Transition from one app to another
SreejithN
In my current project there is an requirement to start one application from another. For example Pre-Loader (Application 1) will checks the the loader validity and start executing the valid loader (Application 2). This Pre-Loader to loader transition is should be done by assembly code (Without any software reset).
Could you please provide an example assembly code for this transition
Thanks!!
Senlent
Hi@SreejithN
your problem seems to be with bootloader .
If I understand correctly, you are looking for something like the following code.
you can find the demo code in the link below
https://www.nxp.com/search?keyword=AN12218&start=0
