SDK version usage problem
JackChen2022
Hello,Currently the company is using the s32k148_144 chip. At the beginning of the development, the sdK version used was "S32SDK_S32K14x_EAR_0.8.6", and another new version was used later, and the version number could not be confirmed. Now there is a new project using "S32SDK_S32K1xx_RTM_3.0.0". Want to know the difference between different versions of SDK, how to confirm the SDK version, which version is the best or recommended to use
Senlent
Hi@JackChen2022
底层驱动代码文件的起始部分其实都有描述,有详细的版本信息和日期。你安装SDK的时候,安装目录下面有SDK的release信息,你可查看release信息对比各个版本的差别,现在最新的RTM已经到4了,不过需要安装S32 DS V3.4的IDE,我个人喜欢用RTM_3.0.0,旧版本的IDE都可以用,如果想用最新的就下载S32 Design Studio V3.4 IDE,这个IDE旧版本的SDK不能用,只能用最新的好像。
