S32k358 SBC_fs26 module
24,640 次查看
mariam
S32k358 I work on SBC_fs26 and I found this error ('Sbc_fs26_PBCfgVariantPredefined' undeclared (first use in this function)), taking in consideration that we are working using precompile option
26 回复数
2,608 次查看
mariam
yes, the same message
2,606 次查看
JozefKozon
Hi Mariam,
could you please double check if you are using the correct software? The application engineer answered, that there cannot be the same error message if you are using the 2.0.0 RTM as for the 2.0.0 CD1 software.
DESCRIPTION
I assume that the customer is still compiling their project on CD01. Because in RTM version, we already renamed that variable and it does not exist anymore.
With Best Regards,
Jozef
2,601 次查看
mariam
2,598 次查看
JozefKozon
Hi Mariam,
the application engineer would like to have a call with you to discuss the issue and receive more information. Please let me know if you agree with the call and please let me know suitable date time. Please note, that the application engineer is from Vietnam, so morning of our time is more suitable for him.
Please also share the configuration file of your FS26 before the call, so the application engineer can have a look at it.
DESCRIPTION
For now, I cannot check this issue from my side.
Can you please ask them to share their configuration file of Sbc_fs26 component, and maybe set up a call so that I can join?
With Best Regards,
Jozef
2,576 次查看
mariam
Thank you for your efforts; the issue has been resolved.
2,571 次查看
JozefKozon
Hi Mariam,
thank you very much for letting me know. I will pass the information to the application engineer. Have a nice day.
With Best Regards,
Jozef
