The program runs normally with a debugger, but the program runs flying without a debugger
1,461件の閲覧回数
SethWang
Using S32K312, I found that when debugging on FLASH with a debugger, the program ran normally. Without a debugger, when running the ADC to initialize the operation on the MCR registers, the program runaway. After doing some debugging, I found that when operating the registers of PWM or SPI without a debugger, the program will also runaway, but with a debugger, the program runs normally.
The program are all running on FLASH, I don't know the difference between with and without a debuger? Do you know why the program runaway without a debugger?
Thank you
1,437件の閲覧回数
SethWang
Thank you.
The reasons is the configuration problem of PLL .The problem has solved.
5 返答(返信)
1,453件の閲覧回数
danielmartynek
Hi @SethWang,
What does it actually do? Do you see a fault exception or a system reset?
The debugger can typically disable the WDOG or initialize SRAM ECC.
Can you double-check the SRAM ECC?
BR, Daniel
774件の閲覧回数
anakha
how can I check them without debugger?
My app also runs OK with debugger but goes to hard fault handler but I am not sure.
I put below code to my app and my test rgb led goes to red(error).
void HardFault_Handler(void)
set_rgb_status(ERROR);
while(TRUE){};
767件の閲覧回数
danielmartynek
Hi @anakha,
What debugger do you have?
Multilink can be attached to the running MCU stuck in the exception handler.
Make sure the clocks are configured precisely to one of the clock options.
RM, 24.7.2 System clocking configurations
1,438件の閲覧回数
SethWang
Thank you.
848件の閲覧回数
DouDou1
Can you tell me how you solved the problem?
