STCU2 PLL question
STCU2 PLL question
Pusoy
In the "safety->STCU2" section of S32K3XXRM, there is a configuration register for PLL located at STCU2->RUNSW.
  1. When our clock configuration uses PLL, do we need to enable these two fields?
petervlna
Yes, you have to enable them if you use PLL for tests.
I guess SAF already has this enabled in some run function, but in case you have your own driver you have to take care of these bits.
Peter
petervlna
Peter
