The PE driver is not recognized during s32ds debugging
hwa
The PE driver cannot be recognized when s32ds is debugging, but my computer can recognize it, and I have tried to reinstall the driver, PE rebrush and other methods, but it has not been solved.
hwa
hi,@Daniel: My problem has been solved, this is caused by the disabled port on the company's side, thank you for your enthusiastic help.
danielmartynek
Hi @hwa,
Which S32DS IDE version do you have?
Can you update the PE Micro Interface plugin?
Is the probe's blue LED on?
What verision of Multilink is it?
hwa
1.The s32ds version is 3.4
2.I have updated the PE microinterface plugin
3.Yes,the probe's blue LED is bright.
4.The version is 10.29
danielmartynek
Hi @hwa,
Do you have just one probe or more?
Have you tested the probe with other machines?
BR, Daniel
hwa
