VLPR
VLPR
LzdOo
使用S32K144的VLPR模式,进入VLPR模式后我关闭了外设电路,但没有对FTM、ADC、CAN等模块进行反初始化,此时电流在3.6mA左右,请问我该进行哪些操作来进一步降低电流至1.5mA?
Senlent
Hi@LzdOo
VLPR在25摄氏度下,所有的外设模块都关闭的情况下,理论的功耗都有1.48mA.
其次,如果CAN ,FTM,或者ADC没关闭,这个功耗是应该超过2mA以上的(没有VLPR下ADC的功耗数据)
LzdOo
请问CAN、FTM以及LPUART的关闭是以deinit的形式实现的吗?我用这种方式关闭FTM和LPUART后发现电流与未关闭时区别几乎没有是什么原因?(项目要求VLPR时ADC需要工作)
Senlent
Hi@LzdOo
是的,这种方式可以关闭外设,但是作为CAN或者FTM的输出端口配置也要考虑改变,例如在进入VLPR模式的时候把这些通信的接口设置为模拟输入模式。CAN和FTM在VLPR模式下的功耗本来就很小,几十微安,测试设备精度不高可能会导致你观察不到这种变化。
Senlent
LzdOo
这个文档是看过了的,首先我选用的是VLPR而文档中选用的是VLPS,其次按照文档内容操作寄存器及时钟配置后,对实际电流基本没有影响。
请问还有什么其他途径吗?
%3CLINGO-SUB%20id%3D%22lingo-sub-2150401%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3EVLPR%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150401%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EUsing%20the%20S32K144%20in%20VLPR%20mode%2C%20I%20turned%20off%20the%20peripheral%20circuits%20after%20entering%20the%20VLPR%20mode%2C%20but%20did%20not%20de-initialize%20the%20FTM%2C%20ADC%2C%20CAN%20and%20other%20modules%2C%20at%20this%20point%2C%20the%20current%20is%20around%203.6mA%2C%20what%20should%20I%20do%20to%20further%20reduce%20the%20current%20to%201.5mA%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150784%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20VLPR%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150784%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EHi%40LzdOo%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EYes%2C%20this%20way%20you%20can%20turn%20off%20the%20peripherals%2C%20but%20the%20configuration%20of%20the%20output%20ports%20as%20CAN%20or%20FTM%20should%20also%20be%20considered%20for%20change%2C%20e.g.%20setting%20the%20interfaces%20for%20these%20communications%20to%20analog%20input%20mode%20when%20entering%20VLPR%20mode.CAN%20and%20FTM%20in%20VLPR%20mode%20consume%20inherently%20small%20amounts%20of%20power%2C%20tens%20of%20microamps%2C%20and%20poor%20accuracy%20of%20the%20test%20equipment%20may%20result%20in%20you%20not%20observing%20this%20change.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150680%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20VLPR%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150680%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EIs%20the%20shutdown%20of%20CAN%2C%20FTM%20and%20LPUART%20realized%20as%20deinit%3F%20What%20is%20the%20reason%20that%20after%20I%20turn%20off%20the%20FTM%20and%20LPUART%20in%20this%20way%20I%20find%20that%20the%20current%20is%20almost%20no%20different%20from%20when%20they%20are%20not%20turned%20off%3F%20(ADC%20needs%20to%20work%20when%20VLPR%20is%20required%20by%20the%20project)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150616%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20VLPR%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150616%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EHi%40LzdOo%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EVLPR%20has%20a%20theoretical%20power%20consumption%20of%201.48mA%20at%2025%20degrees%20Celsius%20with%20all%20peripheral%20modules%20turned%20off.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Senlent_1-1754981391123.png%22%20style%3D%22width%3A%20591px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_1-1754981391123.png%22%20style%3D%22width%3A%20591px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F351924i35C997DE33770881%2Fimage-dimensions%2F591x336%3Fv%3Dv2%22%20width%3D%22591%22%20height%3D%22336%22%20role%3D%22button%22%20title%3D%22Senlent_1-1754981391123.png%22%20alt%3D%22Senlent_1-1754981391123.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ESecondly%2C%20if%20CAN%20%2CFTM%2C%20or%20ADC%20is%20not%20turned%20off%2C%20this%20power%20consumption%20is%20supposed%20to%20be%20more%20than%202mA%20or%20more%20(there%20is%20no%20power%20data%20for%20ADC%20under%20VLPR)%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Senlent_0-1754980931761.png%22%20style%3D%22width%3A%20593px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1754980931761.png%22%20style%3D%22width%3A%20593px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F351923i124C553AA1DCF173%2Fimage-dimensions%2F593x275%3Fv%3Dv2%22%20width%3D%22593%22%20height%3D%22275%22%20role%3D%22button%22%20title%3D%22Senlent_0-1754980931761.png%22%20alt%3D%22Senlent_0-1754980931761.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150549%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20VLPR%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150549%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20document%20is%20read%2C%20first%20of%20all%2C%20I%20chose%20the%20VLPR%20and%20the%20document%20selected%20VLPS%2C%20and%20secondly%2C%20in%20accordance%20with%20the%20contents%20of%20the%20document%20operation%20registers%20and%20clock%20configuration%2C%20the%20actual%20current%20basically%20has%20no%20effect.%3C%2FP%3E%3CP%3EIs%20there%20any%20other%20way%2C%20please%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150478%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20VLPR%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150478%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22mailto%3AHi%40LzdOo%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EHi%40LzdOo%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EPlease%20refer%20to%20the%20documentation%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fmp.weixin.qq.com%2Fs%3F__biz%3DMzI0MDk0ODcxMw%3D%3D%26amp%3Bmid%3D2247485647%26amp%3Bidx%3D1%26amp%3Bsn%3D2738a55639240dc837d93201161f574a%26amp%3Bchksm%3De9124c49de65c55f779e12286f21ec782473cd98ab181f818becc65dccb31a3efd092e42c2ed%26amp%3Bscene%3D21%23wechat_redirect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fmp.weixin.qq.com%2Fs%3F__biz%3DMzI0MDk0ODcxMw%3D%3D%20%26amp%3Bmid%3D2247485647%20%26amp%3Bidx%3D1%20%26amp%3Bsn%3D2738a55639240dc837d93201161f574a%20%26amp%3Bchksm%3D%20e9124c49de65c55f779e12286f21ec782473cd98ab181f818becc65dccb31a3efd092e42c2ed%20%26amp%3Bscene%3D21%23wechat_redirect%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
