SENT Protocol
SENT Protocol
Ganesh808
Hi community
I am trying to figure out how to implement SENT protocol on S32K311 PCB board for position detection of Actuator as it has position sensor. As NXP doesn't have Block set related to SENT protocol. It will be a great help if someone is willing to share.
Senlent
Hi@Ganesh808
If you are using S32 DS + RTD, our S32 DS example code provides a demo of implementing the SENT protocol using flexio.
If you are using MBDT, here's a similar answer I've seen:
https://community.nxp.com/t5/Model-Based-Design-Toolbox-MBDT/SENT-Protocol-Support-in-S32K3-MBDT/td-...
If you are developing a project using MBDT and encounter any problems, please ask in the MBDT forum next time. This is a dedicated forum for answering MBDT questions.
