERATION" value="NO_ABIST">
</d:var>
<d:var name="Abist2Ref" type="ENUMERATION" value="NO_ABIST">
</d:var>
<d:var name="Abist2Trk2" type="ENUMERATION" value="NO_ABIST">
</d:var>
<d:var name="Abist2Trk1" type="ENUMERATION" value="NO_ABIST">
</d:var>
<d:var name="Abist2Ldo2" type="ENUMERATION" value="NO_ABIST">
</d:var>
<d:var name="Abist2Ldo1" type="ENUMERATION" value="NO_ABIST">
</d:var>
<d:var name="Abist2Core" type="ENUMERATION" value="NO_ABIST">
</d:var>
<d:var name="Abist2Vpre" type="ENUMERATION" value="NO_ABIST">
</d:var>
</d:ctr>
<d:ctr name="intbMaskReg" type="IDENTIFIABLE">
<d:var name="u16VpreM" type="ENUMERATION"
value="SBC_FS26_FS_VPRE_M_NOT_MASKED">
</d:var>
<d:var name="u16CoreM" type="ENUMERATION"
value="SBC_FS26_FS_CORE_M_NOT_MASKED">
</d:var>
<d:var name="u16Ldo1M" type="ENUMERATION"
value="SBC_FS26_FS_LDO1_M_NOT_MASKED">
</d:var>
<d:var name="u16Ldo2M" type="ENUMERATION"
value="SBC_FS26_FS_LDO2_M_NOT_MASKED">
</d:var>
<d:var name="u16Trk1M" type="ENUMERATION"
value="SBC_FS26_FS_TRK1_M_NOT_MASKED">
</d:var>
<d:var name="u16Trk2M" type="ENUMERATION"
value="SBC_FS26_FS_TRK2_M_NOT_MASKED">
</d:var>
<d:var name="u16RefM" type="ENUMERATION"
value="SBC_FS26_FS_REF_M_NOT_MASKED">
</d:var>
<d:var name="u16ExtM" type="ENUMERATION"
value="SBC_FS26_FS_EXT_M_NOT_MASKED">
</d:var>
<d:var name="u16Fccu1M" type="ENUMERATION"
value="SBC_FS26_FS_FCCU1_M_NOT_MASKED">
</d:var>
<d:var name="u16Fccu2M" type="ENUMERATION"
value="SBC_FS26_FS_FCCU2_M_NOT_MASKED">
</d:var>
<d:var name="u16BadWdM" type="ENUMERATION"
value="SBC_FS26_FS_BAD_WD_M_NOT_MASKED">
</d:var>
<d:var name="u16ErrmonM" type="ENUMERATION"
value="SBC_FS26_FS_ERRMON_M_NOT_MASKED">
</d:var>
</d:ctr>
</d:ctr>
<d:ctr name="GeneralConfig" type="IDENTIFIABLE">
<d:var name="SbcDevErrorDetect" type="BOOLEAN" value="false">
</d:var>
<d:var name="SbcDisableDemReportError" type="BOOLEAN"
value="true">
</d:var>
<d:var name="SbcEnableUserModeSupport" type="BOOLEAN"
value="false">
</d:var>
<d:var name="SbcVersionInfoApi" type="BOOLEAN" value="false">
</d:var>
<d:var name="SbcWakeupApi" type="BOOLEAN" value="false">
</d:var>
<d:var name="SbcLDTApi" type="BOOLEAN" value="false">
</d:var>
<d:var name="SbcAmuxApi" type="BOOLEAN" value="false">
</d:var>
<d:var name="SbcRegulatorApi" type="BOOLEAN" value="true"/>
<d:var name="SbcAbist2Api" type="BOOLEAN" value="false">
</d:var>
<d:var name="SbcTimeoutMechanism" type="ENUMERATION"
value="TICKS">
</d:var>
<d:var name="SbcTimeoutMethod" type="ENUMERATION"
value="OSIF_COUNTER_DUMMY"/>
<d:var name="SbcTimeout" type="INTEGER" value="5000000"/>
</d:ctr>
</d:ctr>
</d:chc>
</d:lst>
</d:ctr>
</d:lst>
</d:ctr>
</datamodel>
guoweisun
当你把debug pin接到GND的时候意味着active WD,也就是说在SBC进入INIT阶段以后你必须在256ms以内喂狗配置好INIT相关的register,否则RSTB会周期性的拉低导致你的MCU无法正常的工作。
你看看下面附件attached的图片讲这个WD喂狗时序的。
ChangruiKhoo
我在256ms内成功喂狗了,当前处于正常运行的状态。在这个状态下我再次使用jatg进行debug,发现了上面我提到的问题。所以是因为jtag debug 也会复位PMIC吗,这导致需要重新在256ms内配置pmic
guoweisun
那你要去测试核实jtag debug会不会影响到FS26 的RSTB。
%3CLINGO-SUB%20id%3D%22lingo-sub-2345923%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3Edebug%20problem%20when%20pmic%20is%20not%20in%20debug%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2345923%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EI'm%20using%20S32K388%20chip%20and%20using%20pmic%20FS26%20(MFS2633HMDC3AD)%20%3CBR%20%2F%3EI'm%20having%20this%20problem%20that%20I%20can't%20debug%20mcu%20S32K388%20via%20debugger%20MULTI%20LINK%20when%20my%20pmic%20is%20not%20in%20debug%20mode%2C%20is%20this%20normal%2C%20%3CBR%20%2F%3EI%20have%20the%20following%20configuration%20of%20mcal%20for%20my%20pmic%20and%20I'm%20I%20turned%20off%20the%20watchdog's%20reaction%20and%20the%20problem%20still%20exists%20%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%20%26lt%3B%20datamodel%20version%3D%20%227.0%20%22%3CBR%20%2F%3Exmlns%3D%20%22%3CA%20href%3D%22http%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F16%2Froot.xsd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F16%2Froot.xsd%3C%2FA%3E%22%3CBR%20%2F%3Exmlns%3Aa%3D%20%22%3CA%20href%3D%22http%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F16%2Fattribute.xsd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F16%2Fattribute.xsd%3C%2FA%3E%22%3CBR%20%2F%3Exmlns%3Av%3D%20%22%3CA%20href%3D%22http%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F06%2Fschema.xsd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F06%2Fschema.xsd%3C%2FA%3E%22%3CBR%20%2F%3Exmlns%3Ad%3D%20%22%3CA%20href%3D%22http%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F06%2Fdata.xsd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F06%2Fdata.xsd%3C%2FA%3E%22%26gt%3B%3C%2FP%3E%3CP%3E%3CCTR%20type%3D%22AUTOSAR%20%22%20factory%3D%22autosar%20%22%3E%3CBR%20%2F%3E%20xmlns%3Aad%3D%20%22%3CA%20href%3D%22http%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F08%2Fadmindata.xsd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F08%2Fadmindata.xsd%3C%2FA%3E%22%3CBR%20%2F%3Exmlns%3Acd%3D%20%22%3CA%20href%3D%22http%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F08%2Fcustomdata.xsd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F08%2Fcustomdata.xsd%3C%2FA%3E%22%3CBR%20%2F%3Exmlns%3Af%3D%20%22%3CA%20href%3D%22http%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F14%2Fformulaexpr.xsd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F14%2Fformulaexpr.xsd%3C%2FA%3E%22%3CBR%20%2F%3Exmlns%3Aicc%3D%20%22%3CA%20href%3D%22http%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F08%2Fimplconfigclass.xsd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F08%2Fimplconfigclass.xsd%3C%2FA%3E%22%3CBR%20%2F%3Exmlns%3Amt%3D%20%22%3CA%20href%3D%22http%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F11%2Fmultitest.xsd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F11%2Fmultitest.xsd%3C%2FA%3E%22%3CBR%20%2F%3Exmlns%3Avariant%3D%20%22%3CA%20href%3D%22http%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F11%2Fvariant.xsd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F11%2Fvariant.xsd%3C%2FA%3E%22%26gt%3B%3CBR%20%2F%3E%3CLST%20type%3D%22TOP-LEVEL-PACKAGES%20%22%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Actr%20name%3D%20%22Sbc_fs26%20%22%20type%3D%20%22AR-PACKAGE%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Alst%20type%3D%20%22ELEMENTS%20%22%26gt%3B%20%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Achc%20name%3D%20%22Sbc_fs26%20%22%20type%3D%20%22AR-ELEMENT%20%22%20value%3D%20%22MODULE-%20CONFIGURATION%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Actr%20type%3D%20%22MODULE-CONFIGURATION%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22DEF%20%22%20value%3D%20%22ASPath%3A%2FTS_T40D34M60I0R0%2FSbc_fs26%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22POST_BUILD_VARIANT_USED%20%22%20type%3D%20%22BOOLEAN%20%22%20value%3D%20%22%20false%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22IMPLEMENTATION_CONFIG_VARIANT%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22VariantPreCompile%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3C%2FLST%3E%3CBR%20%2F%3E%20%26lt%3B%20d%3Actr%20name%3D%20%22CommonPublishedInformation%20%22%20type%3D%20%22IDENTIFIABLE%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22ModuleId%20%22%20type%3D%20%22INTEGER%20%22%20value%3D%20%22255%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%3C%2FCTR%3E%20%2Fd%3Avar%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22VendorId%20%22%20type%3D%20%22INTEGER%20%22%20value%3D%20%2243%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22ArReleaseMajorVersion%20%22%20type%3D%20%22INTEGER%20%22%20value%3D%20%224%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22ArReleaseMinorVersion%20%22%20type%3D%20%22INTEGER%20%22%20%20value%3D%20%229%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20%20d%3Avar%20name%3D%20%22ArReleaseRevisionVersion%20%22%20type%3D%20%22INTEGER%20%22%20value%3D%20%220%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22SwMajorVersion%20%22%20type%3D%20%22INTEGER%20%22%20value%3D%20%226%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22SwMinorVersion%20%22%20type%3D%20%22INTEGER%20%22%20value%3D%20%220%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22SwPatchVersion%20%22%20type%3D%20%22INTEGER%20%22%20value%3D%20%220%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20d%3Actr%20name%3D%20%22SbcDemEventParameterRefs%20%22%20type%3D%20%22IDENTIFIABLE%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22ENABLE%20%22%20value%3D%20%22false%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Aref%20name%3D%20%22SBC_FS26_E_TIMEOUT%20%22%20type%3D%20%22REFERENCE%20%22%20%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22ENABLE%20%22%20value%3D%20%22false%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Aref%20name%3D%20%22SBC_FS26_E_DEVICE_STATUS%20%22%20type%3D%20%22REFERENCE%20%22%20%3CBR%20%2F%3E%26lt%3B%20a%3Aa%20name%3D%20%22ENABLE%20%22%20value%3D%20%22false%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Actr%20name%3D%20%22SpiConfig%20%22%20type%3D%20%22IDENTIFIABLE%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Aref%20name%3D%20%22SpiChannelRef%20%22%20type%3D%20%22REFERENCE%20%22%3CBR%20%2F%3E%20value%3D%20%22ASPath%3A%2FSpi%2FSpi%2FSpiDriver%2FSpiChannel_FS26%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Aref%20name%3D%20%22SpiSequenceRef%20%22%20type%3D%20%22REFERENCE%20%22%3CBR%20%2F%3E%20value%3D%20%22ASPath%3A%2FSpi%20%2FSpi%2FSpiDriver%20%26gt%3B%2FSpiSequence_FS26%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22SpiAsync%20%22%20type%3D%20%22BOOLEAN%20%22%20value%3D%20%22false%20%22%3CBR%20%2F%3E%20%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22SbcQueueLength%20%22%20type%3D%20%22INTEGER%20%22%20value%3D%20%2216%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Actr%20name%3D%20%22DriverConfig%20type%3D%20%22IDENTIFIABLE%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22CloseInitFS%20%22%20type%3D%20%22BOOLEAN%20%22%20value%3D%20%22true%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22ClearFaultCounter%20%22%20type%3D%20%22BOOLEAN%20%22%20value%3D%20%22true%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20%20d%3Avar%20name%3D%20%22ExitDebugMode%20type%3D%20%22BOOLEAN%20%22%20value%3D%20%22false%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20%20d%3Avar%20name%3D%20%22ReleaseSafetyOutputs%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_%20FS_NONE%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22ExternalWatchdog%20%22%20type%3D%20%22BOOLEAN%20%22%20value%3D%20%22false%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20d%3Avar%20name%3D%20%22WatchdogType%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_WD_CHALLENGER%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16WatchdogToken%20%22%20type%3D%20%22STRING%20%22%20value%3D%20%225AB2%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22bAsilDLevel%20%22%20type%3D%20%22BOOLEAN%20%22%20value%3D%20%22true%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22SbcRstbCheckNotification%20%22%20type%3D%20%22FUNCTION-NAME%20%22%3CBR%20%2F%3E%20value%3DNULL_PTR%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22ENABLE%20%22%20value%3D%20%22false%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22SbcWatchdogNotification%20%22%20type%3D%20%22FUNCTION-NAME%20%22%3CBR%20%2F%3E%20value%3D%20%22NULL_PTR%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22ENABLE%20%22%20value%3D%20%22false%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20%2Fd%3Avar%3CBR%20%2F%3E%26lt%3B%20d%3Avar%20name%3D%20%22SbcCheckWatchdogRefreshNotification%20%22%3CBR%20%2F%3E%20type%3D%20%22FUNCTION-NAME%20%22%20value%3D%20%22NULL_PTR%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22ENABLE%20%22%20value%3D%20%22false%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22SbcDisableWatchdogTimer%20%22%20type%3D%20%22BOOLEAN%20%22%3CBR%20%2F%3E%20value%3D%20%22false%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%2Fd%3Avar%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Actr%20name%3D%20%22InitConfig%20%22%20type%3D%20%22IDENTIFIABLE%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Actr%20name%3D%20%22ovuvSafe1Reg%20%22%20type%3D%20%22IDENTIFIABLE%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22SHORT-NAME%20%22%20value%3D%20%22ovuvSafe1Reg%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16VmonPreOvFs%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_VMON_PRE_OV_FS_REACTION_NO_EFFECT%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16VmonPreUvFs%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22%20SBC_FS26_FS_VMON_PRE_UV_FS_REACTION_NO_EFFECT%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16VmonCoreOvFs%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_VMON_CORE_OV_FS_REACTION_%20NO_EFFECT%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16VmonCoreUvFs%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_VMON_CORE_UV_FS_REACTION_NO_EFFECT%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16VmonLdo1OvFs%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_VMON_LDO1_OV_FS_REACTION_NO_EFFECT%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16VmonLdo1UvFs%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22%20SBC_FS26_FS_VMON_LDO1_UV_FS_REACTION_NO_EFFECT%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16VmonLdo2OvFs%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_VMON_LDO2_OV_FS_REACTION%20_NO_EFFECT%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16VmonLdo2UvFs%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_VMON_LDO2_UV_FS_REACTION_NO_EFFECT%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Actr%20name%3D%20%22ovuvSafe2Reg%20%22%20type%3D%20%22IDENTIFIABLE%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16VmonExtOvFs%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_VMON_EXT_OV_FS_REACTION_NO_EFFECT%20%22%20%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16VmonExtUvFs%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_VMON_EXT_UV_FS_REACTION_NO_EFFECT%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16VmonRefOvFs%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_VMON_REF_OV_FS_REACTION_NO_EFFECT%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16VmonRefUvFs%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_VMON_REF_UV_FS_REACTION_NO_EFFECT%20UV_FS_REACTION_NO_EFFECT%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16VmonTrk2OvFs%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_VMON_TRK2_OV_FS_REACTION_NO_EFFECT%20%22%2F%20%26gt%3B%20%3CBR%20%2F%3E%3CVAR%20name%3D%22u16VmonTrk2UvFs%20%22%20type%3D%22ENUMERATION%20%22%3E%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_VMON_TRK2_UV_FS_REACTION_NO_EFFECT%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16VmonTrk1OvFs%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_VMON_TRK1_OV_FS_REACTION_NO_EFFECT%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16VmonTrk1UvFs%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_VMON_%20TRK1_UV_FS_REACTION_NO_EFFECT%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%26lt%3B%20d%3Actr%20name%3D%20%22wdCfgReg%20%22%20type%3D%20%22IDENTIFIABLE%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20%20d%3Avar%20name%3D%20%22%20u16WdErrLimit%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_WD_ERR_LIMIT_6%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16WdRfrLimit%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_WD_RFR_LIMIT_1%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16WdFs%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22%20SBC_FS26_FS_WD_FS_REACTION_NO_EFFECT%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Actr%20name%3D%20%22safeInputsReg%20%22%20type%3D%20%22IDENTIFIABLE%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16FccuCfg%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_%20%26gt%3B%3CBR%20%2F%3E%20FS26_FS_FCCU_CFG_NO%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16Fccu12FltPol%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_FCCU12_FLT_POL_0_1%20%22%20%26lt%3B%20%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20u16Fccu1FltPol%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_FCCU1_FLT_POL_LOW%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16Fccu2FltPol%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_FCCU2_FLT_POL_LOW%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16Fccu12Fs%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22%20SBC_FS26_FS_FCCU12_FS_REACTION_FS0B%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16Fccu1Fs%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_FCCU1_FS_REACTION_FS0B%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16Fccu2Fs%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_FCCU2_FS_REACTION_FS0B%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16Wake2LpPol%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_WAKE2_%20LP_POLARITY_LOW%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3Ed%3Avar%20name%3D%20%22u16ErrmonFaultPol%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_ERRMON_FLT_POLARITY_LOW%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d.%20%3CBR%20%2F%3E%20var%20name%3D%20%22u16ErrmonAckTime%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_ERRMON_ACK_TIME_8MS%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16ErrmonFs%20%22%20type%3D%20%22ENUMERATION%20%20%3CBR%20%2F%3Evalue%3D%20%22SBC_FS26_FS_ERRMON_FS_REACTION_FS0B%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16Fccu12Filt%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22%20SBC_FS26_FS_FCCU12_FILT_6US%20%22%26gt%3B%20%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Actr%20name%3D%20%22fssmReg%20%22%20type%3D%20%22IDENTIFIABLE%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16FltErrCntLimit%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS%20_FLT_ERR_CNT_LIMIT_6%20%22%26gt%3B%20%3CBR%20%2F%3E%20%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16FltErrFs%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_FLT_ERR_REACTION_NO_EFFECT%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16RstbDur%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_RSTB_DUR_10MS%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16BackupFs0b%20%22%20type%3D%20%22ENUMERATION%20%22%20%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_BACKUP_SAFETY_PATH_FS0B_NO%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16BackupFs1b%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_BACKUP_SAFETY_PATH_FS1B_%20NO%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16ClkMonDis%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_CLK_MON_DIS_DISABLED%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16Dis8s%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_%20FS_DIS8S_DISABLED%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Actr%20name%3D%20%22wdwDurationReg%20%22%20type%3D%20%22IDENTIFIABLE%20%22%20%3CBR%20%2F%3E%26lt%3B%20d%3Avar%20name%3D%20%22u16WdwPeriod%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_WDW_PERIOD_INFINITE%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16WdwDc%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_%20FS26_FS_WDW_DC_62C_37O%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16WdwRecovery%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_WDW_RECOVERY%20_INFINITE%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Actr%20name%3D%20abistOnDemand%20%22%20type%3D%20%22IDENTIFIABLE%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22Abist2Ext%20%22%20type%3D%20%22ENUMERATION%20%22%20value%3D%20%22NO_ABIST%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40%20DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22Abist2Ref%20%22%20type%3D%20%22ENUMERATION%20%22%20value%3D%20%22NO_ABIST%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3Ed%3Avar%20name%3D%20%22Abist2Trk2%20%22%20type%3D%20%22ENUMERATION%20%22%20value%3D%20%22NO_ABIST%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22Abist2Trk1%20%22%20type%3D%20%22ENUMERATION%20%22%20value%3D%20%22NO_ABIST%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22Abist2Ldo2%20%22%20type%3D%20%22ENUMERATION%20%22%20value%3D%20NO_ABIST%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22Abist2Ldo1%20%22%20type%3D%20%22ENUMERATION%20%22%20value%3D%20%22NO_ABIST%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40%20DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22Abist2Core%20%22%20type%3D%20%22ENUMERATION%20%22%20value%3D%20%22NO_ABIST%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22Abist2Vpre%20%22%20type%3D%20%22ENUMERATION%20%22%20value%3D%20%22NO_ABIST%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Actr%20name%3D%20%22intbMaskReg%20%22%20type%3D%20%22IDENTIFIABLE%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16VpreM%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_VPRE_M_NOT_MASKED%20%22%3CBR%20%2F%3E%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16CoreM%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_CORE_M_NOT_MASKED%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_%20%3CBR%20%2F%3E%20INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%20%20%26lt%3B%20d%3Avar%20name%3D%20%22u16Ldo1M%20%22%20type%3D%20%22ENUMERATION%20%22%20value%3D%20%22SBC_FS26_FS_LDO1_M_NOT_MASKED%20%22%20%26gt%3B%20%26lt%3B%20%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%40DEF%20%22%2F%20%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16Ldo2M%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_LDO2_M_NOT_MASKED%20%22%26gt%3B%20%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16Trk1M%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_TRK1_M_NOT_MASKED%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20%26lt%3B%20%2Fd%3Avar%3CBR%20%2F%3E%26lt%3B%20d%3Avar%20name%3D%20%22u16Trk2M%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_TRK2_M_NOT_MASKED%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16RefM%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_REF_M_NOT_MASKED%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16ExtM%20%22%20type%3DENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_EXT_M_NOT_MASKED%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20%20d%3Avar%20name%3D%20%22u16Fccu1M%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_FCCU1_M_NOT_MASKED%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16Fccu2M%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_%20FS26_FS_FCCU2_M_NOT_MASKED%20%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16BadWdM%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_BAD_WD_M_NOT_MASKED%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER%20_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22u16ErrmonM%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22SBC_FS26_FS_ERRMON_M_NOT_MASKED%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Actr%20name%3D%20%22GeneralConfig%20%22%20type%3D%20%22IDENTIFIABLE%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22SbcDevErrorDetect%20%22%20type%3D%20%22BOOLEAN%20%22%20value%3D%20%22false%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20%20d%3Avar%20name%3D%20%22SbcDisableDemReportError%20%22%20type%3D%20%22BOOLEAN%20%22%3CBR%20%2F%3E%20value%20%3D%20%22true%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22SbcEnableUserModeSupport%20%22%20type%3D%20%22BOOLEAN%20%22%3CBR%20%2F%3E%20value%3D%20%22false%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40%20DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22SbcVersionInfoApi%20%22%20type%3D%20%22BOOLEAN%20%22%20value%3D%20%22false%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20%20a%3Aa%20name%3D%20%22%20IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22SbcWakeupApi%20%22%20type%3D%20%22BOOLEAN%20%22%20value%3D%20%22false%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22SbcLDTApi%20%22%20type%3D%20%22BOOLEAN%20%22%20value%3D%20%22false%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20%2Fd%3Avar%3CBR%20%2F%3E%26lt%3B%20d%3Avar%20name%3D%20%22SbcAmuxApi%20%22%20type%3D%20%22BOOLEAN%20%22%20value%3D%20%22false%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22SbcRegulatorApi%20%22%20type%3D%20%22BOOLEAN%20%22%20value%3D%20%22true%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22SbcAbist2Api%20%22%20type%3D%20%22BOOLEAN%20%22%20value%3D%20%22false%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%20%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22SbcTimeoutMechanism%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22TICKS%20%22%26gt%3B%20%3CBR%20%2F%3E%20%26lt%3B%20a%3Aa%20name%3D%20%22IMPORTER_INFO%20%22%20value%3D%20%22%40DEF%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22SbcTimeoutMethod%20%22%20type%3D%20%22ENUMERATION%20%22%3CBR%20%2F%3E%20value%3D%20%22OSIF_COUNTER_DUMMY%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20d%3Avar%20name%3D%20%22SbcTimeout%20%22%20type%3D%20%22INTEGER%20%22%20value%3D%20%225000000%20%22%2F%20%26gt%3B%3CBR%20%2F%3E%20%26lt%3B%20%2Fd%3Actr%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346685%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20debug%20problem%20when%20pmic%20is%20not%20in%20debug%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346685%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EWhen%20you%20connect%20the%20debug%20pin%20to%20GND%20it%20means%20active%20WD%2C%20that%20is%20to%20say%20after%20the%20SBC%20enters%20the%20INIT%20phase%20you%20have%20to%20feed%20the%20dog%20to%20configure%20the%20INIT%20related%20register%20within%20256ms%2C%20otherwise%20the%20RSTB%20will%20pull%20down%20periodically%20causing%20your%20MCU%20to%20not%20work%20properly.%3C%2FP%3E%0A%3CP%3EYou%20can%20see%20the%20picture%20attached%20belowattached%20to%20talk%20about%20the%20timing%20of%20this%20WD%20feeding%20the%20dog.%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2349376%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20debug%20problem%20when%20pmic%20is%20not%20in%20debug%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2349376%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3EI%20managed%20to%20feed%20the%20dog%20in%20256ms%20and%20it%20is%20currently%20in%20a%20normal%20running%20state.%20In%20this%20state%20I%20debugged%20again%20using%20jatg%20and%20found%20the%20problem%20I%20mentioned%20above.%20So%20is%20it%20because%20jtag%20debug%20also%20resets%20the%20PMIC%3F%20which%20results%20in%20the%20need%20to%20reconfigure%20the%20pmic%20within%20256ms%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2349506%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20debug%20problem%20when%20pmic%20is%20not%20in%20debug%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2349506%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EThen%20you%20need%20to%20test%20to%20verify%20that%20%3CSPAN%3Ethe%20jtag%20debug%20affects%20the%20FS26%20RSTB.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
