SPI callback event
SPI callback event
chris_010
hi, when  using spi callback function, I meet a trouble, need some help.
 my code description: I use LPSI0 as slave to communicate with external device,using interrupt mode.here is my code:
callback function defined:
void lpspi_callback_int(uint8 Instance, Lpspi_Ip_EventType Event)
Event_global = Event;
if(Event ==LPSPI_IP_EVENT_END_TRANSFER)
// Cache_Ip_InvalidateByAddr(CACHE_IP_CORE,CACHE_IP_DATA, (uint32)&rxBuffer[0U], 8);
// read data from rxBuffer
t++;
__asm volatile ("nop");
else if (Event ==LPSPI_IP_EVENT_FAULT)
start receive data:
lpspi_status = Lpspi_Ip_AsyncTransmit(&SLAVE_EXTERNAL_DEVICE_1, TxSlaveBuffer, RxSlaveBuffer, NUMBER_OF_BYTES, lpspi_callback_int);
Phenomenon: The callback function is invoked when the master sends data for the first time, but it is not invoked during subsequent data transmissions.
How to fix this issue? Ensure the callback function is triggered on every external SPI data transmission.
PetrS
do you call Lpspi_Ip_AsyncTransmit again after callback is invoked, to prepare slave for next transfer? This must be called before master sends new frame.
BR, Petr
PetrS
BR, Petr
chris_010
thanks a lot.It work well now.
%3CLINGO-SUB%20id%3D%22lingo-sub-2288765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESPI%20callback%20event%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2288765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%2C%20when%26nbsp%3B%20using%20spi%20callback%20function%2C%20I%20meet%20a%20trouble%2C%20need%20some%20help.%3C%2FP%3E%3CP%3E%26nbsp%3Bmy%20code%20description%3A%20I%20use%20LPSI0%20as%20slave%20to%20communicate%20with%20external%20device%2Cusing%20interrupt%20mode.here%20is%20my%20code%3A%3C%2FP%3E%3CP%3Ecallback%20function%20defined%3A%3C%2FP%3E%3CDIV%3Evoid%20lpspi_callback_int(uint8%20Instance%2C%20Lpspi_Ip_EventType%20Event)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EEvent_global%20%3D%20Event%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif(Event%20%3D%3DLPSPI_IP_EVENT_END_TRANSFER)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%2F%2F%20Cache_Ip_InvalidateByAddr(CACHE_IP_CORE%2CCACHE_IP_DATA%2C%20(uint32)%26amp%3BrxBuffer%5B0U%5D%2C%208)%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F%2F%20read%20data%20from%20rxBuffer%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Et%2B%2B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E__asm%20volatile%20(%22nop%22)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eelse%20if%20(Event%20%3D%3DLPSPI_IP_EVENT_FAULT)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E__asm%20volatile%20(%22nop%22)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Estart%20receive%20data%3A%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Elpspi_status%20%3D%20Lpspi_Ip_AsyncTransmit(%26amp%3BSLAVE_EXTERNAL_DEVICE_1%2C%20TxSlaveBuffer%2C%20RxSlaveBuffer%2C%20NUMBER_OF_BYTES%2C%20lpspi_callback_int)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3EPhenomenon%3A%20The%20callback%20function%20is%20invoked%20when%20the%20master%20sends%20data%20for%20the%20first%20time%2C%20but%20it%20is%20not%20invoked%20during%20subsequent%20data%20transmissions.%3C%2FP%3E%3CP%3EHow%20to%20fix%20this%20issue%3F%20Ensure%20the%20callback%20function%20is%20triggered%20on%20every%20external%20SPI%20data%20transmission.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2289299%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SPI%20callback%20event%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2289299%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3Edo%20you%20call%26nbsp%3B%3CSPAN%3ELpspi_Ip_AsyncTransmit%20again%20after%20callback%20is%20invoked%2C%20to%20prepare%20slave%20for%20next%20transfer%3F%20This%20must%20be%20called%20before%20master%20sends%20new%20frame.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR%2C%20Petr%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
