debug problem when pmic is not in debug mode
1,537件の閲覧回数
ChangruiKhoo
我使用的是S32K388芯片,并且使用了pmic  FS26(MFS2633HMDC3AD)
我遇到了这样的问题,当我的pmic不属于debug 模式时,我无法通过调试器MULTI LINK debug mcu S32K388,这是否正常呢,
我的pmic的mcal配置如下,我关闭了看门狗的reaction,问题还是存在
<?xml version='1.0'?>
<datamodel version="7.0"
xmlns="http://www.tresos.de/_projects/DataModel2/16/root.xsd"
xmlns:a="http://www.tresos.de/_projects/DataModel2/16/attribute.xsd"
xmlns:v="http://www.tresos.de/_projects/DataModel2/06/schema.xsd"
xmlns:d="http://www.tresos.de/_projects/DataModel2/06/data.xsd">
<d:ctr type="AUTOSAR" factory="autosar"
xmlns:ad="http://www.tresos.de/_projects/DataModel2/08/admindata.xsd"
xmlns:cd="http://www.tresos.de/_projects/DataModel2/08/customdata.xsd"
xmlns:f="http://www.tresos.de/_projects/DataModel2/14/formulaexpr.xsd"
xmlns:icc="http://www.tresos.de/_projects/DataModel2/08/implconfigclass.xsd"
xmlns:mt="http://www.tresos.de/_projects/DataModel2/11/multitest.xsd"
xmlns:variant="http://www.tresos.de/_projects/DataModel2/11/variant.xsd">
<d:lst type="TOP-LEVEL-PACKAGES">
<d:ctr name="Sbc_fs26" type="AR-PACKAGE">
<d:lst type="ELEMENTS">
<d:chc name="Sbc_fs26" type="AR-ELEMENT" value="MODULE-CONFIGURATION">
<d:ctr type="MODULE-CONFIGURATION">
<a:a name="DEF" value="ASPath:/TS_T40D34M60I0R0/Sbc_fs26"/>
<d:var name="POST_BUILD_VARIANT_USED" type="BOOLEAN" value="false"/>
<d:var name="IMPLEMENTATION_CONFIG_VARIANT" type="ENUMERATION"
value="VariantPreCompile">
<a:a name="IMPORTER_INFO" value="@DEF"/>
</d:var>
<d:ctr name="CommonPublishedInformation" type="IDENTIFIABLE">
<d:var name="ModuleId" type="INTEGER" value="255">
</d:var>
<d:var name="VendorId" type="INTEGER" value="43">
</d:var>
<d:var name="ArReleaseMajorVersion" type="INTEGER" value="4">
</d:var>
<d:var name="ArReleaseMinorVersion" type="INTEGER" value="9">
</d:var>
<d:var name="ArReleaseRevisionVersion" type="INTEGER" value="0">
</d:var>
<d:var name="SwMajorVersion" type="INTEGER" value="6">
</d:var>
<d:var name="SwMinorVersion" type="INTEGER" value="0">
</d:var>
<d:var name="SwPatchVersion" type="INTEGER" value="0">
</d:var>
</d:ctr>
<d:ctr name="SbcDemEventParameterRefs" type="IDENTIFIABLE">
<a:a name="ENABLE" value="false"/>
<d:ref name="SBC_FS26_E_TIMEOUT" type="REFERENCE" >
</d:ref>
<d:ref name="SBC_FS26_E_DEVICE_STATUS" type="REFERENCE" >
</d:ref>
</d:ctr>
<d:ctr name="SpiConfig" type="IDENTIFIABLE">
<d:ref name="SpiChannelRef" type="REFERENCE"
value="ASPath:/Spi/Spi/SpiDriver/SpiChannel_FS26"/>
<d:ref name="SpiSequenceRef" type="REFERENCE"
value="ASPath:/Spi/Spi/SpiDriver/SpiSequence_FS26"/>
<d:var name="SpiAsync" type="BOOLEAN" value="false">
</d:var>
<d:var name="SbcQueueLength" type="INTEGER" value="16">
</d:var>
</d:ctr>
<d:ctr name="DriverConfig" type="IDENTIFIABLE">
<d:var name="CloseInitFS" type="BOOLEAN" value="true">
</d:var>
<d:var name="ClearFaultCounter" type="BOOLEAN" value="true">
</d:var>
<d:var name="ExitDebugMode" type="BOOLEAN" value="false">
</d:var>
<d:var name="ReleaseSafetyOutputs" type="ENUMERATION"
value="SBC_FS26_FS_NONE"/>
<d:var name="ExternalWatchdog" type="BOOLEAN" value="false">
</d:var>
<d:var name="WatchdogType" type="ENUMERATION"
value="SBC_FS26_WD_CHALLENGER"/>
<d:var name="u16WatchdogToken" type="STRING" value="5AB2">
</d:var>
<d:var name="bAsilDLevel" type="BOOLEAN" value="true"/>
<d:var name="SbcRstbCheckNotification" type="FUNCTION-NAME"
value="NULL_PTR">
</d:var>
<d:var name="SbcWatchdogNotification" type="FUNCTION-NAME"
value="NULL_PTR">
</d:var>
<d:var name="SbcCheckWatchdogRefreshNotification"
type="FUNCTION-NAME" value="NULL_PTR">
</d:var>
<d:var name="SbcDisableWatchdogTimer" type="BOOLEAN"
value="false">
</d:var>
</d:ctr>
<d:ctr name="InitConfig" type="IDENTIFIABLE">
<d:ctr name="ovuvSafe1Reg" type="IDENTIFIABLE">
<a:a name="SHORT-NAME" value="ovuvSafe1Reg"/>
<d:var name="u16VmonPreOvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_PRE_OV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonPreUvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_PRE_UV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonCoreOvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_CORE_OV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonCoreUvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_CORE_UV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonLdo1OvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_LDO1_OV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonLdo1UvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_LDO1_UV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonLdo2OvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_LDO2_OV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonLdo2UvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_LDO2_UV_FS_REACTION_NO_EFFECT"/>
</d:ctr>
<d:ctr name="ovuvSafe2Reg" type="IDENTIFIABLE">
<d:var name="u16VmonExtOvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_EXT_OV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonExtUvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_EXT_UV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonRefOvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_REF_OV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonRefUvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_REF_UV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonTrk2OvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_TRK2_OV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonTrk2UvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_TRK2_UV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonTrk1OvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_TRK1_OV_FS_REACTION_NO_EFFECT"/>
<d:var name="u16VmonTrk1UvFs" type="ENUMERATION"
value="SBC_FS26_FS_VMON_TRK1_UV_FS_REACTION_NO_EFFECT"/>
</d:ctr>
<d:ctr name="wdCfgReg" type="IDENTIFIABLE">
<d:var name="u16WdErrLimit" type="ENUMERATION"
value="SBC_FS26_FS_WD_ERR_LIMIT_6">
</d:var>
<d:var name="u16WdRfrLimit" type="ENUMERATION"
value="SBC_FS26_FS_WD_RFR_LIMIT_1">
</d:var>
<d:var name="u16WdFs" type="ENUMERATION"
value="SBC_FS26_FS_WD_FS_REACTION_NO_EFFECT"/>
</d:ctr>
<d:ctr name="safeInputsReg" type="IDENTIFIABLE">
<d:var name="u16FccuCfg" type="ENUMERATION"
value="SBC_FS26_FS_FCCU_CFG_NO"/>
<d:var name="u16Fccu12FltPol" type="ENUMERATION"
value="SBC_FS26_FS_FCCU12_FLT_POL_0_1">
</d:var>
<d:var name="u16Fccu1FltPol" type="ENUMERATION"
value="SBC_FS26_FS_FCCU1_FLT_POL_LOW">
</d:var>
<d:var name="u16Fccu2FltPol" type="ENUMERATION"
value="SBC_FS26_FS_FCCU2_FLT_POL_LOW">
</d:var>
<d:var name="u16Fccu12Fs" type="ENUMERATION"
value="SBC_FS26_FS_FCCU12_FS_REACTION_FS0B"/>
<d:var name="u16Fccu1Fs" type="ENUMERATION"
value="SBC_FS26_FS_FCCU1_FS_REACTION_FS0B"/>
<d:var name="u16Fccu2Fs" type="ENUMERATION"
value="SBC_FS26_FS_FCCU2_FS_REACTION_FS0B"/>
<d:var name="u16Wake2LpPol" type="ENUMERATION"
value="SBC_FS26_FS_WAKE2_LP_POLARITY_LOW">
</d:var>
<d:var name="u16ErrmonFaultPol" type="ENUMERATION"
value="SBC_FS26_FS_ERRMON_FLT_POLARITY_LOW">
</d:var>
<d:var name="u16ErrmonAckTime" type="ENUMERATION"
value="SBC_FS26_FS_ERRMON_ACK_TIME_8MS">
</d:var>
<d:var name="u16ErrmonFs" type="ENUMERATION"
value="SBC_FS26_FS_ERRMON_FS_REACTION_FS0B"/>
<d:var name="u16Fccu12Filt" type="ENUMERATION"
value="SBC_FS26_FS_FCCU12_FILT_6US">
</d:var>
</d:ctr>
<d:ctr name="fssmReg" type="IDENTIFIABLE">
<d:var name="u16FltErrCntLimit" type="ENUMERATION"
value="SBC_FS26_FS_FLT_ERR_CNT_LIMIT_6">
</d:var>
<d:var name="u16FltErrFs" type="ENUMERATION"
value="SBC_FS26_FS_FLT_ERR_REACTION_NO_EFFECT"/>
<d:var name="u16RstbDur" type="ENUMERATION"
value="SBC_FS26_FS_RSTB_DUR_10MS">
</d:var>
<d:var name="u16BackupFs0b" type="ENUMERATION"
value="SBC_FS26_FS_BACKUP_SAFETY_PATH_FS0B_NO"/>
<d:var name="u16BackupFs1b" type="ENUMERATION"
value="SBC_FS26_FS_BACKUP_SAFETY_PATH_FS1B_NO"/>
<d:var name="u16ClkMonDis" type="ENUMERATION"
value="SBC_FS26_FS_CLK_MON_DIS_DISABLED"/>
<d:var name="u16Dis8s" type="ENUMERATION"
value="SBC_FS26_FS_DIS8S_DISABLED"/>
</d:ctr>
<d:ctr name="wdwDurationReg" type="IDENTIFIABLE">
<d:var name="u16WdwPeriod" type="ENUMERATION"
value="SBC_FS26_FS_WDW_PERIOD_INFINITE"/>
<d:var name="u16WdwDc" type="ENUMERATION"
value="SBC_FS26_FS_WDW_DC_62C_37O">
</d:var>
<d:var name="u16WdwRecovery" type="ENUMERATION"
value="SBC_FS26_FS_WDW_RECOVERY_INFINITE"/>
</d:ctr>
<d:ctr name="abistOnDemand" type="IDENTIFIABLE">
<d:var name="Abist2Ext" type="ENUMERATION" value="NO_ABIST">
</d:var>
<d:var name="Abist2Ref" type="ENUMERATION" value="NO_ABIST">
</d:var>
<d:var name="Abist2Trk2" type="ENUMERATION" value="NO_ABIST">
</d:var>
<d:var name="Abist2Trk1" type="ENUMERATION" value="NO_ABIST">
</d:var>
<d:var name="Abist2Ldo2" type="ENUMERATION" value="NO_ABIST">
</d:var>
<d:var name="Abist2Ldo1" type="ENUMERATION" value="NO_ABIST">
</d:var>
<d:var name="Abist2Core" type="ENUMERATION" value="NO_ABIST">
</d:var>
<d:var name="Abist2Vpre" type="ENUMERATION" value="NO_ABIST">
</d:var>
</d:ctr>
<d:ctr name="intbMaskReg" type="IDENTIFIABLE">
<d:var name="u16VpreM" type="ENUMERATION"
value="SBC_FS26_FS_VPRE_M_NOT_MASKED">
</d:var>
<d:var name="u16CoreM" type="ENUMERATION"
value="SBC_FS26_FS_CORE_M_NOT_MASKED">
</d:var>
<d:var name="u16Ldo1M" type="ENUMERATION"
value="SBC_FS26_FS_LDO1_M_NOT_MASKED">
</d:var>
<d:var name="u16Ldo2M" type="ENUMERATION"
value="SBC_FS26_FS_LDO2_M_NOT_MASKED">
</d:var>
<d:var name="u16Trk1M" type="ENUMERATION"
value="SBC_FS26_FS_TRK1_M_NOT_MASKED">
</d:var>
<d:var name="u16Trk2M" type="ENUMERATION"
value="SBC_FS26_FS_TRK2_M_NOT_MASKED">
</d:var>
<d:var name="u16RefM" type="ENUMERATION"
value="SBC_FS26_FS_REF_M_NOT_MASKED">
</d:var>
<d:var name="u16ExtM" type="ENUMERATION"
value="SBC_FS26_FS_EXT_M_NOT_MASKED">
</d:var>
<d:var name="u16Fccu1M" type="ENUMERATION"
value="SBC_FS26_FS_FCCU1_M_NOT_MASKED">
</d:var>
<d:var name="u16Fccu2M" type="ENUMERATION"
value="SBC_FS26_FS_FCCU2_M_NOT_MASKED">
</d:var>
<d:var name="u16BadWdM" type="ENUMERATION"
value="SBC_FS26_FS_BAD_WD_M_NOT_MASKED">
</d:var>
<d:var name="u16ErrmonM" type="ENUMERATION"
value="SBC_FS26_FS_ERRMON_M_NOT_MASKED">
</d:var>
</d:ctr>
</d:ctr>
<d:ctr name="GeneralConfig" type="IDENTIFIABLE">
<d:var name="SbcDevErrorDetect" type="BOOLEAN" value="false">
</d:var>
<d:var name="SbcDisableDemReportError" type="BOOLEAN"
value="true">
</d:var>
<d:var name="SbcEnableUserModeSupport" type="BOOLEAN"
value="false">
</d:var>
<d:var name="SbcVersionInfoApi" type="BOOLEAN" value="false">
</d:var>
<d:var name="SbcWakeupApi" type="BOOLEAN" value="false">
</d:var>
<d:var name="SbcLDTApi" type="BOOLEAN" value="false">
</d:var>
<d:var name="SbcAmuxApi" type="BOOLEAN" value="false">
</d:var>
<d:var name="SbcRegulatorApi" type="BOOLEAN" value="true"/>
<d:var name="SbcAbist2Api" type="BOOLEAN" value="false">
</d:var>
<d:var name="SbcTimeoutMechanism" type="ENUMERATION"
value="TICKS">
</d:var>
<d:var name="SbcTimeoutMethod" type="ENUMERATION"
value="OSIF_COUNTER_DUMMY"/>
<d:var name="SbcTimeout" type="INTEGER" value="5000000"/>
</d:ctr>
</d:ctr>
</d:chc>
</d:lst>
</d:ctr>
</d:lst>
</d:ctr>
</datamodel>
3 返答(返信)
1,494件の閲覧回数
guoweisun
当你把debug pin接到GND的时候意味着active WD,也就是说在SBC进入INIT阶段以后你必须在256ms以内喂狗配置好INIT相关的register,否则RSTB会周期性的拉低导致你的MCU无法正常的工作。
你看看下面附件attached的图片讲这个WD喂狗时序的。
1,401件の閲覧回数
ChangruiKhoo
我在256ms内成功喂狗了,当前处于正常运行的状态。在这个状态下我再次使用jatg进行debug,发现了上面我提到的问题。所以是因为jtag debug 也会复位PMIC吗,这导致需要重新在256ms内配置pmic
1,381件の閲覧回数
guoweisun
那你要去测试核实jtag debug会不会影响到FS26 的RSTB。
%3CLINGO-SUB%20id%3D%22lingo-sub-2345923%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3Epmic%E3%81%8C%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2345923%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AFS32K388%E3%83%81%E3%83%83%E3%83%97%E3%81%A8PMIC%20FS26%EF%BC%88MFS2633HMDC3AD%EF%BC%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20PMIC%E3%81%8C%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81Multilink%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6S32K388%20MCU%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AA%E5%8B%95%E4%BD%9C%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%E7%A7%81%E3%81%AEPMIC%20Mcal%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E5%BF%9C%E7%AD%94%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%20%3CDATAMODEL%20version%3D%227.0%22%3E%3CBR%20%2F%3Exmlns%3D%22%20%3CA%20href%3D%22http%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F16%2Froot.xsd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F16%2Froot.xsd%3C%2FA%3E%20%22%3CBR%20%2F%3Exmlns%3Aa%3D%22%20%3CA%20href%3D%22http%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F16%2Fattribute.xsd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F16%2Fattribute.xsd%3C%2FA%3E%20%22%3CBR%20%2F%3Exmlns%3Av%3D%22%20%3CA%20href%3D%22http%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F06%2Fschema.xsd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F06%2Fschema.xsd%3C%2FA%3E%20%22%3CBR%20%2F%3Exmlns%3Ad%3D%22%20%3CA%20href%3D%22http%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F06%2Fdata.xsd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F06%2Fdata.xsd%3C%2FA%3E%20%22%26gt%3B%3C%2FDATAMODEL%3E%3C%2FP%3E%3CP%3E%3CCTR%20type%3D%22AUTOSAR%22%20factory%3D%22autosar%22%3E%3CBR%20%2F%3E%20xmlns%3Aad%3D%22%20%3CA%20href%3D%22http%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F08%2Fadmindata.xsd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F08%2Fadmindata.xsd%3C%2FA%3E%20%22%3CBR%20%2F%3Exmlns%3Acd%3D%22%20%3CA%20href%3D%22http%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F08%2Fcustomdata.xsd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F08%2Fcustomdata.xsd%3C%2FA%3E%20%22%3CBR%20%2F%3Exmlns%3Af%3D%22%20%3CA%20href%3D%22http%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F14%2Fformulaexpr.xsd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F14%2Fformulaexpr.xsd%3C%2FA%3E%20%22%3CBR%20%2F%3Exmlns%3Aicc%3D%22%20%3CA%20href%3D%22http%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F08%2Fimplconfigclass.xsd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F08%2Fimplconfigclass.xsd%3C%2FA%3E%20%22%3CBR%20%2F%3Exmlns%3Amt%3D%22%20%3CA%20href%3D%22http%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F11%2Fmultitest.xsd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F11%2Fmultitest.xsd%3C%2FA%3E%20%22%3CBR%20%2F%3Exmlns%3Avariant%3D%22%20%3CA%20href%3D%22http%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F11%2Fvariant.xsd%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.tresos.de%2F_projects%2FDataModel2%2F11%2Fvariant.xsd%3C%2FA%3E%20%22%26gt%3B%3CBR%20%2F%3E%3CLST%20type%3D%22TOP-LEVEL-PACKAGES%22%3E%3CBR%20%2F%3E%20%3CCTR%20name%3D%22Sbc_fs26%22%20type%3D%22AR-PACKAGE%22%3E%3CBR%20%2F%3E%20%3CLST%20type%3D%22ELEMENTS%22%3E%3CBR%20%2F%3E%20%3CCHC%20name%3D%22Sbc_fs26%22%20type%3D%22AR-ELEMENT%22%20value%3D%22MODULE-CONFIGURATION%22%3E%3CBR%20%2F%3E%20%3CCTR%20type%3D%22MODULE-CONFIGURATION%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22DEF%22%20value%3D%22ASPath%3A%2FTS_T40D34M60I0R0%2FSbc_fs26%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22POST_BUILD_VARIANT_USED%22%20type%3D%22BOOLEAN%22%20value%3D%22false%22%3E%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22IMPLEMENTATION_CONFIG_VARIANT%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22VariantPreCompile%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CCTR%20name%3D%22CommonPublishedInformation%22%20type%3D%22IDENTIFIABLE%22%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22ModuleId%22%20type%3D%22INTEGER%22%20value%3D%22255%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22VendorId%22%20type%3D%22INTEGER%22%20value%3D%2243%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22ArReleaseMajorVersion%22%20type%3D%22INTEGER%22%20value%3D%224%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22ArReleaseMinorVersion%22%20type%3D%22INTEGER%22%20value%3D%229%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22ArReleaseRevisionVersion%22%20type%3D%22INTEGER%22%20value%3D%220%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22SwMajorVersion%22%20type%3D%22INTEGER%22%20value%3D%226%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22SwMinorVersion%22%20type%3D%22INTEGER%22%20value%3D%220%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22SwPatchVersion%22%20type%3D%22INTEGER%22%20value%3D%220%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3C%2FCTR%3E%3CBR%20%2F%3E%20%3CCTR%20name%3D%22SbcDemEventParameterRefs%22%20type%3D%22IDENTIFIABLE%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22ENABLE%22%20value%3D%22false%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3CREF%20name%3D%22SBC_FS26_E_TIMEOUT%22%20type%3D%22REFERENCE%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22ENABLE%22%20value%3D%22false%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FREF%3E%3CBR%20%2F%3E%20%3CREF%20name%3D%22SBC_FS26_E_DEVICE_STATUS%22%20type%3D%22REFERENCE%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22ENABLE%22%20value%3D%22false%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FREF%3E%3CBR%20%2F%3E%20%3C%2FCTR%3E%3CBR%20%2F%3E%20%3CCTR%20name%3D%22SpiConfig%22%20type%3D%22IDENTIFIABLE%22%3E%3CBR%20%2F%3E%20%3CREF%20name%3D%22SpiChannelRef%22%20type%3D%22REFERENCE%22%3E%3CBR%20%2F%3E%20value%3D%22ASPath%3A%2FSpi%2FSpi%2FSpiDriver%2FSpiChannel_FS26%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CREF%20name%3D%22SpiSequenceRef%22%20type%3D%22REFERENCE%22%3E%3CBR%20%2F%3E%20value%3D%22ASPath%3A%2FSpi%2FSpi%2FSpiDriver%2FSpiSequence_FS26%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22SpiAsync%22%20type%3D%22BOOLEAN%22%20value%3D%22false%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22SbcQueueLength%22%20type%3D%22INTEGER%22%20value%3D%2216%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3C%2FREF%3E%3CBR%20%2F%3E%20%3CCTR%20name%3D%22DriverConfig%22%20type%3D%22IDENTIFIABLE%22%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22CloseInitFS%22%20type%3D%22BOOLEAN%22%20value%3D%22true%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22ClearFaultCounter%22%20type%3D%22BOOLEAN%22%20value%3D%22true%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22ExitDebugMode%22%20type%3D%22BOOLEAN%22%20value%3D%22false%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22ReleaseSafetyOutputs%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_NONE%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22ExternalWatchdog%22%20type%3D%22BOOLEAN%22%20value%3D%22false%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22WatchdogType%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_WD_CHALLENGER%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16WatchdogToken%22%20type%3D%22STRING%22%20value%3D%22%26amp%3B%E3%80%8C5AB2%E3%80%8D%26lt%3BBR%22%3E%3C%2FVAR%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22bAsilDLevel%22%20type%3D%22BOOLEAN%22%20value%3D%22true%22%3E%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22SbcRstbCheckNotification%22%20type%3D%22FUNCTION-NAME%22%3E%3CBR%20%2F%3E%20value%3D%22NULL_PTR%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22ENABLE%22%20value%3D%22false%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22SbcWatchdogNotification%22%20type%3D%22FUNCTION-NAME%22%3E%3CBR%20%2F%3E%20value%3D%22NULL_PTR%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22ENABLE%22%20value%3D%22false%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22SbcCheckWatchdogRefreshNotification%22%3E%3CBR%20%2F%3E%20type%3D%22FUNCTION-NAME%22%20value%3D%22NULL_PTR%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22ENABLE%22%20value%3D%22false%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22SbcDisableWatchdogTimer%22%20type%3D%22BOOLEAN%22%3E%3CBR%20%2F%3E%20value%3D%22false%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CCTR%20name%3D%22InitConfig%22%20type%3D%22IDENTIFIABLE%22%3E%3CBR%20%2F%3E%20%3CCTR%20name%3D%22ovuvSafe1Reg%22%20type%3D%22IDENTIFIABLE%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22SHORT-NAME%22%20value%3D%22ovuvSafe1Reg%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16VmonPreOvFs%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_VMON_PRE_OV_FS_REACTION_NO_EFFECT%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16VmonPreUvFs%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_VMON_PRE_UV_FS_REACTION_NO_EFFECT%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16VmonCoreOvFs%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_VMON_CORE_OV_FS_REACTION_NO_EFFECT%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16VmonCoreUvFs%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_VMON_CORE_UV_FS_REACTION_NO_EFFECT%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16VmonLdo1OvFs%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_VMON_LDO1_OV_FS_REACTION_NO_EFFECT%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16VmonLdo1UvFs%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_VMON_LDO1_UV_FS_REACTION_NO_EFFECT%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16VmonLdo2OvFs%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_VMON_LDO2_OV_FS_REACTION_NO_EFFECT%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16VmonLdo2UvFs%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_VMON_LDO2_UV_FS_REACTION_NO_EFFECT%22%2F%26gt%3B%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CCTR%20name%3D%22ovuvSafe2Reg%22%20type%3D%22IDENTIFIABLE%22%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16VmonExtOvFs%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_VMON_EXT_OV_FS_REACTION_NO_EFFECT%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16VmonExtUvFs%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_VMON_EXT_UV_FS_REACTION_NO_EFFECT%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16VmonRefOvFs%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_VMON_REF_OV_FS_REACTION_NO_EFFECT%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16VmonRefUvFs%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_VMON_REF_UV_FS_REACTION_NO_EFFECT%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16VmonTrk2OvFs%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_VMON_TRK2_OV_FS_REACTION_NO_EFFECT%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16VmonTrk2UvFs%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_VMON_TRK2_UV_FS_REACTION_NO_EFFECT%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16VmonTrk1OvFs%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_VMON_TRK1_OV_FS_REACTION_NO_EFFECT%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16VmonTrk1UvFs%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_VMON_TRK1_UV_FS_REACTION_NO_EFFECT%22%2F%26gt%3B%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CCTR%20name%3D%22wdCfgReg%22%20type%3D%22IDENTIFIABLE%22%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16WdErrLimit%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_WD_ERR_LIMIT_6%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16WdRfrLimit%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_WD_RFR_LIMIT_1%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16WdFs%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_WD_FS_REACTION_NO_EFFECT%22%2F%26gt%3B%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CCTR%20name%3D%22safeInputsReg%22%20type%3D%22IDENTIFIABLE%22%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16FccuCfg%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_FCCU_CFG_NO%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16Fccu12FltPol%22%20type%3D%22%E5%88%97%E6%8C%99%26lt%3BBR%20%2F%26gt%3Bvalue%3D%22%20sbc_fs26_fs_fccu12_flt_pol_0_1%3D%22%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16Fccu1FltPol%22%20type%3D%22%E5%88%97%E6%8C%99%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_FCCU1_FLT_POL_LOW%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16Fccu2FltPol%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_FCCU2_FLT_POL_LOW%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16Fccu12Fs%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_FCCU12_FS_REACTION_FS0B%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16Fccu1Fs%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_FCCU1_FS_REACTION_FS0B%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16Fccu2Fs%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_FCCU2_FS_REACTION_FS0B%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16Wake2LpPol%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_WAKE2_LP_POLARITY_LOW%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16ErrmonFaultPol%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_ERRMON_FLT_POLARITY_LOW%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16ErrmonAckTime%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_ERRMON_ACK_TIME_8MS%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16ErrmonFs%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_ERRMON_FS_REACTION_FS0B%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16Fccu12Filt%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_FCCU12_FILT_6US%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CCTR%20name%3D%22fssmReg%22%20type%3D%22IDENTIFIABLE%22%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16FltErrCntLimit%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_FLT_ERR_CNT_LIMIT_6%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16FltErrFs%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_FLT_ERR_REACTION_NO_EFFECT%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16RstbDur%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_RSTB_DUR_10MS%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16BackupFs0b%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_BACKUP_SAFETY_PATH_FS0B_NO%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16BackupFs1b%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_BACKUP_SAFETY_PATH_FS1B_NO%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16ClkMonDis%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_CLK_MON_DIS_DISABLED%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16Dis8s%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_DIS8S_DISABLED%22%2F%26gt%3B%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CCTR%20name%3D%22wdwDurationReg%22%20type%3D%22IDENTIFIABLE%22%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16WdwPeriod%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_WDW_PERIOD_INFINITE%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16WdwDc%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_WDW_DC_62C_37O%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16WdwRecovery%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_WDW_RECOVERY_INFINITE%22%2F%26gt%3B%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CCTR%20name%3D%22abistOnDemand%22%20type%3D%22IDENTIFIABLE%22%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22Abist2Ext%22%20type%3D%22ENUMERATION%22%20value%3D%22NO_ABIST%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22Abist2Ref%22%20type%3D%22ENUMERATION%22%20value%3D%22NO_ABIST%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22Abist2Trk2%22%20type%3D%22ENUMERATION%22%20value%3D%22NO_ABIST%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22Abist2Trk1%22%20type%3D%22ENUMERATION%22%20value%3D%22NO_ABIST%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22Abist2Ldo2%22%20type%3D%22ENUMERATION%22%20value%3D%22NO_ABIST%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22Abist2Ldo1%22%20type%3D%22ENUMERATION%22%20value%3D%22NO_ABIST%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22Abist2Core%22%20type%3D%22ENUMERATION%22%20value%3D%22NO_ABIST%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22Abist2Vpre%22%20type%3D%22ENUMERATION%22%20value%3D%22NO_ABIST%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3C%2FCTR%3E%3CBR%20%2F%3E%20%3CCTR%20name%3D%22intbMaskReg%22%20type%3D%22IDENTIFIABLE%22%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16VpreM%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_VPRE_M_NOT_MASKED%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16CoreM%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_CORE_M_NOT_MASKED%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16Ldo1M%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_LDO1_M_NOT_MASKED%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16Ldo2M%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_LDO2_M_NOT_MASKED%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16Trk1M%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_TRK1_M_NOT_MASKED%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16Trk2M%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_TRK2_M_NOT_MASKED%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16RefM%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_REF_M_NOT_MASKED%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16ExtM%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_EXT_M_NOT_MASKED%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16Fccu1M%22%20type%3D%22%E5%88%97%E6%8C%99%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_FCCU1_M_NOT_MASKED%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16Fccu2M%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_FCCU2_M_NOT_MASKED%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16BadWdM%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_BAD_WD_M_NOT_MASKED%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22u16ErrmonM%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22SBC_FS26_FS_ERRMON_M_NOT_MASKED%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3C%2FCTR%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CCTR%20name%3D%22GeneralConfig%22%20type%3D%22IDENTIFIABLE%22%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22SbcDevErrorDetect%22%20type%3D%22BOOLEAN%22%20value%3D%22false%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22SbcDisableDemReportError%22%20type%3D%22BOOLEAN%22%3E%3CBR%20%2F%3E%20value%3D%22true%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22SbcEnableUserModeSupport%22%20type%3D%22BOOLEAN%22%3E%3CBR%20%2F%3E%20value%3D%22false%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22SbcVersionInfoApi%22%20type%3D%22BOOLEAN%22%20value%3D%22false%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22SbcWakeupApi%22%20type%3D%22BOOLEAN%22%20value%3D%22false%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22SbcLDTApi%22%20type%3D%22BOOLEAN%22%20value%3D%22false%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22SbcAmuxApi%22%20type%3D%22BOOLEAN%22%20value%3D%22false%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22SbcRegulatorApi%22%20type%3D%22BOOLEAN%22%20value%3D%22true%22%3E%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22SbcAbist2Api%22%20type%3D%22BOOLEAN%22%20value%3D%22false%22%3E%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22SbcTimeoutMechanism%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22TICKS%22%26gt%3B%3CBR%20%2F%3E%20%3CA%20name%3D%22IMPORTER_INFO%22%20value%3D%22%40DEF%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3CVAR%20name%3D%22SbcTimeoutMethod%22%20type%3D%22ENUMERATION%22%3E%3CBR%20%2F%3E%20value%3D%22OSIF_COUNTER_DUMMY%22%2F%26gt%3B%3CBR%20%2F%3E%20%3CVAR%20name%3D%22SbcTimeout%22%20type%3D%22INTEGER%22%20value%3D%225000000%22%3E%3C%2FVAR%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3C%2FCTR%3E%3CBR%20%2F%3E%20%3C%2FCTR%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3CBR%20%2F%3E%20%3C%2FVAR%3E%3C%2FCTR%3E%3C%2FVAR%3E%3C%2FVAR%3E%3C%2FVAR%3E%3C%2FVAR%3E%3C%2FCTR%3E%3C%2FCTR%3E%3C%2FVAR%3E%3C%2FVAR%3E%3C%2FVAR%3E%3C%2FVAR%3E%3C%2FVAR%3E%3C%2FVAR%3E%3C%2FVAR%3E%3C%2FCTR%3E%3C%2FVAR%3E%3C%2FVAR%3E%3C%2FVAR%3E%3C%2FVAR%3E%3C%2FVAR%3E%3C%2FVAR%3E%3C%2FVAR%3E%3C%2FCTR%3E%3C%2FCTR%3E%3C%2FCTR%3E%3C%2FREF%3E%3C%2FCTR%3E%3C%2FCTR%3E%3C%2FCHC%3E%3C%2FLST%3E%3C%2FCTR%3E%3C%2FLST%3E%3C%2FCTR%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346685%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20debug%20problem%20when%20pmic%20is%20not%20in%20debug%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346685%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%94%E3%83%B3%E3%82%92GND%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%8C%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81SBC%E3%81%8CINIT%E3%82%B9%E3%83%86%E3%83%BC%E3%82%B8%E3%81%AB%E5%85%A5%E3%81%A3%E3%81%9F%E5%BE%8C%E3%80%81256ms%E4%BB%A5%E5%86%85%E3%81%AB%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%AB%E4%BF%A1%E5%8F%B7%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%80%81INIT%E9%96%A2%E9%80%A3%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%86%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81RSTB%E3%81%8C%E5%AE%9A%E6%9C%9F%E7%9A%84%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AB%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%81%95%E3%82%8C%E3%80%81MCU%E3%81%8C%E8%AA%A4%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%B8%8B%E8%A8%98%E3%81%AE%E6%B7%BB%E4%BB%98%E7%94%BB%E5%83%8F%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%82%8C%E3%81%AFWD%E7%8A%AC%E3%81%AE%E7%B5%A6%E9%A4%8C%E6%89%8B%E9%A0%86%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2349376%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20debug%20problem%20when%20pmic%20is%20not%20in%20debug%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2349376%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E256ms%E4%BB%A5%E5%86%85%E3%81%AB%E7%8A%AC%E3%81%AB%E9%A4%8C%E3%82%92%E4%B8%8E%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%A7%E3%80%81JTAG%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%86%8D%E5%BA%A6%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E5%89%8D%E8%BF%B0%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81JTAG%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6PMIC%E3%81%8C%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81256ms%E4%BB%A5%E5%86%85%E3%81%ABPMIC%E3%82%92%E5%86%8D%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2349506%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20debug%20problem%20when%20pmic%20is%20not%20in%20debug%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2349506%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EJTAG%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%8CFS26%E3%81%AERSTB%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%82%92%E4%B8%8E%E3%81%88%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E6%A4%9C%E8%A8%BC%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
