can‘t debug jlink s32 ide 2018
3,592 次查看
yujinsheng
hi
   The problem is shown in figure Even in the demo project this is the same effect but it was not easy to use before for unknown reasons
3,574 次查看
danielmartynek
You use an old version of the Design Studio.
Can you try with S32DS 2.2 or S32DS 3.3?
The configuration seems to be correct.
But I would recommend contacting Segger support, because the error was reported by the Segger plugin.
5 回复数
3,566 次查看
yujinsheng
Thank you for your reply.
The error message forgot to provide, segger software can be linked, but our IDE can't, because colleagues' environment is 2018, I tried s32DS 2.2 is really good, but I want to know what's wrong with 2018, because we officially use 2018 in office.Want to find out why?
3,575 次查看
danielmartynek
3,566 次查看
yujinsheng
3,556 次查看
danielmartynek
Did you import the project from an older S32DS version or was the project built in S32DS R1?
Thank you,
BR, Daniel
3,550 次查看
yujinsheng
I'm trying to official demo, thanks for the reply, we have decided to use s32ds arm version 2.2 does not pursue the cause of the problem
