TempSense data is so weird..
4,251 次查看
rlaxortn
i am using s32k314, s32ds 3.6.1 Version.
i make a source code for reading MCU TempSense.
when i get data from MCU TempSense data, data is so weird..
before i use Adc_Sar_Ip_TempSenseGetTemp function, i use Adc_Sar_Ip_TempSenseEnable(1U).
reason parameter 1 is i use make TempSense adc channel in adc1 by adc config.
1. why data is so weird..?
2. do i have to do something?
3. when you see first pic, adc resolution is 14. so tempSens resolution is 14bit?????
thanks to help.
标记 (2)
4,193 次查看
Senlent
Hi@rlaxortn
In your last answer, you said "because MCU Supply voltage is 3.3V". Now you say "MCU VREFH is 5.0V". Are you serious?
In your configuration , the TempSense Voltage Supply is 0x53, that is 5.3V
the Adc Voltage Reference is 53->0x35->3.5V
We've been talking for so long and you keep making the same mistakes。
If your VREFH is 5V, then you should set both values to 0x50.
Secondly, to improve stability, you can set the following parameters to a larger value and test again.
9 回复数
4,236 次查看
Senlent
Hi@rlaxortn
Your ADC reference voltage is 3.2V?
4,221 次查看
rlaxortn
@Senlent
1. How can I know the supply voltage of Tempsense? Isn't the operating power of MCU the supply voltage of TEMPSense? or dose TempSense have other pin for getting Voltage like adc Channel?
2. because MCU Supply voltage is 3.3V. so i set TempSense Supply Voltage is 50(0x32)-> 3.2V.
3. anyway i test Tempsense Supply voltage, 0x50(5.0V), 0x15(1.5V), 0x33(3.3v).
when i set 0x50.
(TemperatureRaw is Integer value, mcuTempData is float for print)
ex) 2205 -> 0x89D
when i set 0x33(3.3V)
ex) 2537->0x9e9
when i set 0x15(1.5V)
ex) 5515->0x158B
标记 (2)
4,206 次查看
Senlent
Hi@rlaxortn
From the data you provided, your ADC sampling results fluctuate greatly. This should be due to some problems in your ADC sampling configuration.
1. Provide your project and I will help you check the ADC settings
2. Please confirm the ADC reference voltage on your current hardware and test the actual voltage of VREFH.
4,198 次查看
rlaxortn
@Senlent
1. it is difficult i give to you source code. but i can give adc configure by image capture. is it okay?
2. MCU VREFH is 5.0v, and VREFL is 0V.
标记 (1)
4,190 次查看
rlaxortn
@Senlent
1. sorry, that is my mistake. VREF is 5.0V absolutely. so i already change value 0x50.
but result is same.
2. i gonna set larger than current value.
But I don't think that's a solution. i can catch the data shaking, but the values are weird.
you know previous pics, temperature is over 150 at least.
标记 (2)
4,183 次查看
Senlent
Hi@rlaxortn
What's your RTD version is?
4,092 次查看
rlaxortn
@Senlent
i check hardware by hardware engineer. so i knew Data is unstable.
although i supply vref voltage is 5.0V,  vref is unstable (4.1V~ 5.8V).
RTD Version is 4.0.0.
thanks to help.
4,194 次查看
Senlent
Hi@rlaxortn
639 次查看
Senlent
Hi@rlaxortn
Just to correct myself, there were some errors in my answer.
The data format used was S11.4.
Therefore, the actual value = original 16-bit signed number ÷ 16
For example:
1.0x15 = 21 / 16 = 1.3125V
2.0x35 = 53 / 16 = 3.3125V
3.0x50 = 80 / 16 = 5V
%3CLINGO-SUB%20id%3D%22lingo-sub-2135342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ETempSense%20%E6%95%B0%E6%8D%AE%E5%A4%AA%E5%A5%87%E6%80%AA%E4%BA%86......%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2135342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20s32k314%EF%BC%8Cs32ds%203.6.1%20%E7%89%88%E6%9C%AC%E3%80%82%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E5%88%B6%E4%BD%9C%E4%BA%86%E8%AF%BB%E5%8F%96%20MCU%20TempSense%20%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%E3%80%82%20%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E4%BB%8E%20MCU%20TempSense%20%E6%95%B0%E6%8D%AE%E4%B8%AD%E8%8E%B7%E5%8F%96%E6%95%B0%E6%8D%AE%E6%97%B6%EF%BC%8C%E6%95%B0%E6%8D%AE%E9%9D%9E%E5%B8%B8%E5%A5%87%E6%80%AA%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%9C%A8%E4%BD%BF%E7%94%A8%3CSPAN%3EAdc_Sar_Ip_TempSenseGetTemp%20%E5%87%BD%E6%95%B0%20%3C%2FSPAN%3E%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%20Adc_Sar_Ip_TempSenseEnable(1U)%E3%80%82%20%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%8F%82%E6%95%B0%201%20%E7%9A%84%E5%8E%9F%E5%9B%A0%E6%98%AF%E6%88%91%E9%80%9A%E8%BF%87%20adc%20%E9%85%8D%E7%BD%AE%E5%9C%A8%20adc1%20%E4%B8%AD%E4%BD%BF%E7%94%A8%E4%BA%86%20TempSense%20adc%20%E9%80%9A%E9%81%93%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F347938i178E7773962DB844%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%221.png%22%20alt%3D%221.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F347939i6095AF7F3E259A1E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%223.png%22%20alt%3D%223.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20508px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20508px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20508px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F347940i17C36C0936BE6889%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222.png%22%20alt%3D%222.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E1.%20%E4%B8%BA%E4%BB%80%E4%B9%88%E6%95%B0%E6%8D%AE%E5%A6%82%E6%AD%A4%E5%A5%87%E6%80%AA%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2.%20%E6%88%91%E5%BF%85%E9%A1%BB%E5%81%9A%E4%BB%80%E4%B9%88%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E3.%20%E5%BD%93%E6%82%A8%E7%9C%8B%E5%88%B0%E7%AC%AC%E4%B8%80%E5%BC%A0%E5%9B%BE%E7%89%87%E6%97%B6%EF%BC%8Cadc%20%E7%9A%84%E5%88%86%E8%BE%A8%E7%8E%87%E4%B8%BA%2014%EF%BC%8C%E5%9B%A0%E6%AD%A4%20tempSens%20%E7%9A%84%E5%88%86%E8%BE%A8%E7%8E%87%E4%B8%BA%2014bit%3F%3F%3F%3F%3F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%84%9F%E8%B0%A2%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TempSense%20data%20is%20so%20weird..%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F188029%22%20target%3D%22_blank%22%3E%40Senlent%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E7%94%B1%E7%A1%AC%E4%BB%B6%E5%B7%A5%E7%A8%8B%E5%B8%88%E6%A3%80%E6%9F%A5%E7%A1%AC%E4%BB%B6%E3%80%82%E6%89%80%E4%BB%A5%E6%88%91%E7%9F%A5%E9%81%93%3CSPAN%3EData%20%E4%B8%8D%E7%A8%B3%E5%AE%9A%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%99%BD%E7%84%B6%E6%88%91%E7%9A%84%E7%94%B5%E6%BA%90%20vref%20%E7%94%B5%E5%8E%8B%E4%B8%BA%205.0V%EF%BC%8C%E4%BD%86%20vref%20%E4%B8%8D%E7%A8%B3%E5%AE%9A%EF%BC%884.1V~%205.8V%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ERTD%20%E7%89%88%E6%9C%AC%E4%B8%BA%204.0.0%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%84%9F%E8%B0%A2%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136312%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TempSense%20data%20is%20so%20weird..%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136312%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22mailto%3AHi%40rlaxortn%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E4%BD%A0%E5%A5%BD%40rlaxortn%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E7%9A%84%20RTD%20%E7%89%88%E6%9C%AC%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136284%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TempSense%20data%20is%20so%20weird..%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136284%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F188029%22%20target%3D%22_blank%22%3E%40Senlent%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E1.%20%E5%AF%B9%E4%B8%8D%E8%B5%B7%EF%BC%8C%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%E5%A4%B1%E8%AF%AF%E3%80%82VREF%20%E7%BB%9D%E5%AF%B9%E7%94%B5%E5%8E%8B%E4%B8%BA%205.0V%E3%80%82%E6%89%80%E4%BB%A5%E6%88%91%E5%B7%B2%E7%BB%8F%E6%9B%B4%E6%94%B9%E4%BA%86%200x50%E3%80%82%20%3C%2FP%3E%3CP%3E%E4%BD%86%E7%BB%93%E6%9E%9C%E6%98%AF%E4%B8%80%E6%A0%B7%E7%9A%84%E3%80%82%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2.%20%E6%88%91%E8%A6%81%E8%AE%BE%E7%BD%AE%E6%AF%94%E5%BD%93%E5%89%8D%E5%80%BC%E6%9B%B4%E5%A4%A7%E7%9A%84%E5%80%BC%E3%80%82%20%3C%2FP%3E%3CP%3E%E4%BD%86%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E4%B8%8D%E6%98%AF%E8%A7%A3%E5%86%B3%E5%8A%9E%E6%B3%95%E3%80%82%E6%88%91%E5%8F%AF%E4%BB%A5%E6%8D%95%E6%8D%89%E5%88%B0%E6%99%83%E5%8A%A8%E7%9A%84%E6%95%B0%E6%8D%AE%EF%BC%8C%E4%BD%86%E6%95%B0%E5%80%BC%E5%BE%88%E5%A5%87%E6%80%AA%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%A0%E7%9F%A5%E9%81%93%E4%B9%8B%E5%89%8D%E7%9A%84%E7%85%A7%E7%89%87%EF%BC%8C%E6%B8%A9%E5%BA%A6%E8%87%B3%E5%B0%91%E8%B6%85%E8%BF%87%20150%20%E6%91%84%E6%B0%8F%E5%BA%A6%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136266%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TempSense%20data%20is%20so%20weird..%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136266%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22mailto%3AHi%40rlaxortn%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E4%BD%A0%E5%A5%BD%40rlaxortn%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%E6%82%A8%E7%9A%84%E6%9C%80%E5%90%8E%E4%B8%80%E4%B8%AA%E7%AD%94%E6%A1%88%E4%B8%AD%EF%BC%8C%E6%82%A8%E8%AF%B4%22%3CSTRONG%3E%20%3C%2FSTRONG%3E%3CSPAN%3E%E6%98%AF%E5%9B%A0%E4%B8%BA%3CSTRONG%3E%20MCU%20%E7%9A%84%E7%94%B5%E6%BA%90%E7%94%B5%E5%8E%8B%E4%B8%BA%203.3V%20%22%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%E3%80%82%E7%8E%B0%E5%9C%A8%E6%82%A8%E8%AF%B4%22%3CSTRONG%3EMCU%20VREFH%20%E4%B8%BA%205.0V%3C%2FSTRONG%3E%22%20%E3%80%82%E4%BD%A0%E6%98%AF%E8%AE%A4%E7%9C%9F%E7%9A%84%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%E6%82%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E4%B8%AD%EF%BC%8C%E6%B8%A9%E5%BA%A6%E6%84%9F%E5%BA%94%E7%94%B5%E5%8E%8B%E7%94%B5%E6%BA%90%E4%B8%BA%200x53%EF%BC%8C%E5%8D%B3%205.3V%3C%2FP%3E%0A%3CP%3EAdc%20%E5%8F%82%E8%80%83%E7%94%B5%E5%8E%8B%E4%B8%BA%2053-%26gt%3B%200x35-%26gt%3B%203.5V%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E8%B0%88%E4%BA%86%E8%BF%99%E4%B9%88%E4%B9%85%EF%BC%8C%E4%BD%A0%E5%8D%B4%E6%80%BB%E6%98%AF%E7%8A%AF%E5%90%8C%E6%A0%B7%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Senlent_1-1752817875816.png%22%20style%3D%22width%3A%20640px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_1-1752817875816.png%22%20style%3D%22width%3A%20640px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_1-1752817875816.png%22%20style%3D%22width%3A%20640px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348195i7419DBCFB0C6692B%2Fimage-dimensions%2F640x152%3Fv%3Dv2%22%20width%3D%22640%22%20height%3D%22152%22%20role%3D%22button%22%20title%3D%22Senlent_1-1752817875816.png%22%20alt%3D%22Senlent_1-1752817875816.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Senlent_2-1752818096266.png%22%20style%3D%22width%3A%20644px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_2-1752818096266.png%22%20style%3D%22width%3A%20644px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_2-1752818096266.png%22%20style%3D%22width%3A%20644px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348197i2E39EB64A9D89595%2Fimage-dimensions%2F644x87%3Fv%3Dv2%22%20width%3D%22644%22%20height%3D%2287%22%20role%3D%22button%22%20title%3D%22Senlent_2-1752818096266.png%22%20alt%3D%22Senlent_2-1752818096266.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%20VREFH%20%E4%B8%BA%205V%EF%BC%8C%E5%88%99%E5%BA%94%E5%B0%86%E4%B8%A4%E4%B8%AA%E5%80%BC%E9%83%BD%E8%AE%BE%E7%BD%AE%E4%B8%BA%200x50%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%85%B6%E6%AC%A1%EF%BC%8C%E4%B8%BA%E4%BA%86%E6%8F%90%E9%AB%98%E7%A8%B3%E5%AE%9A%E6%80%A7%EF%BC%8C%E5%8F%AF%E4%BB%A5%E5%B0%86%E4%BB%A5%E4%B8%8B%E5%8F%82%E6%95%B0%E8%AE%BE%E7%BD%AE%E4%B8%BA%E8%BE%83%E5%A4%A7%E5%80%BC%EF%BC%8C%E7%84%B6%E5%90%8E%E5%86%8D%E6%AC%A1%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Senlent_3-1752818335937.png%22%20style%3D%22width%3A%20692px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_3-1752818335937.png%22%20style%3D%22width%3A%20692px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_3-1752818335937.png%22%20style%3D%22width%3A%20692px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348199i898F8462730182C6%2Fimage-dimensions%2F692x102%3Fv%3Dv2%22%20width%3D%22692%22%20height%3D%22102%22%20role%3D%22button%22%20title%3D%22Senlent_3-1752818335937.png%22%20alt%3D%22Senlent_3-1752818335937.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TempSense%20data%20is%20so%20weird..%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F188029%22%20target%3D%22_blank%22%3E%40Senlent%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E1.%20%E6%88%91%E5%BE%88%E9%9A%BE%E5%90%91%E6%82%A8%E6%8F%90%E4%BE%9B%E6%BA%90%E4%BB%A3%E7%A0%81%E3%80%82%E4%BD%86%E6%88%91%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E5%9B%BE%E5%83%8F%E6%8D%95%E8%8E%B7%E6%9D%A5%E9%85%8D%E7%BD%AE%20adc%E3%80%82%E5%8F%AF%E4%BB%A5%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348187i954FD43E0F194DDF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%221.png%22%20alt%3D%221.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348186iBFBEAD13AEA56B69%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222.png%22%20alt%3D%222.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2.MCU%20VREFH%20%E4%B8%BA%205.0%20%E4%BC%8F%EF%BC%8CVREFL%20%E4%B8%BA%200%20%E4%BC%8F%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TempSense%20data%20is%20so%20weird..%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%40%3CSPAN%3Erlaxortn%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E4%BB%8E%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E6%95%B0%E6%8D%AE%E6%9D%A5%E7%9C%8B%EF%BC%8C%E6%82%A8%E7%9A%84%20ADC%20%E9%87%87%E6%A0%B7%E7%BB%93%E6%9E%9C%E6%B3%A2%E5%8A%A8%E5%BE%88%E5%A4%A7%E3%80%82%E8%BF%99%E5%BA%94%E8%AF%A5%E6%98%AF%E7%94%B1%E4%BA%8E%E6%82%A8%E7%9A%84%20ADC%20%E9%87%87%E6%A0%B7%E9%85%8D%E7%BD%AE%E5%AD%98%E5%9C%A8%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%E9%80%A0%E6%88%90%E7%9A%84%E3%80%82%3CBR%20%2F%3E1%E3%80%82%E6%8F%90%E4%BE%9B%E4%BD%A0%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%88%91%E4%BC%9A%E5%B8%AE%E4%BD%A0%E6%A3%80%E6%9F%A5%20ADC%20%E8%AE%BE%E7%BD%AE%20%3CBR%20%2F%3E%202.%E8%AF%B7%E7%A1%AE%E8%AE%A4%E5%BD%93%E5%89%8D%E7%A1%AC%E4%BB%B6%E4%B8%8A%E7%9A%84%20ADC%20%E5%8F%82%E8%80%83%E7%94%B5%E5%8E%8B%E5%B9%B6%E6%B5%8B%E8%AF%95%20VREFH%20%E7%9A%84%E5%AE%9E%E9%99%85%E7%94%B5%E5%8E%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136117%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TempSense%20data%20is%20so%20weird..%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136117%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F188029%22%20target%3D%22_blank%22%3E%40Senlent%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E1.%3CSPAN%3E%E5%A6%82%E4%BD%95%E7%9F%A5%E9%81%93%20Tempsense%20%E7%9A%84%E7%94%B5%E6%BA%90%E7%94%B5%E5%8E%8B%EF%BC%9F%E5%8D%95%E7%89%87%E6%9C%BA%E7%9A%84%E5%B7%A5%E4%BD%9C%E7%94%B5%E5%8E%8B%E4%B8%8D%E5%B0%B1%E6%98%AF%20TEMPSense%20%E7%9A%84%E7%94%B5%E6%BA%90%E7%94%B5%E5%8E%8B%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2.%20%E5%9B%A0%E4%B8%BA%20MCU%20%E7%9A%84%E7%94%B5%E6%BA%90%E7%94%B5%E5%8E%8B%E4%B8%BA%203.3V%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E5%B0%86%E6%B8%A9%E5%BA%A6%E6%84%9F%E5%BA%94%E7%94%B5%E6%BA%90%E7%94%B5%E5%8E%8B%E8%AE%BE%E7%BD%AE%E4%B8%BA%2050(0x32)-%26gt%3B%203.2V%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%97%A0%E8%AE%BA%E5%A6%82%E4%BD%95%EF%BC%8C%E6%88%91%E9%83%BD%E8%A6%81%E6%B5%8B%E8%AF%95%20Tempsense%20%E7%94%B5%E6%BA%90%E7%94%B5%E5%8E%8B%EF%BC%8C0x50%EF%BC%885.0V%EF%BC%89%E3%80%810x15%EF%BC%881.5V%EF%BC%89%E3%80%810x33%EF%BC%883.3v%EF%BC%89%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%BD%93%E6%88%91%E8%AE%BE%E7%BD%AE%200x50%20%E6%97%B6%3C%2FP%3E%3CP%3E(TemperatureRaw%20%E6%98%AF%E6%95%B4%E6%95%B0%E5%80%BC%EF%BC%8CmcuTempData%20%E6%98%AF%E7%94%A8%E4%BA%8E%E6%89%93%E5%8D%B0%E7%9A%84%E6%B5%AE%E7%82%B9%E6%95%B0%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3Eex)%202205%20-%26gt%3B%200x89D%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%225volt.png%22%20style%3D%22width%3A%20633px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225volt.png%22%20style%3D%22width%3A%20633px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225volt.png%22%20style%3D%22width%3A%20633px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348146i25319E62C5A167FB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%225volt.png%22%20alt%3D%225volt.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%BD%93%E6%88%91%E8%AE%BE%E7%BD%AE%200x33%EF%BC%883.3V%EF%BC%89%E6%97%B6%3C%2FP%3E%3CP%3E(TemperatureRaw%20%E6%98%AF%E6%95%B4%E6%95%B0%E5%80%BC%EF%BC%8CmcuTempData%20%E6%98%AF%E7%94%A8%E4%BA%8E%E6%89%93%E5%8D%B0%E7%9A%84%E6%B5%AE%E7%82%B9%E6%95%B0%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3Eex)%202537-%26gt%3B0x9e9%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2233volt.png%22%20style%3D%22width%3A%20648px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2233volt.png%22%20style%3D%22width%3A%20648px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2233volt.png%22%20style%3D%22width%3A%20648px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348148i28674AB47505093D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2233volt.png%22%20alt%3D%2233volt.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%BD%93%E6%88%91%E8%AE%BE%E7%BD%AE%200x15%EF%BC%881.5V%EF%BC%89%E6%97%B6%3C%2FP%3E%3CP%3Eex)%205515-%26gt%3B0x158B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2215volt.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2215volt.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2215volt.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348149iBF253347652C3114%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2215volt.png%22%20alt%3D%2215volt.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2135567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TempSense%20data%20is%20so%20weird..%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2135567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%40%3CSPAN%3Erlaxortn%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BD%A0%E7%9A%84%20ADC%20%E5%8F%82%E8%80%83%E7%94%B5%E5%8E%8B%E6%98%AF%203.2V%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222025-07-17_15-29-30.png%22%20style%3D%22width%3A%20548px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222025-07-17_15-29-30.png%22%20style%3D%22width%3A%20548px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222025-07-17_15-29-30.png%22%20style%3D%22width%3A%20548px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348002iCC990FA6B8C9CEDA%2Fimage-dimensions%2F548x413%3Fv%3Dv2%22%20width%3D%22548%22%20height%3D%22413%22%20role%3D%22button%22%20title%3D%222025-07-17_15-29-30.png%22%20alt%3D%222025-07-17_15-29-30.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2394683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TempSense%20data%20is%20so%20weird..%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2394683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22mailto%3AHi%40rlaxortn%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E4%BD%A0%E5%A5%BD%40rlaxortn%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%9B%B4%E6%AD%A3%E4%B8%80%E4%B8%8B%EF%BC%8C%E6%88%91%E7%9A%84%E5%9B%9E%E7%AD%94%E4%B8%AD%E6%9C%89%E4%B8%80%E4%BA%9B%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%89%80%E7%94%A8%E6%95%B0%E6%8D%AE%E6%A0%BC%E5%BC%8F%E4%B8%BA%20S11.4%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%AE%9E%E9%99%85%E5%80%BC%20%3D%20%E5%8E%9F%E5%A7%8B%2016%20%E4%BD%8D%E6%9C%89%E7%AC%A6%E5%8F%B7%E6%95%B0%20%C3%B7%2016%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FP%3E%0A%3CP%3E1.0%C3%9715%20%3D%2021%20%2F%2016%20%3D%201.3125V%3C%2FP%3E%0A%3CP%3E2.0%C3%9735%20%3D%2053%20%2F%2016%20%3D%203.3125V%3C%2FP%3E%0A%3CP%3E3.0%C3%9750%20%3D%2080%20%2F%2016%20%3D%205V%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
